11-26-2007, 08:45 PM | #1 |
Member#: 102475
HIIC
Vehicle:2001 impreza RS-T white |
2001 impreza 2.5RS sedan what class
right now i'm in EM i just wanna know if i'm in the right class
here are my mods Interior: Blitz turbo timer Optimal Redtop Battery Kartboy short shifter Triple gauge pod (60mm) Innovate XD-1 gauge Apex EL boost gauge Apex EL EGT gauge Apex EL fuel press gauge LED alarm lights Exterior: Sti version 6 grill Sti rear red and clear taillights Sti rear lip molded to the bumper Sti rear aeroguards guard molded to the bumper Sti Clear side marker lights Clear front turn signals Carbon fiber hood Rear high coupe wing Piaa crystal ion fog light bulbs Piaa yellow corner lights Halo 6000k HID H4 headlights Front lightweight bumper beam Rear lightweight bumper beam 35% charcoal tint True Grey Side moldings removed, spot welded and body worked Antenna shaved off Engine: Ludespeed Stage 2 turbo kit T3/T4 turbo Tial wastegate Greddy E-manage Ultimate EMS Innovate wideband HKS SSQS BOV Deatschwerks 550cc Injectors Walbro 255 fuel pump V6 STI RA gear set for the n/a tranny cyro treated Hyper voltage meter and grounding kit type -mr NGK spark plugs Spearco intercooler 2-inch up-pipe 2 1/2 inch down-pipe Greddy oil catch can Blitz nur spec touring exhaust full system Exedy stage 1 clutch w/act street disc Fidanza 11lbs flywheel Borla headers with thermal wrapping Prestige alarm with kill switch installed AMS Tune Suspension: Ohlin adjustable coilovers Whiteline front strut bar Drill and slotted front rotors Cusco rear crossmember brace Cusco rear 24mm sway bar Perrin P.S.R.S. Anti-lift kit 5-Zigen Fireball 17 inch rims (painted gunmetal) Falken Azenis RT-615 225/45/17 Gorilla lug locks Techna-fit SS brake lines Techna-fit SS clutch line ATE super blue brake/clutch fluid In Car Electronics: Alpine fully motorized screen and DVD player 5.5-inch screens on both front sun visors Rockford highs Rockford mids Rockford crossovers JL 2 10w0's Kenwood 800watt amp
11-27-2007, 07:23 AM | #2 |
Guest
Member#:
The Perrin P.S.R.S. Anti-lift kit puts you in FP.
Otherwise your car appears to conform to SM rules....the big question is.. what intercooler are you using? |
11-27-2007, 01:03 PM | #3 |
Merci Buckets
Moderator Member#: 88606
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
Rear cross member brace is SM legal too? Otherwise, its up to the intercooler and whether or not the bumper beam was modified to fit it.
FP or EM...doesn't really matter at this point because the added weight of the stereo equipment already means its not going to be a national level car. Though I think you are supposed to have an external battery cut-off switch in Mod (except SM) and Prepared classes. |
11-27-2007, 01:53 PM | #4 |
Guest
Member#:
If the cross member brace only attaches in two points, its ST* legal...so its *SP and SM legal too.
If its more than two points of attachment...FP/EM. |
11-27-2007, 02:57 PM | #5 |
Member#: 27446
TXIC
If you're going to race locally I would just go into SM. At the local level I don't think anyone is going to be picky and with 225 tires you're probobly not going to be setting any FTDs.
11-27-2007, 04:23 PM | #6 |
Member#: 102475
HIIC
i have a Spearco intercooler TMIC. my cross member brace is held on by 2bolts on each side. also my speaker box i remove every race along with my spare tire and jacks
FS: 2001 Impreza 2.5RS Sedan BRP 117k Miles | boston_errol | NESIC Private Classifieds | 4 | 10-31-2009 01:38 PM |
FS MA: 2001 Impreza 2.5RS Sedan BRP 117k Miles | boston_errol | Private Vehicle 'For Sale' Classifieds | 5 | 10-31-2009 01:37 PM |
FS: 2001 Impreza 2.5RS Sedan | dmitts | Private Vehicle 'For Sale' Classifieds | 6 | 07-12-2008 05:53 PM |
FS: 2001 Impreza 2.5RS Sedan 5sp manual. Original Owner. Stock 80k | Greg - LI | Private Vehicle 'For Sale' Classifieds | 38 | 04-23-2007 12:01 AM |
FS: 2001 Impreza 2.5RS BRP GC8 Sedan *testing waters* | Notyab | Private Vehicle 'For Sale' Classifieds | 23 | 06-25-2005 09:55 PM |
