Old 01-24-2002, 04:28 PM   #1
daytontp
Member#: 9797
2005 Honda S2000
New Formula Red
Default A/F Ratio Change Relocation Question???
I am planning to buy a 2 1/16" AutoMeter A/F Ratio gauge, specifically the Carbon faced UltraLight model. I understand that the 2002 WRX has a wide band (0-5 volt) O2 sensor in the front and a short band (0-1 volt) O2 sensor in the rear. I also understand the AutoMeter gauge only works with a short band O2 sensor. I also understand that with a stock exhaust the reading would be more accurate before the front cat than after the rear cat. I am also planning to put a turbo back exhaust and uppipe in the car, from M2 Performance. As well as M2's TMIC. And, I understand the CELs issues with this exhaust mod. I am not planning on buying an EGT gauge. I have several questions, which if you read all of them you may understand where I am going with them.
1. What is the thread size of the EGT bung on most aftermarket uppipes? I am assuming 1/8" NPT or 1/8" BSPT.
2. What is the thread size of the WRX's rear O2 sensor threads? And, will it fit into the bung in most aftermarker uppipes?
3. If I put the uppipe and turbo back exhaust on my car, would the reading at the rear O2 sensor be more accurate than with the stock exhaust? I am guessing yes.
4. Now, lets say I have the uppipe, a turbo back exhaust and a MIL Eliminator capacitor installed on the rear O2 sensor (to stop the CELs). If the A/F gauge is hooked up to the rear O2 sensor, will it effect the A/F Gauge readings? I am guessing NO if the gauge is connected to the wire inbetween the O2 sensor and the capacitors. And, YES if the gauge was connected to the wire inbetween the ECU and the capacitors.
Any suggestions will be welcomed!!!
daytontp is offline   Reply With Quote
Old 01-24-2002, 04:44 PM   #2
daytontp
Member#: 9797
2005 Honda S2000
New Formula Red
I forgot to mention something.
I am not planning on moving the rear O2 sensor to a location before the turbo. I would buy another rear O2 sensor and put it in the uppipe, or near there. Both of the stock O2 sensors would stay in their correct locations. Which brings up the question as how to wire the new one up. How would voltage wires be setup so the sensor would work? Because if you were to wire the sensor into the location the rear O2 sensor is wired, it would trip CELs. At least I guess it would.
Any suggestions!!!
Old 01-24-2002, 04:53 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
1) The stock EGT sensor's threading may be M8 x 1.0, but I don't really know. I doubt it's 1/8" npt.
2) The O2 sensor's threading is M18 x 1.5 and definitely won't fit into the EGT bung. You could have the EGT bung removed and an O2 bung welded on in its place.
3) I agree that the rear 02 sensor would be more accurate with only one cat ahead of it instead of 3.
4) I believe that if you connect your gauge somewhere between the sensor and the MIL Eliminator resistor, it will not be affected by the MIL Eliminator.
Jon [in CT] is offline   Reply With Quote
Old 01-24-2002, 09:46 PM   #4
bobgrice
Member#: 10627
2002 WRX Sedan
Platinum Silver Metallic
To clarify, the EGT sensor threads are definitely not 1/8" NPT. They are M12 x 1.25.
I just had to make some custom parts for my up-pipe, so I purchased a high speed tap and die in this size.
If anyone would like to buy or borrow the tap & die, just PM me and let me know.
bobgrice is offline   Reply With Quote
Old 01-24-2002, 10:12 PM   #5
daytontp
Member#: 9797
2005 Honda S2000
New Formula Red
Thanks for the info!!!!
1. Does anyone know how to wire the O2 sensor, if I was going to add a 3rd one on the uppipe?
2. Does anyone have an idea what the rear O2 sensor would cost me at the dealer?
I am probably just going to put it on the rear O2 sensor and then just deal with it not being as accurate until I get my turbo back exhaust.
Old 01-24-2002, 11:06 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
An unheated O2 sensor (one wire) can be purchased for about $30 at your local auto parts store. If it's mounted in the uppipe, it won't need a heater and having only one wire should make wiring it to your gauge simpler.
Old 01-25-2002, 07:05 AM   #7
bobgrice
Member#: 10627
2002 WRX Sedan
Use caution when mounting an O2 in your up-pipe. I understand (not from experience, though), that it is NOT a good idea to put it here, I imagine due to higher temperatures in the long run.
As I mentioned, mine is mounted 4" after the turbo on my downpipe, which from what I understand is the prime placement. My BPM downpipe had a bung, so it made it too easy.
I totally agree with Jon to purchase the CHEAPEST single wire O2 sensor you can find and wire it up. The one I purchased was heated and I should have just saved the money and gotten a cheaper one. The heater is to get a better reading more quickly, but, if you're taking care of your car and letting the oil temp get to operating conditions before jumping on your engine (several minutes), your O2 sensor will be plenty hot to give you good readings. The only advantage of the heated O2 is that I have good readings within 20 seconds of turning the key (engine running or not).
Just my $.02 (perhaps $.03).
Old 01-26-2002, 03:17 AM   #8
wrx_in_efx
Member#: 10889
Yup, 265whp 255tq
Pink oWz JoO!!
I just hooked up a halmeter A/F guage and I spliced in to the Rear o2 sensor signal wire. It takes a minute or so for it to heat up but It is accurate. Check out Rifts hm page, he shows you exactly how to do it. www.projectwrx.com
LAter.
Cory
wrx_in_efx is offline   Reply With Quote
What Is the Forumula for Torque Change due to Compression Ratio Change? williaty Normally Aspirated Powertrain 30 02-09-2009 09:03 PM
STI swap gear ratio change scotty17509 Transmission (AT/MT) & Driveline 3 07-16-2008 08:27 PM
Steering Rack ratio change rob Subaru Conversions 3 10-01-2004 01:34 PM
ratio change in a 02 WRX 5MT ?? quig Transmission (AT/MT) & Driveline 4 07-28-2003 07:38 PM
4.111 final drive ratio change to 4.4???? okamikatekore Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-20-2002 02:00 AM
