South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 11-21-2007, 11:20 PM   #1
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
Default tranny problem
So I was getting on the 101 today and I pushed the gas down in 5th (was going like 60) and the car revved really high. I was like hmmmm...... took it out of gear, put it back in, put the pedl down and once again I accelerated for a second then it was like I was in neutral again. I am assuming my clutch is shot. Not sure if it could be another tranny component tho. any ideas?
tspinks is offline   Reply With Quote
Old 11-21-2007, 11:30 PM   #2
stoner
Member#: 52863
2007 B7 A4
how does it smell, another way to verify the clutch , go to a empty parking lot, and try to start out in second. if it goes and doesn't die then time for a new clutch, but im pretty sure your clutch is shot.
stoner is offline   Reply With Quote
Old 11-21-2007, 11:36 PM   #3
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
it doesn't have that I just launched my car and let the clutch out to slow smell, but it smells like metal on metal. why would it when you say die do you mean stall? cause I have gone 0mph in 2nd before on accident and it never died.
Old 11-21-2007, 11:51 PM   #4
stoner
Member#: 52863
2007 B7 A4
die stall its all the same. is your car popping out of gear, but im still thinking its your clutch.
Old 11-21-2007, 11:56 PM   #5
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
well like when I put the gas down it revved slow, then really fast as if I was revving it in neutral, but the shifter was still in 5th, it didn't pop into neutral
Old 11-22-2007, 12:08 AM   #6
stoner
Member#: 52863
2007 B7 A4
yeah your clutch is done bro, how many miles are on your car?
Old 11-22-2007, 12:10 AM   #7
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
like 30k. I was a n00b and took it to the drags quite a few times tho. suprised it lasted this long. What clutch do you recommend bro?
Old 11-22-2007, 12:29 AM   #8
stoner
Member#: 52863
2007 B7 A4
well with 30k i would say take it to the dealership and try to get them warranty it, usually they will do one clutch. say its popping out of gear and making a grinding noise.
Old 11-22-2007, 12:30 AM   #9
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
I have other mods will they get sad about that
Old 11-22-2007, 12:33 AM   #10
stoner
Member#: 52863
2007 B7 A4
ahh i doubt it, i used to work at a subaru dealership and we had this brand new legacy gt come in with more mods than you could possibly due, yeah warranty took care of their clutch. its worth a try.
Old 11-22-2007, 12:34 AM   #11
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
cool man ill try it. May be upgrade time
Old 11-22-2007, 12:37 AM   #12
stoner
Member#: 52863
2007 B7 A4
yeah could be, i just don't like recommending clutches, i have seen too many horror stories when people do it. reason being the aftermarket clutches don't slip as well as the oem, therefore passing more of the shock on to the other parts of the tranny. i have seen shafts broken in two and many gears well toothless. just treat your tranny like a baby, and it will treat your wallet ok. well maybe.
Old 11-22-2007, 12:59 AM   #13
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Sounds like your clutch.
I doubt warranty will cover it, especially since you are modded.
Stoner is right about upgraded clutches, it is cheaper to replace the clutch then the tranny.
Smoby is offline   Reply With Quote
Old 11-22-2007, 01:26 AM   #14
wrxkid85
Member#: 108452
2005 Impreza WRX
Hahaha Ouchtown, population you bro.
On the real though, that sucks Trev. I'm gonna start worrying about my Trans now.
Lets hope the dealership hooks you up. crazyjulius had warranty kick in on 3 trans issues, and he was stage 2+. So I think there is hope.
wrxkid85 is offline   Reply With Quote
Old 11-22-2007, 12:17 PM   #15
joebud
Member#: 55089
What are your mods? Sounds like you can probably use a mild street clutch. Smooth engagement so it's not so hard on your tranny and more clamping force to handle the extra power.
joebud is offline   Reply With Quote
Old 11-22-2007, 01:55 PM   #16
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
I have the usual bolt ons intake, up dp, header etc... Im pushing like 220-230 whp
Old 11-22-2007, 04:01 PM   #17
gormonk
Member#: 98960
1978 brat (fo realz)
red
i would say go with a mild clutch upgrade...... the act stage 2 is a nice little bump..... not too hard on the street
gormonk is offline   Reply With Quote
Old 11-22-2007, 06:35 PM   #18
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
I thought ACT Stage 1 would handle that? But you're the tranny master, JJ, so I'd take your word over mine any day
Black-Falcon is offline   Reply With Quote
Old 11-22-2007, 10:17 PM   #19
gormonk
Member#: 98960
red
meh...... it should do fine but its not much of in increase over stock.i mean im still rocking a stock clutch..... so is rich. and we're both putting down more than that. i would stil like a little increase in clutch feel over what i have now but not at the expense of another transmission. but with the lower power hes putting down a stage 2 would net great pedal feel while still not being too agressive for the tranny.
Old 11-23-2007, 12:45 AM   #20
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
get a stock STI clutch and flywheel and grind out hte part of the bellhousing
bobturismo is offline   Reply With Quote
Old 11-23-2007, 03:29 AM   #21
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
When I read "Tranny Problem" I though McCrackin's girl finally let him outta the basement again!
Now that I read the thread, I'd say your clutch is Kaput, like previously stated. Get a new stock clutch, and get a STI SS clutch line while your at it.
John2.5RS is offline   Reply With Quote
Old 11-23-2007, 09:27 PM   #22
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
I guess I will go to subaru and get a new stocker
Old 11-24-2007, 09:00 PM   #23
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
Tuned @ FAT by Snail Perf
Don't get the stocker from a dealership. Just order it on-line. So much cheaper and you get the same part. Go to 1stsubaruparts.com I think that's what it is. Got a new ac hose off there for $60 less than what the dealer charged.
BugeyePB Rex is offline   Reply With Quote
Old 11-26-2007, 06:56 PM   #24
tspinks
Member#: 109088
2006 Infiniti G35
Liquid Platinum
well I took it into subaru but they want 350 to do a diognostic and if it comes back they won't warranty it I have to pay the 350. If I want them to replace it it will be another 950. If they warranty it then they will cover all the cost. Dunno if i want to pay them 350 for them to tell me they wont warranty it. Anyone have a better idea? Dunno if i want to get an upgraded clutch. Maybe a stage 1
Old 11-26-2007, 07:06 PM   #25
racingfish
Member#: 60976
1969 LGT
FATURBO
Yeah dont figure on the dealership covering it. If they see any "blue" on your fw then your gonna be paying out of pocket. stock clutch jobs cost around 1300 so be prepaired. thats the cost of the clutch, fw, tob, pp.
racingfish is offline   Reply With Quote
Tranny problems to worry about? hoffmada000 Transmission (AT/MT) & Driveline 2 06-03-2010 11:21 PM
Major MY98 problems. Anyone else with an MY98 have clutch/tranny problems? Sean Warranty Issues & SOA Problems 20 11-03-2001 10:33 PM
Auto Tranny Problem... Help? DarkLite Normally Aspirated Powertrain 3 03-08-2001 11:15 PM
Attn: Pre 99 turbo manual's any tranny problems.... MPREZYA Normally Aspirated Powertrain 12 03-08-2001 12:51 AM
