Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Alaskan Impreza Club
Old 01-24-2002, 08:59 PM   #1
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Question cold starts
is it normal for our cars to be hard to start when it is really cold outside, like these past few days? my car took a few tries to get it started today.
AK_2002_WRX is offline   Reply With Quote
Old 01-24-2002, 11:19 PM   #2
RawCode
Member#: 3115
2002 Impreza 2.5RS
Mine did once about a month ago. and I have a half litre more displacement than you! heheh...
I am running mobil 1 synth also...
RawCode
RawCode is offline   Reply With Quote
Old 01-25-2002, 04:04 AM   #3
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
that's happened to my car sometimes...
SQUAD_907 is offline   Reply With Quote
Old 01-25-2002, 04:13 AM   #4
AKSubie
Member#: 6214
92 Corrado SLC
www.motorsportsalaska.com
Happens to me too. Although if I remember to plug in, it doesn't.
AKSubie is offline   Reply With Quote
Old 01-25-2002, 04:29 AM   #5
MrJoe
Member#: 13192
Default Hard Starts - My solution
Try this: when starting your WRX, especially when it's cold - turn the key to the ON position (the last key position before the starter engages) and let it set for 3 seconds.
After three seconds - turn the key the rest of the way - and you should be fine.
If you turn off all your heater/radio/etc - you can hear the WRX fuel pump pressurize during that first three seconds.
Since I've been doing this with my WRX, I've had no problems what-so-ever with very quick starts.
Let me know how it works for other people out there.
Joe
MrJoe is offline   Reply With Quote
Old 01-25-2002, 07:45 PM   #6
WRXnFX
Alaskan Mafia
Member#: 10398
I do the three second thing and I still have a hard time starting when it is really cold. It's supposed to be 25 below tonght. It better warm up or I'll have to dress warm for the meet. Winslow
WRXnFX is offline   Reply With Quote
Old 01-26-2002, 01:25 AM   #7
zemmo
Member#: 5416
2002 Wrx wagon
You Las Anchores guys are talking cold!? If it's really cold it ain't gonna start, not unless it was plugged in. Interestingly, the WRX owner's manual says something about giving it some throttle while cranking for cold weather starts. I haven't had to try it yet, but never try to start w/o plug-ins if it's below minus 10 or so. The best of cars will start down to minus thirty, but they make some horrible noises doing so. Y'all have a good meet.
zemmo is offline   Reply With Quote
Old 01-26-2002, 01:55 AM   #8
hotrod
Member#: 14141
2002 Impreza WRX
I recall a post some time back that refered to the fact the WRX has a lightweight battery, which of course implies limited cold weather cranking capacity.
The subaru manual #1 General Information, lists the stock battery as being:
MT 48AH res. cap. 99 min cold cranking 356 amps
AT 52AH res cap. 111 min cold cranking 420 amps
I will probably go to a higher capacity battery if I have any start problems.
I'm sure your already using a light synthetic oil like mobil 1 5W 30. If not that will be a big help. I have been using it for about 15 years and haven't killed a starter or battery since the switch.
I also disabled the daytime running lights which will make it easier for the alternator to keep the battery charged in short drive situations.
Unfortuantly, we haven't had any decent cold weather here, although it should get down into the single digits soon. So far the coldest start I've had to make with the WRX is cold soaked all night at about 20 deg F. and I did notice it cranked a bit longer than I expected, and is why I pulled the running light module.
Larry
hotrod is offline   Reply With Quote
Old 01-26-2002, 02:12 AM   #9
zemmo
Member#: 5416
2002 Wrx wagon
True, CCA is low on the OEM battery, engine doesn't crank very fast below zero. Even so, I made it thru 5 years on the OEM battery with my last Impreza, but like I say, I plug it in if cold.
Old 01-27-2002, 02:14 AM   #10
KapaFool
Member#: 2679
2010 WRX4FD
Cool
I have been putting in Diehard Golds in the vehicles I have had. They work excellent. I think they are about 900 cca. I have had one in my 91 prelude for over 6 years and didn't ever have a problem with it. I never plugged it in, due to the fact that I bought the car in Hawaii and didn't come with a block heater. In fact it didn't even have a heater. I found out the first winter I drove the car here. Anyways I have an Optima in the RS right now and hopefully I'll be putting one in the WRX too. I think about 800 cca.
KapaFool is offline   Reply With Quote
Scratching/Scraping sound when cold starting speedracer47 Normally Aspirated Powertrain 14 05-23-2010 05:52 PM
('93-'01) Cold starting up my Impreza RS 2001 AliasAngel Impreza Forum 17 06-01-2001 10:35 AM
Just how bad ARE those cold starts? 8Complex Normally Aspirated Powertrain 23 12-20-2000 07:08 AM
Cold start - revisited Steve00RS General Forum Archive 3 12-18-2000 08:07 PM
Cold starting mrbell General Forum Archive 5 12-16-2000 12:39 PM
