Old 11-22-2007, 09:36 PM   #1
turbodrive
Member#: 101744
1992 Legacy Turbo
Default front crank pulley bolt very tight, left or right hand thread ?
I am having trouble removing the bolt on the lower pulley, it would help to know if it is left or right hand thread. Anyone have an idea ? Thanks.
1995 Subaru Legacy Sport EJ22T 5MT
turbodrive is offline   Reply With Quote
Old 11-22-2007, 09:49 PM   #2
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
ummm.. right tighty lefty loosey.. crank bolt is the same as most other bolts. easiest way to break it loose is rest the end of the breaker bar just behind the radiator (on the driver side of course) and bump the starter.
bugeye829 is offline   Reply With Quote
Old 11-23-2007, 03:33 AM   #3
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
It's normally threaded for sure.
If your somewhat apprehensive about bumping the starter to break it loose, Throw the car in fifth with all the wheels on the ground, grab a 1/2 inch ratchet with the appropriate socket, and a 3 foot breaker bar. I use a 3 foot ceiling fan extension bar as my breaker bar. Works like a champ.
We had to crank the crank pulley off a Toyota pick up once and couldn't get it loose. We ended with using a 3/4 inch socket, 2 foot breaker bar with a 8 foot extension bar. Two Mexican guys were hanging from the bar and it still wouldn't break, so a third guy grabbed the bar, they all bounced one time in unison and it finally cracked. When the bolt let loose in the stall, it was louder than a gunshot and the customers in the waiting area freaked out and thought someone had a gun.
True Story.
/Brox
Broxma is offline   Reply With Quote
Old 11-23-2007, 06:42 PM   #4
imprezilization
Member#: 73471
2004 WRX Stg2+some
Blk melon launcher
Originally Posted by Broxma View Post
Two Mexican guys were hanging from the bar and it still wouldn't break, so a third guy grabbed the bar...
True Story.
/Brox
so how many Mexicans does it take to loosen a bolt?
imprezilization is offline   Reply With Quote
Old 11-23-2007, 08:54 PM   #5
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
My 07 STI took a 3 ft breaker bar put it in gear and pull the E-Brake tight, and pull it like your 12 and its your pud it'll bust loose.
4ST-AIR is offline   Reply With Quote
Old 11-24-2007, 10:28 PM   #6
turbodrive
Member#: 101744
1992 Legacy Turbo
Thanks for all of the ideas. After finding out that it was standard rh-thread, I put a breaker bar on the bolt and had my Dad bump the starter while I held the bar, it worked great.
Old 11-24-2007, 11:30 PM   #7
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
You're a braver man than me!
MannyMohawk#5 is offline   Reply With Quote
Old 11-24-2007, 11:31 PM   #8
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
come again??? WOOOOW
Old 11-25-2007, 02:12 AM   #9
EntertheWagon
Member#: 163729
04 War Wagon
Wow Really Blue
you could have hurt yourself doing that
EntertheWagon is offline   Reply With Quote
Old 11-25-2007, 03:46 AM   #10
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
why hasn't someone put a tried and true way to do this in a stickey. makes more sense then having the kid trying to hurt himself severly. this is what i did and worked like a charm. i put my car in fourth with two 4x4 peices of wood behind the front tires, pulled the e-brake, sprayed pb blaster let sit for about 5 min. then i grabbed my breaker bar with my 21mm socket, and gave it a nice hard push to the left, and bingo. it took me all of 20min to change mine. there stickey that so no more noobies hold the breaker while their dad cranks the engine over. for auto's don't ask me i don't own one but i am sure someone will have a stickey for that i hope.
midnight2.5rs-t is offline   Reply With Quote
Old 11-25-2007, 01:48 PM   #11
68Cadillac
Member#: 95901
That's exactly how I broke mine loose:
PB Blaster.
Car in 4th with the E-brake on.
My 1/2 inch drive breaker bar.
Three foot extension.
Broke loose on the first try.
PB blaster rocks your wrenching world.
Oh and to answer the OP question. It's a right-hand (normal) bolt.
68Cadillac is offline   Reply With Quote
left or right? right or left? left or right?right or left? rendog24 Off-Topic 2 09-12-2007 07:12 AM
TablesawerZ Left hand tilt or Right hand tilt? [email protected] Off-Topic 11 09-08-2006 06:37 PM
Left or Right handed? alacrity024 Off-Topic 26 01-25-2006 01:31 PM
Fork in left hand...or right hand? DrDRum Off-Topic 47 06-21-2005 02:55 PM
left or right handed? HubCap Off-Topic 19 01-16-2003 10:28 AM
