#1 |
Member#: 1140
SCIC
Vehicle:2013 Ecoboost'd F150 Grey |
So now that's it's finally street legal, I thought I'd take the time to make a new thread to show the results of months of planning, plotting, and working on building one of the greatest GC coupes on the road today. I've been working on it since Valentines' day, and I still have to get a few more parts and install a few things, but for all practical purposes, it's done enough to show. So here it is. I still have some more numbers to gather, such as a new dyno chart and 1/4 mile slips but I will update as I get them.
I'm going to go take some more pictures soon, but here's a few I have right now. Future plans include 3 more Defi's, Side skirts, a front lip, a larger turbo (HKS GT2835 twin-scroll), And if needed, another trunk w/ a spoiler (for the track), and brake ducts routed through Driving light fog covers. Weight: 2697 lbs (Wet, with full tank of gas) Power: ??? (Goal: is 300-350 w/ stock turbo, 400+ with HKS turbo) 1/4 Mile time/trap: ??? (Goal: high 11/low 12-sec range on street tires) 60' Time: ??? (Goal: Around 1.6/1.7 sec) 0-60 time: ??? (Goal: 4 seconds) Power-to-weight Ratio: ???/??? (Stock approx. 17.2-22.8lbs/HP; Goal 6.3-8.0lbs/HP) This was the shell I started with. 02-14-07 ![]() ![]() Mod List As of 10-14-09 Exterior Mistubishi Evo MR Graphite Grey paint STI Sport front bumper CF Burn-up style Front lip color matched side skirts Blacked out headlights and corners HID Hi/Low (6k) headlight conversion. Smoked corner lights w/ Amber LED light bulbs Amber bumper turn signals. (ver. 3 STI style) Smoked JDM STI Ver. 6 Red/Clear Tail lights Do-luck style flared front fenders JDM Subaru GC Aluminum hood 22b hood vents CF S201 hood scoop Seibon CF doors CF WRC mirrors CF 'STI' fog cover decals Roof replaced with L roof skin (sunroof delete) Seibon CF trunk JDM ver. VI rear bumper cover JDM Ver. VI rear plate holder Window tint Shaved side moldings Antenna Delete plate 06 STI rear diffuser Rallitek Front skidplate S202 CF adj. spoiler Wheels/Brakes 18X8" Prodrive GC-05F 5-spoke British Black wheels Dunlop Durreza Z1 Star spec 225/40/18 tires Rotora Red 355mm(14") 2-piece slotted rotors, 6-piston front brakes, SS lines Rotora Red 330mm (13") 2-piece slotted rotors, 4-piston rear Brakes, SS lines Black STI lugnuts Motul RBF 600 brake fluid Suspension/Chassis JDM GC8 Turbo front x-member JDM STI ver. 8 Rear x-member Tein Flex Coilovers Tein EDFC Custom Chrome moly rear strut brace JDM STI ver. 6 CF front strut brace Aluminum fender braces GC8 Pink STI Full pillow ball lateral links GC8 Pink STI trailing arms JDM GC8 Aluminum front control arms Perrin (PSRS) castor kit Kartboy front sway bar end links STI front swaybar Whiteline 22mm rear sway bar Perrin Heavy Duty rear swaybar mounts R180 hubs Custom welded DOM rollcage (8-pt) Corner-balanced Engine/Transmission Utec EM with Launch control, Flat-foot shifting, Map switch Zerosports JDM STI ver.8 Spec C ECU 2005 Ver. 8 JDM STI EJ207 VF-37 Twin-scroll Turbo Auto-to-manual conversion JDM STI ver. 8 6-Speed transmission R-180 Rear Differential Syms larger capacity Diff. cover Custom3" Bellmouth ceramic coated DP Prodrive 3-port boost solenoid Walbro 255 lph fuel pump JUN upgraded adj. (1-1.3 Bar) WG actuator JIC Full Titanium 3" non-resonated Exhaust (18 lbs.) Kartboy HD poly. Exhaust mounts 2005 STI radiator STI uprated red Intercooler-TB hose STI Radiator cap STI SS-braided clutch line Samco Radiator hose kit Samco Ancillary hose kit JDM Power Steering fluid cooler Kartboy Poly Shifter bushings (F & R) Kartboy Short shifter Custom Intercooler sprayer system Zerosports GC8 intercooler splitter (discontinued) Beatrush Alternator pulley Power Enterprises Accessory drivebelt Prodrive Battery Tie Down Prodrive oil cap Prova Brake Res. cover Prova Clutch Res. cover C-West CF MAF sensor cover ARC belt cover ACPT CF Driveshaft Interior sound deadening removed gutted interior & trunk Semi-gutted dashboard Repainted interior black Trunk light kit Defi Gauge Pod (discontinued) Defi BF gauges (EGT, Oil Press., Turbo) Radio delete plate, made to house 3 52mm gauges Defi Link controller II JDM Ver. 6 STI instrument cluster STI Titanium Shift Knob STI Titanium Ignition Keys Prodrive 350mm Black Leather 3-spoke steering wheel Splash (JDM) short steering boss NRG quick release Recaro Pole Position SPG seats Sparco 3" 6-pt quick release harnesses Sparco 3" Harness pads Longacre 17" convex racing mirror 04 STI Blue Carpet w/ Matching Aluminum deadpedal 06 STI Black floor mats WRX drilled Aluminum pedals STI Stainless steel Door sill plates power-to-Manual window conversion Several very hot months later, here's the fruits of my labor (With the help of Tyler (Smoby) , Evan(KrazyIvan), and Justin(dlurx4), And Zephyr, for the wiring ) these were taken around 01-01-08 ![]() ![]() ![]() ![]() \/ If you look closely, you can see the Syms Rear diff. cover and the STI full-pillowball lateral links ![]() ![]() ![]() Still have to install the CF STI strut brace in /\ That picture. ![]() http://www.cardomain.com/ride/3173841
#2 |
Member#: 1140
SCIC
![]() ![]() ![]() ![]() /\ This one's to show the CF doors, it's a little older, I took it before I installed the window trim ![]() /\ Need to make some door cards for the manual windows. ![]() ![]() ![]() Before it went to paint, To show the rear diff. cover & STI bits, rear diffuser will block the cover once installed. ![]() I'm looking forward to getting it out on the road & track and seeing what I can do with it! Last edited by John2.5RS; 11-23-2007 at 10:38 PM. |
#3 |
Member#: 126181
NWIC
Vehicle:02 wagonmafia silver |
mother of god! clean as a porn stars balls
#4 |
Member#: 150006
SCIC
Vehicle:2002 WRB WRX HBSpeed tuned 18g 326whp/281wtq |
niiiice subie bro. . . is it strictly just a track car? (im figuring it is since the whole roll cage setup and the gutted interior)
#5 |
Member#: 142014
AKIC
dude, nicely done. now became one of my favorites.
