Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 11-22-2007, 03:09 PM   #1
drkramm
Member#: 159156
2007 wrx
wrb
Default boost cut 4th-5th gear
io was helping a friend tune his 06 wrx with a cbe and i was giving it a lil more boost and we had no proplems maxed at 15 psi ran great thru 3rd didn't pull any timing now today he was out and called me saying he had a cel but car was running fine and boosted fine so i reset the computor take it out 1,2,3 no proplems but 4th and 5th gear both will cause fuel cut around 3500-4000 rpms (around max boost)
rpm boost(psi wot)
800 3.52
1200 7.54
1600 8.16
2000 10.60
2400 13.92
3300 14.97
3600 13.77
4400 13.05
5600 12.10
6000 10.56
6400 9.86
the boost limit fuel cut is set at 16.07psi
am i jsut trying to run too much boost with the factory dp or should i nudge the fuel cut up a lil
i could't get the code scanned since its thanksgiving and most places are closed around here
drkramm is offline   Reply With Quote
Old 11-22-2007, 03:30 PM   #2
LateApex31
Member#: 135686
The rate of change of RPM is slower in the higher gears which will cause this to happen. You need to balance the need for quick spoolup and meeting boost targets in the lower gears with controlling boost in the higher gears.
LateApex31 is offline   Reply With Quote
Old 11-22-2007, 03:32 PM   #3
drkramm
Member#: 159156
2007 wrx
wrb
i understand what you mean but how do i go about doing it ?
thanks for the quick reply though
Old 11-22-2007, 03:42 PM   #4
drkramm
Member#: 159156
2007 wrx
wrb
i think im jsut gonna back the boost off ran great at 13psi in all the gears
i doubt the extra 2 psi is really making that big of a diffrence specaily when its cutting out anyway
Old 11-27-2007, 04:16 PM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
Are you running a MBC? They are more sensitive to both temperature and load. I'd only turn the boost cut up if you are not detonating.
Old 11-27-2007, 06:40 PM   #6
drkramm
Member#: 159156
2007 wrx
wrb
na its the factory bcs
Old 11-28-2007, 12:11 PM   #7
controler
Member#: 100271
Are you hitting higher boost than in your targets? It could be an issue with the wastegate arm is too tight.
controler is offline   Reply With Quote
Old 11-28-2007, 12:57 PM   #8
bboy
Member#: 56468
04 Improved STI
Dirty White
Maybe it's not "boost" cut. There are several fuel cuts that it could be. MAFv, Load, Boost,....
Try posting a log of: AFR, MAFv, Load, MRP, and RPM (you could throw knock correction, and AF learning and AF correction in there too if you want). Use the "code" wrapper to post the log.
Wastegate opens 4th+5th gear low boost? 99subi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-18-2008 09:28 PM
04 sti 4th-5th gear grind? stiman17 Transmission (AT/MT) & Driveline 3 09-19-2007 05:32 PM
Weird 4th,5th gear problem fluxcapacitor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-30-2006 01:22 PM
Power loss @ 4th 5th gear......??? |los| Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-31-2006 05:02 PM
4th - 5th gear grind kettsupp Warranty Issues & SOA Problems 5 10-19-2005 07:35 PM
