Old 11-27-2007, 10:11 AM   #1
ej205gga
Member#: 39249
-1 Impreza
EA71,EJ222,EJ205
Default Suggestion for '08 STI Wheels
I am considering the BBS wheels option for the new STI, and want to check if there is a better alternative.
Which wheels do you recommend for the '08 STI that are:
1. lighter; and
2. diameter and width identical to the stock wheels, offset must be within +/- 0.25in (per SCCA A Stock rule); and
3. cheaper (i.e. <$500 each); and
4. available in the US.
ej205gga is offline   Reply With Quote
Old 11-27-2007, 10:22 AM   #2
Td5turbo
Member#: 126410
02 WRX Wagon
Why not use stock wheels?
they are:
1. Light & strong (forged)
2. obviously stock sizes haha
3. free
so basically you just want a lighter wheels?
Td5turbo is offline   Reply With Quote
Old 11-27-2007, 10:43 AM   #3
ej205gga
Member#: 39249
-1 Impreza
EA71,EJ222,EJ205
Stock forged wheels are not free. I want to see if there is a better place to spend $2500.
Yes, I don't want the wheels to be heavier than the BBS option.
The options are:
1. aftermarket wheels for summer + stock cast wheels for winter. (Cost: $X for the wheels + $0); or
2. stock forged wheels + aftermarket wheels for winter. (BBS wheels is a $2000 option + $500 for winter wheels = $2500)
BTW: does anyone know the weight of the cast and forged wheels for the '08 STI?
Old 11-27-2007, 03:44 PM   #4
dedgley
Member#: 80631
2016 WRX Premium 6MT
Ice Silver
If you don't need 18", what about a set of 05-07 STi BBS?
dedgley is offline   Reply With Quote
Old 11-27-2007, 04:03 PM   #5
waktasz
Member#: 86356
2015 s1000r
wheelie monster
TR Motorsports mt1 I think they are called. They are decently light and fairly cheap. I'd probably pick those for A-stock autocross if I do end up getting an 08 STI.
waktasz is offline   Reply With Quote
Old 12-03-2007, 10:05 PM   #6
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
until someone publishes the actual weight of the 08 BBS wheels, you're wasting your time trying to choose something "lighter". Subaru says the BBS's are 7 lbs lighter. Not clear if this is per wheel or per car. Per wheel would be horrible news since that would put the new std wheels at 24+ lbs. Someone needs to weigh the new rims.
...or, why <$500? Most anything is under 500. You can even get Volks for close to 5, so you might as well plan on getting CE28N's or something else absurdly light. Why not challenge yourself: less than 17 lbs/rim and less than $250/rim?
Frank
Frank A is offline   Reply With Quote
Old 12-04-2007, 04:43 AM   #7
bcarm
Member#: 100068
2010 Outback
Frank
I agree, although I did read somewhere, and I'll see if I can find that, that the weight savings is per corner on the BBS. Also need to know for sure what the stock offset of the 08 STi wheels are.
bcarm is offline   Reply With Quote
Old 12-04-2007, 07:20 AM   #8
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I'd get the regular wheels, keep them for the winter, and then buy a nice set of 18's. There are so many options out there, you'll probably find something you like better, are lighter, and cost about the same as the BBS option.
Old 12-04-2007, 07:39 AM   #9
bcarm
Member#: 100068
2010 Outback
Thats the plan.
Old 12-04-2007, 08:09 AM   #10
911-3.2
Member#: 71421
2005 Sold - WRX
Salty Gray Metallic
Anyone know if 17's are going to fit over the brakes?
911-3.2 is offline   Reply With Quote
Old 12-04-2007, 08:18 AM   #11
mav1c
Hoodbridge!
Member#: 560
I would bet they're the same brakes as the current STI, so I would also bet the current STI wheels, and any other 17's that fit over the current STI brembos, would fit.
Old 12-04-2007, 09:57 AM   #12
911-3.2
Member#: 71421
2005 Sold - WRX
Salty Gray Metallic
I'm hoping so, I need all the sidewall I can get
Old 12-04-2007, 08:11 PM   #13
remowgn
Member#: 41149
09 FXT
SSM
They are an option in Japan, so I would assume so. There is nothing to indicate any differences in brakes, so 17's should be no problem.
remowgn is offline   Reply With Quote
Old 12-04-2007, 10:43 PM   #14
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I get the impression something has changed about the braking since the '04 sti because all anyone ever did was b*tch about the Sti, especially compared to the Evo. Since I haven't owned all the Sti years, maybe someone else could explain what changed and when? Certainly the latest smattering of 08 sti reviews have been very positive on the braking on the new car. Maybe they just tweaked how the proportioning works? I doubt it's a change in the pads or there wouldn't have been so much b*tching.