btw....GC-05's in british black..i have the same rims and love them. any high Res pics of your car?? |
#6 | ||
Member#: 1140
SCIC
![]() Hell no! I made sure to make it street legal, So I can cruise around in it, and I can drive it to the track, trailers are a PITA. I build my cars to drive them (that's why this is my 3rd RS, totaled the other 2! )Quote:
#7 |
Member#: 122306
South East
Vehicle:2002 Sti PTE 6262sp Interlagos Blue 551/441 |
Nice looking car. I dont care for the CF doors but its hot.
#8 |
Member#: 124935
SWIC
Vehicle:'05 WRX |
Why didnt you paint the CF
... Just kidding.... Looks gooooood! It would look way better with a front lip and side skirts, thats just me though ... |
#9 |
Member#: 123305
NWIC
Vehicle:1999 E36 M3 Cocaine Cowboy |
Justin is a good guy!!!
great work again, justin |
#10 |
Member#: 156478
Vehicle:06 330i Blue |
#11 |
Member#: 96944
Vehicle:2005 SAAB 9-2X AERO 4eat Stage 2 Protuned |
Looks insane, love the color, but for me it's missing some kind of spoiler, never liked the GC8 wingless.
#12 |
Member#: 136133
Vehicle:07 WRX Wagon LTD Urban Grey Metallic |
Sick car. Amazing work on it, i'm kinda jealous. No i am.
#13 |
Member#: 108452
SWIC
Vehicle:2005 Impreza WRX Black |
#14 |
Member#: 120924
SWIC
Vehicle:2006 WRX Lmtd Wagon Should be IMPREZme06 |
wow, impressive!! From the shell to this masterpiece! Did you do the majority of work in your garage? And how the F did you do this?
#15 |
Member#: 48025
NESIC
Vehicle:2011 WRX WRB, 302whp-320wtq |
crazy buildup, I think the car would look better with 17's
#16 |
Member#: 106521
SWIC
Vehicle:I am an ancient of chaos. \\ t3hclap.com |
So seck-si.
#17 | |||
Member#: 1140
SCIC
![]() ![]() Quote:
![]() ![]() ![]() Quote:
I'm planning on getting another trunk & spoiler for the track. ![]() |
#18 |
Member#: 90235
SCIC
Vehicle:1993 GC ej255 swap White |
aww im jealous =D
#19 |
Pirates > Your Mom
Moderator Member#: 104055
International
Vehicle:96 RHD555, 98 RHD STi, 91 NSX & 06 9-2xAero |
#20 |
Member#: 146911
just, wow.
#21 |
Member#: 83638
TXIC
damn nice build. i think i said this somewhere else... but is that a 02/03 jdm scoop cause if it is... this is the one other instance where i like different year scoops on different models/
props |
#22 |
Member#: 102323
SWIC
Vehicle:99 power poles beware |
Time To Crank Da Boost
#23 |
Member#: 106799
Vehicle:2004 built 257 tomei powered ^.^ |
b-you-t-Full
#24 |
Member#: 110653
Vehicle:87 FC3S Black |
everything looks sick!...except those cheap ass ebay corners. they look like they are worth what you payed for them.
#25 |
Member#: 13641
TXIC
Vehicle:08 Audi RS4 03 SY WRX (DAILY) |
pure sickness, hawt 4 sho
| Thread Tools | |
| Display Modes | |
| WTB: 98-01 2.5 RS Coupe | evilferret | Tri-State Area Private Classifieds | 36 | 09-23-2006 01:53 PM |
| $6500 98 suby rs 2.5 coupe rally blue with 5 spokes gold rimes | wantasuby | Private Vehicle 'For Sale' Classifieds | 1 | 06-17-2006 02:28 AM |
| $6500 98 suby rs 2.5 coupe rally blue with 5 spokes gold rimes | wantasuby | Private Vehicle 'For Sale' Classifieds | 8 | 06-12-2006 07:05 AM |
| WTB 98-01 2.5 RS Coupe | evilferret | Tri-State Area Forum | 2 | 08-28-2005 06:01 PM |
| WTB> 98-01 2.5 RS Coupe TristateArea-Willing to pick up reasonable distance | evilferret | Private 'Wanted' Classifieds | 0 | 08-18-2005 02:22 AM |
