Old 11-27-2007, 03:22 PM   #1
Rizen
Member#: 157002
2011 STI
Satin White Pearl
Default Slight boost creep, not enough to hit fuel cut, should I be concerned?
I just put my ProSport boost gauge in the car and I was hitting around 17psi on my stage2 06 WRX. The Cobb stage 2 map is set for 15.2psi, variance is 0.7psi, and fuel cut is 17.9 psi.
I had a slightly tweaked version of the Cobb map that had adjusted waste gate duty cycles and a lowered fuel cut (we set it to 17.09 psi) and I was hitting fuel cut in 4th/5th gear with that map, so we put the unchanged Cobb stage 2 map back on and I haven't hit fuel cut since then.
I'm going to do a log soon to verify the gauge is accurate, but assuming it is, how concerned should I be about this? I don't drive the car like an idiot and rarely drive hard enough in 4th or 5th gear to hit 17psi. And it doesn't creep past 17-17.5, I had it up to 110mph in 4th and it didn't go any further. I'm planning on getting it protuned eventually, just wondering how I should handle this until then.
Rizen is online now   Reply With Quote
Old 11-27-2007, 03:30 PM   #2
urabus2005
Member#: 164409
2005 legacy gt limt
Agile tunned 19psi
well, in my 05 legacy i am getting up 2 21 psi on cobb stage 2.( dont ask me how). My car hasnt broken (yet) but i am schedualed for a protune next week. I would recomend 2 just get a protune, everycar is diferent and need there own tune.
urabus2005 is offline   Reply With Quote
Old 11-27-2007, 03:38 PM   #3
Rizen
Member#: 157002
2011 STI
Satin White Pearl
Do 05 Legacies have a TD04? That's wayyy high haha. I see people running TD04s at 18-19 psi on protunes or custom self-tuned maps, but Cobb Stage 2 is set for around 15.
Old 11-27-2007, 03:44 PM   #4
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
I believe the 05+ turbo'd legacies have run VF40's.
wrxfactor is offline   Reply With Quote
Old 11-27-2007, 03:58 PM   #5
Rizen
Member#: 157002
2011 STI
Satin White Pearl
Ah.
Okay then.
The Cobb Stage2 Legacy GT map calls for 16.5psi, so sounds like he has worse problems than me either way haha.
Old 11-27-2007, 04:43 PM   #6
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Pro(or any other)tune will not get rid of creep.
wcbjr is offline   Reply With Quote
Old 11-27-2007, 05:17 PM   #7
wage0052
Member#: 127556
2006 WRX
RomRaided.
True, but there is no way he's getting creep with his car.
Sounds like the WGDC's where too aggressive on one of those Cobb maps, and you where spiking a bit. Get a protune.
wage0052 is offline   Reply With Quote
Old 11-28-2007, 11:00 AM   #8
EJ20_lee
Member#: 106799
2004 built 257 tomei
powered ^.^
Originally Posted by Rizen View Post
Ah.
Okay then.
haha funny....
EJ20_lee is offline   Reply With Quote
Old 11-28-2007, 11:22 AM   #9
Rizen
Member#: 157002
2011 STI
Satin White Pearl
Originally Posted by EJ20_lee View Post
haha funny....
http://www.accessecu.com/accessport/...3%20MTv116.pdf
Are you reading something I'm not?
Slight Spring Rub, Should I be concerned? WebMasterP Brakes, Steering & Suspension 12 03-17-2008 08:28 AM
Hit fuel cut today, creeping badly. Boostfiend04STI Engine Management & Tuning 1 07-10-2005 11:33 AM
Wanting to buy a 98 Outback, should I be concerned about HG probs? erichollins Outback Forum 1 06-20-2005 12:51 AM
Hit fuel cut... should I raise it? WolfDrive Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 06-06-2005 12:57 PM
Hitting Fuel Cut and Boost cut at 18 PSi HELP!! ChrisV-FL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-11-2002 10:36 AM
