Old 11-27-2007, 01:34 AM   #1
scraggy
Member#: 136384
06 WRX
Dipped with custom blend
Default Cleaned MAF....all hell broke loose...
As the title says, all hell broke loose. At first the car wouldnt start, then when it did, it was adding fuel like crazy. I had to rework my latencies and scalar.
Thing is, I didnt think the MAF was that dirty at all, but I have never cleaned it before. I thought I was, but it turned out I was cleaning the intake temp sensor I guess.
Anyway, I took about an hour to get things figured out, but I still have a little more work to do. My original scalar was around 880 (modded injectors) and the latency at 14v was 1.04 I think. With that setup, after the cleaning, it was maxing out the a/f correction, adding as much fuel as it could. A/F at idle was like 18:1 on my wideband.
Now the scalar is at 780( I think I need to go to 800) and the latencies are much higher at 1.14 at 14v. I am going to play with it more tomorrow. A/F at idle is 14.5 ish and is running good at cruise. Idle correction learned is at +-.78 and it stays around that area. At cruise, it is taking out fuel at about 4-5% so I will deal with that next.
Anyone seen this happen this drastically before? I thought I messed up the maf when I cleaned it, but my wideband is corresponding with all the changes the ecu makes. Also, the factory o2 sensor is telling the same story. I guess I was tuning with a dirty maf the whole time.
Input if you got something.
Thanks
scraggy is offline   Reply With Quote
Old 11-27-2007, 01:57 AM   #2
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
you might try getting a new MAF sensor, I'v read "cleaning" those is BADDD
a6n6d6y is offline   Reply With Quote
Old 11-27-2007, 02:57 AM   #3
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
you can definitely clean them, but i havent heard of them making such huge changes. it is possible to damage them when cleaning them so that might be a possibility.
how did you clean it?
TROLL is online now   Reply With Quote
Old 11-27-2007, 07:28 AM   #4
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
you CAN and SHOULD clean them with NON chlorinated brake cleaner.
AWDWRXLOVER is offline   Reply With Quote
Old 11-27-2007, 07:37 AM   #5
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
and +1 for non-chlorinated brakleen.
SBW is offline   Reply With Quote
Old 11-27-2007, 07:50 AM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
+1 for the above mentioned
Old 11-27-2007, 08:49 AM   #7
scraggy
Member#: 136384
06 WRX
All I used was a q-tip. I didn't have any of the correct cleaner at the house when I decided to do it.
I don't think I damaged it because the maf voltage seems to be normal, but I will try it out with a known working one first chance I get.
Old 11-27-2007, 10:42 AM   #8
SBW
Member#: 38469
07 LGT spec-b
yea, that might not have done much, you're probably alright though and didnt damage it.
Get a large plastic bag, some of the brakleen mentioned above. Fill it up, put your MAF in there, swish it around for a while, let it dry and then try it. You're right though, it probably does need to be cleaned.
Old 11-27-2007, 10:47 AM   #9
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
Theres electronic cleaner and MAF cleaner that may be your best bet
xrocket21 is offline   Reply With Quote
Old 11-27-2007, 10:59 AM   #10
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
You didn't put it in backwards, did you.?
wrxdrvr is offline   Reply With Quote
Old 11-27-2007, 01:10 PM   #11
quazimoto
Member#: 70395
CRC makes a MAF specific cleaner.Found at most autostores.I hope you kept a copy of your original tune.
quazimoto is offline   Reply With Quote
Old 11-27-2007, 01:15 PM   #12
scraggy
Member#: 136384
06 WRX
I used to have some around here somewhere, must have used it all. Car is running real good, a/f targets are still a off on the rich side, so I can raise the scalar to 800cc I think. Otherwise, using the spreadsheets, the latency looks pretty good, not quite a horizontal line, but close enough for gubment work.
I think if I had damaged it, the maf would be all wacky and I wouldnt get it to idle at all, much less hit expected targets.
Old 11-27-2007, 04:24 PM   #13
bboy
Member#: 56468
04 Improved STI
Dirty White
Check the air temp reading (log data). If you broke the sensor it will read very cold.
Old 11-27-2007, 05:10 PM   #14
scraggy
Member#: 136384
06 WRX
Didn't think of that, will do!
Old 11-27-2007, 09:05 PM   #15
scraggy
Member#: 136384
06 WRX
I think the MAF is working fine, IAT is good and things are reading like they should and a/f is good now.
Old 11-27-2007, 09:32 PM   #16
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
nothin like being wrong...
http://www.amazon.com/CRC-Mass-Flow-.../dp/B000EGH57G
Old 12-02-2007, 12:45 PM   #17
riderz
Member#: 148896
This happened to me before, one of the things that causes the problem is cleaning the maf when you just pulled it out from a hot engine bay. The temp readings go out of sync and when the car is already warm the maf sensor may be cold from the solution you used to clean it.
Its advisable to clean the maf when the car is clean. Also dont clean it to regular as not all the liquid will evaporate from the sensor. This can cause small corrosion under hot enviornments.
riderz is offline   Reply With Quote
Old 12-02-2007, 01:03 PM   #18
scraggy
Member#: 136384
06 WRX
In this particular case, I didn't use any cleaning solution and the car was cool by the time I restarted the car again. I don't think the MAF had ever been cleaned correctly before and I had always wondered why my settings were so different from others when it came to scalar and latencies. Now, they are very simular.
Old 12-02-2007, 02:06 PM   #19
riderz
Member#: 148896
Great job man!!!
Old 12-02-2007, 03:38 PM   #20
Chino Bling
Member#: 129743
2009 335i
Jet Black
this is what it looks like
Chino Bling is offline   Reply With Quote
Wait, all hell breaking loose in Iran again? SQ3.0dotJP Political Playground 49 12-31-2009 02:35 AM
2001 Subaru 2.5RS 145K-4EAT-4 Door-Clean Titled-Clean Car All Stock: $4000 Audioexcels NWIC Private Classifieds 0 05-29-2009 08:45 PM
If ALL HELL brokes loose on earth, all out chaos and war... brucelee Off-Topic 97 02-28-2008 12:54 PM
Hmmm 5:13pm on a Wednesday. Time to make the cleaning lady's afternoon hell. Asinine Off-Topic 12 05-10-2006 05:47 PM
