Old 11-23-2007, 02:53 PM   #1
djerickd
Member Sales Rating: (41)
Member#: 3782
02 WRX WFC#040
Clean on 19's
Default Driveshaftshop WRX Driveshaft
some aftermarket parts not compatable
Kartboy rear shifter stay bushing rubbed, so I went back to a modded stock:
here is the modded stock shift stay, I placed a thick aluminum washer siliconed in the void so it's a little stiffer and ensures the entire shift assy is lifted upward ever so slightly. Even when installed I hammered it upward a bit, just to be sure it cleared.:
it's upside down in this pic:
hammer work on the tunnel:
parking brake rubs a little"
the car feels lighter! no balance issues or vibrations post install... I have only taken it to 80mph so far tho...It's definatly more driveable down low in 4th and 5th I can crawl at 2000 rpm and it doesn't bog. I get up to speed quicker too, it feels like I lost 50lbs or more of dead weight I'll post more as I drive on it. I left off the diff cover, it's must weigh 5lbs+ there is a weight welded to it. I don't think this will be an issue as others have done the same and not reported any negative effects.
djerickd is offline   Reply With Quote
Old 11-23-2007, 02:56 PM   #2
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
damn I need to change that seal on the rear diff
Old 11-23-2007, 02:59 PM   #3
All4bSpinnin
Member Sales Rating: (10)
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
very nice, if i ever drive down to tampa can i take a ride in the car to feel the difference?
-dave
All4bSpinnin is offline   Reply With Quote
Old 11-23-2007, 03:01 PM   #4
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
yessir!!!
Old 11-23-2007, 03:03 PM   #5
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
oh, btw.... what was the difference in weight?
Old 11-23-2007, 03:04 PM   #6
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
IIRC (I didn't weight it) but it's 13.5lbs and the stocker is 31. (can anyone validate this?)
Old 11-23-2007, 03:11 PM   #7
112nick
Member Sales Rating: (1)
Member#: 83735
'06 Impreza WRX STi
This is the aluminum drive shaft, correct? 13.5 lbs isn't likely. The CF driveshafts are 14.? lbs.
112nick is offline   Reply With Quote
Old 11-23-2007, 03:26 PM   #8
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
yup aluminum... shipping weight on box was 15lbs.
Old 11-24-2007, 01:53 AM   #9
thejaredhuang
Member Sales Rating: (53)
Member#: 86206
2006 WRX Wagon
Thanks for info on the kartboy bushing.
thejaredhuang is offline   Reply With Quote
Old 11-24-2007, 01:56 AM   #10
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
yup! It is now for sale as well!
Old 11-24-2007, 06:15 PM   #11
Token-Negro
Member Sales Rating: (25)
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Do u think the KB unit would be used if you modded it?
Token-Negro is offline   Reply With Quote
Old 11-24-2007, 08:05 PM   #12
Vendor Sales Rating: (62)
Member#: 67
1999 Outlasting
the competition.
you could probably shave a little off the rear shifter bushing and it should work just fine.
Tom
Old 11-24-2007, 09:01 PM   #13
bmxpunk
Member Sales Rating: (17)
Member#: 89599
1995 almost 22B:)
red
Thats not exactly true. Its similar to bicycles ( spent a decade in a shop). Carbon can be lighter but to make it as strong in an aplication like this you have to have strenght in many different directions. To make carbon strong enough to handle forces in all of these directions you have to do mulptiple weaves and more carbon. Aluminum is neat becasue you can thin the wall down a little and go with a little larger diameter and have the same strenght for a little less weight. And if that is all wrong I totally hold accountable all the bike reps I have ever spoken to.
By the way, nice write up. I am looking to do this to my RS, but banging out the tunnel still scares me.
bmxpunk is offline   Reply With Quote
Old 11-24-2007, 10:18 PM   #14
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
yes definately... dremmel it with sandpaper wheel!
Old 11-25-2007, 07:15 PM   #15
Crazykev
Member Sales Rating: (38)
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Haven't drove with mine yet, but here is an installed pic
Crazykev is offline   Reply With Quote
Old 11-26-2007, 09:30 AM   #16
voidths4
Member Sales Rating: (3)
Member#: 158802
R.I.P. Justin
djerickd, thx for your write up, I greatly appreciate it. Now, if you donít mind. What I can see from the pictures, it looks like the only issue that you are running with the floor is right by the diff; is that correct? Also, it seems like you did a lot of hammering but the floor doesnít look like it moved much... how far up do you think you pushed it?
Crazykev, let us know your driving impressions. Thx
voidths4 is offline   Reply With Quote
Old 11-26-2007, 10:50 AM   #17
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
yeah the areas to hammer would be the area right around where the ebrake cables exit the body and a few areas on the passengerside of the tunnel where it's closest. I think I maybe moved the metal at the most a 1/2"...
Old 11-29-2007, 11:43 AM   #18
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Kevin did you take yours for a ride yet? or are you still down?
Old 12-07-2007, 10:24 PM   #19
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
still lovin it, no issues...
Old 12-08-2007, 12:11 AM   #20
txl146
Member Sales Rating: (145)
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
price on this thing?
Old 12-08-2007, 12:14 AM   #21
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
about $420-450...
Old 03-16-2008, 11:23 PM   #22
wrxwagon253
Member Sales Rating: (81)
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
Did you have any problems with the driveshaft rubbing anywhere else but the floorboard? I just installed mine and it looks like it might rub on the upper half of the rear diff cover..Any input on that?
wrxwagon253 is offline   Reply With Quote
Old 03-17-2008, 09:03 AM   #23
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I left that cover off mine...
Old 05-10-2008, 07:38 AM   #24
fastwrx25
Member Sales Rating: (37)
Member#: 126441
03 bugeye
any updates? might be getting one
fastwrx25 is offline   Reply With Quote
Old 05-10-2008, 03:24 PM   #25
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
still doing good!
Driveshaftshop WRX Driveshaft & GTSpec Subframe Install dug-e-fresh Car Part Reviews 61 05-08-2011 04:47 PM
VA: DriveShaftShop, alluminum driveshaft Rexxyou Drivetrain 5 04-06-2009 09:21 PM
WTB: STI driveshaft Or automatic wrx driveshaft. DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 7 09-12-2005 03:03 PM
wtb: automatic wrx driveshaft or STI driveshaft. DoctorNick Private 'Wanted' Classifieds 2 08-21-2005 09:58 PM
sti driveshaft and wrx driveshafts, difference? drivrswntd Transmission (AT/MT) & Driveline 4 12-20-2004 10:52 PM