If the weight difference is per wheel, there is no f'ing way I'm using the stock wheels on mine. Immediate sale on ebay and at least buy Enkei RPF1's for 250/ea and weight that's probably within 2 lbs of the BBS's.
Frank
Old 12-05-2007, 03:06 AM   #15
Imprezard
Member#: 3016
CBA GH8
WR Blue
Both STI wheels (5 spoke and 18 spoke) are forged. Offset 55mm.
Imprezard is offline   Reply With Quote
Old 12-05-2007, 09:30 AM   #16
waktasz
Member#: 86356
2015 s1000r
wheelie monster
If you don't mind me asking, can you site your source? All STI wheels have been +53 to date, am I right? This would throw a monkey wrench in my A-stock autocross plans. (replacement wheels must be within 6mm of stock offset, so the +48 wheels that are plentiful aren't technically legal)
Old 12-05-2007, 09:54 AM   #17
mav1c
Hoodbridge!
Member#: 560
Ummmm...53-48=5, so why would a +48 wheel not be legal?
Old 12-05-2007, 10:01 AM   #18
bcarm
Member#: 100068
2010 Outback
55-48=7
Old 12-05-2007, 12:03 PM   #19
remowgn
Member#: 41149
09 FXT
SSM
Oops.. I should have been more clear. I believe the brakes are different from the GD chassis cars, but what I meant to say is that there isn't a difference between the JDM 08 STI and USDM 08 STI when it comes to brakes.
Frank
That's what I'm saying. I think the 5-spoke wheels would look pretty damn sexy on a legacy.
Old 12-05-2007, 01:31 PM   #20
Imprezard
Member#: 3016
CBA GH8
WR Blue
I have the Japanese STI brochure in my hand. And I read Japanese.
08 WRX/S-GT uses 55 as well.
Old 12-05-2007, 01:33 PM   #21
waktasz
Member#: 86356
2015 s1000r
wheelie monster
The WRXs have always been +55, but this is a change for the STI. Thanks
Old 12-06-2007, 09:00 PM   #22
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
To answer my own question, here's what the motivemag review says about the brakes:
The brakes are certainly the best ever fitted to a road-legal Subaru, and not just because of the impressive Brembo hardware peeking through the wheel spokes. Good brakes not only stop short, they also "talk" to the driver, an area where a Subaru's middle pedal has traditionally been a letdown. The 2008 STI uses a new brake booster with a double pushrod to eliminate deflection in the linkage, giving a more connected feel, and the flexible brake lines are made of an ultra-low-expansion material for firmer pedal response.
So I wonder if the new brake lines are as good as the aftermarket ones so that I won't have to replace them anyway?
Frank
Old 12-07-2007, 07:48 PM   #23
kdjstratton
Member#: 144681
2007 Outback 2.5i
1996 Acura Integra RS
I'm doing the same thing. I'll buy the base model with the heavy 5-spokes and put some all season tires on them. Preordered today!
kdjstratton is offline   Reply With Quote
Old 12-07-2007, 09:12 PM   #24
skydes
Member#: 141347
2005 WRX
My recommendation: If the offset is the same or compatible, buy a set of mint 05-07 BBS 17'' takeoffs with some nice rubber on 'em right NOW.
skydes is offline   Reply With Quote
HKS twin power ignition for WRX/STI now $300.00!! Blue06STI Engine/Power/Exhaust 37 07-05-2010 08:43 PM
FS : Thread Moved. Swifty Cactus Wheels/Tires 16 06-20-2010 04:29 AM
5X100 wheels needed for photos EJ20(GDB) VIC Private Classifieds 9 06-06-2010 12:55 AM
need suggestions on springs for KYB G2's deftonez99 Brakes, Steering & Suspension 3 06-05-2010 11:21 PM
Need wiring diagram for 04 sti ocv solenoid sti3573 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-03-2010 04:59 PM
