Old 11-27-2007, 11:59 PM   #1
wrx03.4wz
Member#: 122375
03.7 I own 2 of them
White & Black
Default 03 to 06 front end swap info please
i wanted a bugeye and i got one, i have a 04 STi rear end conversion already. its time to start over with a new engine and new look, anyway the point is i want to do a 06 front end swap but i want to know ALL the parts i would need to do this, if anyone know or has done it already PLEASE shoot me some info, i would greatly appriciate it a lot.
Kai
wrx03.4wz is offline   Reply With Quote
Old 11-28-2007, 09:29 PM   #2
wrx03.4wz
Member#: 122375
White & Black
bump
Old 11-28-2007, 09:38 PM   #3
snowcrzy
Member#: 110895
You need the headlights, bumper, bumper beam, grille fenders, hood, and the front radiator support/headlight surround bar. The only thing that is at all tricky is the bar in the front, that needs to be salvaged from the year that you want to do the conversion. It needs to be welded to the rest of the frame. Everything is bolt on from there except the wiring for the headlights and maybe fog lights.
I did an 04/05 conversion and fully custom fabricated the front bar and I will never do it again. It was such a bitch.
snowcrzy is offline   Reply With Quote
Old 11-29-2007, 11:09 PM   #4
1VIPWRX
Member#: 107554
yellow
i did a 02 to 2007..its pretty easy. all i used was subaru parts, u gota drill out the weld spots and stuff. chargespeed also makes a kit.
1VIPWRX is offline   Reply With Quote
Old 11-30-2007, 12:13 AM   #5
wrx03.4wz
Member#: 122375
White & Black
did you have to weld anything back together? some say yes others say no.
Old 11-30-2007, 01:29 PM   #6
scrape
Member#: 163720
2001 Legacy Outback
wouldnt the radiator support have to be welded in?
scrape is offline   Reply With Quote
Old 12-01-2007, 12:02 PM   #7
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
Yes, that it the way it was designed initially. I have an 04 and I am considering going bugeye. The radiator support is really a flimsy piece of sheet metal which is tack welded to the front end. The piece that needs to be changed for year to year headlight differences is not even a complete radiator support from what I see. What I mean is that the lower supporting part that holds the radiator up remains the same.
I have not really reached a conclusion as to whether the tack welding is really necessary versus another type of attachment. I can do either.
Welding in some cases is superior for structural integrity and ultimate strength. For manufacturers it is sometimes an effective cost cutting measure.
It costs alot less to tack weld this part on then to make reinforcement taps and attachment bosses and then hardware to be able to unbolt this part to change from year to year. They do not look at it like that.
Good luck with your project!
nottofast is offline   Reply With Quote
Old 12-02-2007, 10:35 PM   #8
1VIPWRX
Member#: 107554
yellow
you dont have to. i used decent size bolts but u can weld it on if you want. i
drilled out the weld spots and just installed the 06 upper rad support
Old 12-04-2007, 03:17 PM   #9
chinoWRXL
Member#: 89123
02 WdBody STi Wgn
03 L
Also you will need front quarter panels.
chinoWRXL is offline   Reply With Quote
Old 12-04-2007, 11:57 PM   #10
turbotomas
Member#: 84710
05 sti
im going to order the radiator support from subaru and prob do the install the parts the weekend they come in. ill do a pic by pic how to if its not too cold. ill prob stop by lightwerks for some hids and harness. I have all the parts except the hood. and hopefull pick up limited interior at the end of the month. that would be it till spring.
turbotomas is offline   Reply With Quote
Old 12-05-2007, 08:18 PM   #11
wrx03.4wz
Member#: 122375
White & Black
what all did you buy so i can get started on mine if you dont minf me asking.
Old 12-07-2007, 09:52 AM   #12
turbotomas
Member#: 84710
05 sti
ok this is my list:
hood,fenders,bumper.headlights, headlight housing and radiator support.
i think if i have time on sun ill start drillin its suppusto be mid 40's out compared to the teens we have been gettin im thinkin of rockin a t-shirt. lol
Old 12-09-2007, 10:13 PM   #13
wrx03.4wz
Member#: 122375
White & Black
bumped
Old 12-12-2007, 11:06 AM   #14
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
ekw is offline   Reply With Quote
Old 12-22-2007, 01:48 AM   #15
wrx03.4wz
Member#: 122375
White & Black
get in a car accident im good car's f'd up though the bodyshop will take car of the swap for me i will post pics as soon as its done
Old 12-22-2007, 02:22 AM   #16
turbotomas
Member#: 84710
05 sti
im going to start on the front end on sun. if you can get me any info ill need lmk. i started dismantling the front end all ready and now working on the rad support on sun.
Old 01-08-2008, 04:28 PM   #17
turbotomas
Member#: 84710
05 sti
with the awesome weather i drilled out the sopt welds. im pickin up a hood, fender and radiator support next week. ill post pics and keep you inflrmed on the process. most likely tomorrow before the cold weather comes through again.
02/03 to 04 front end swap wrxxxrated Interior & Exterior Modification 24 07-24-2012 09:31 PM
Front end swap info- if youve done it or have front end knowledge, please read! DWUsSubaru Interior & Exterior Modification 2 10-16-2009 02:42 PM
04 to 06 Front End Swap pilotstephen Interior & Exterior Modification 5 08-13-2007 07:47 PM
02 to 06 front end swap and wiring question MGAMAN Subaru Conversions 30 07-02-2007 11:21 AM
03 to 04 front end swap question bdicustoms Interior & Exterior Modification 9 08-12-2005 01:10 PM
