Old 11-26-2007, 08:17 PM   #1
hwtan
Member#: 160607
Default what can be the estimated max output?
from a stock ECU reflash?
hwtan is offline   Reply With Quote
Old 11-26-2007, 11:47 PM   #2
reddoak
Member#: 147628
2014 Fiat Abarth 500
Rosso
+75 WHP
+100 WTq
Easily.
Max output of what? Measured how? On what vehicle?
C'mon dude, give us a little to work with here.
reddoak is offline   Reply With Quote
Old 11-27-2007, 08:01 AM   #3
Tgui
Member#: 44771
+5 V
Tgui is offline   Reply With Quote
Old 11-27-2007, 01:56 PM   #4
testes1010
Member#: 47145
2012 Gas Saver
Originally Posted by Tgui View Post
+5 V
+1...almost there with meth
testes1010 is offline   Reply With Quote
Old 11-27-2007, 04:15 PM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
You won't get that much from an STI. The WRX, Legacy, and FXT offer more tuning potential from just tuning alone. Based purely on MAF readings it's about 10% for an STI and 15% for the others, but you can get 15% and 20% if you tune very carefully and aggressively.
5V is a function the tube size, and MAF scaling. I'd say MAF voltage is pretty relative.
Old 11-27-2007, 07:11 PM   #6
hwtan
Member#: 160607
sorry guys, it's 06 wrx.
Old 11-27-2007, 07:40 PM   #7
testes1010
Member#: 47145
2012 Gas Saver
'MAF scaling' does not change the MAFv, but you are correct is pretty relative, at least to that particular car.
MAF housing design & size are the main things that will change the MAFv, even large changes in temperature doesn't change the MAFv very much, some but not much.
Old 11-27-2007, 07:46 PM   #8
Airboy
Member#: 72829
2006 WRX
2015 WRX
I am pretty Tgui was not talking about the MAF sensor output voltage.
Airboy is online now   Reply With Quote
Old 11-27-2007, 07:49 PM   #9
testes1010
Member#: 47145
2012 Gas Saver
, I got it now.....
What can be removed from the engine bay Darcros Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 11-24-2009 03:29 AM
What can be done if someone waves a gun at you on the freeway? brucelee Off-Topic 32 06-22-2007 09:11 PM
what can be done to the 2.5i legacy dlowman Legacy Forum 6 01-24-2005 12:13 AM
Can be the older DCCD-A be upgraded with the new yaw sensor? tharoka Transmission (AT/MT) & Driveline 1 11-05-2004 10:15 AM
what can be the problem. hesitation at 4k and a lot of popping. AzNStiImpreza Normally Aspirated Powertrain 14 10-17-2003 08:53 PM
