Old 11-28-2007, 12:29 AM   #1
superfast_wrx
Member#: 144852
2002 impreza wrx
MBP
Default meth? nitrous? both? need advice
HEy guys i am new to the meth and i have a quick question i have a 02 wrx with intake exhaust cobb ap ver2 and a fmic with a nitrous intercooler spryer set up i was wondering if it would be better to go to meth injection or stay nitrous or even both? just need some advice thanks.
superfast_wrx is offline   Reply With Quote
Old 11-28-2007, 11:15 AM   #2
superfast_wrx
Member#: 144852
2002 impreza wrx
MBP
bump.
Old 11-28-2007, 12:04 PM   #3
anickode
Member#: 141633
2002 WRX Wagon
Shiny new silver!!!
I had this crazy idea a while back to set up a wet nitrous system that injects nitrous and methanol instead of nitrous and gas... couldnt afford to do anything with it though. If you're interested in experimenting with that, I'll help out.
anickode is offline   Reply With Quote
Old 11-28-2007, 04:16 PM   #4
superfast_wrx
Member#: 144852
2002 impreza wrx
MBP
either that or have a nitrous intercooler sprayer and meth injection
Old 11-28-2007, 04:18 PM   #5
anickode
Member#: 141633
2002 WRX Wagon
Shiny new silver!!!
If you're gonna have a nitrous system on your car, you might as well spray it into the intake, that way you get both the cooling AND the oxidizing effects of it. Use the Meth on top of that, and I think you've got a winning combination
Old 11-29-2007, 06:06 AM   #6
MattPersman
Member#: 139385
only downside I see of the nitrous is the cost to keep filling that magic bottle
MattPersman is offline   Reply With Quote
Old 11-29-2007, 07:25 AM   #7
anickode
Member#: 141633
2002 WRX Wagon
Shiny new silver!!!
ahh, but on the plus side of nitrous, you don't have to use it all the time. It's there when you want it
Old 11-29-2007, 12:17 PM   #8
AIS
Vendor
Member#: 153108
Water methanol injection is particularly important with you running a shot of nitrous. This will help stabilize the combustion process slowing down the flame propagation when both on and off nitrous helping to reduce detonation and keeping the tops of your pistons and upper rings cooler.
When you inject water/alcohol the alcohol portion provides instant cooling (as it quickly evaporates), added fuel, increased octane (when used with pump gas) and burns as part of the combustion process while reducing combustion temperatures and EGT‘s. It should be noted that alcohol has a much lower latent heat of vaporization then water therefore it begins to evaporate instantly when injected into a hot air charge.
Water on the other hand has a very high latent heat of vaporization.
Definition of Latent Heat Of Vaporization: “latent heat” is the amount of energy in the form of heat released or absorbed by a substance during a change of phase. (i.e. solid, liquid, or gas), - also called a phase transition.
The energy (heat) required to turn water into a steam (to begin evaporating) is substantially higher then that of alcohol. When atomized properly water alone works well at cooling air charge temperatures. However, when compared to alcohol, testing has shown water does not have as great of a cooling effect on the air charge temperatures as does alcohol. When water does evaporate it turns to steam. This steam stabilizes and slows the combustion process acting as a anti-detonate (suppressing detonation) essentially making it an effective octane enhancer.
Together, water alcohol injection cools the intake air charge temperatures, reduces combustion chamber temperatures, thus cooling and protecting the top of the pistons and the top ring as well as lowering EGT's and cooling the exhaust valves.
AIS is offline   Reply With Quote
Old 11-30-2007, 06:27 AM   #9
MattPersman
Member#: 139385
but once you use it you want it all the time
my car is set up with meth that way. I can just reflash with AP in seconds, turn off my pump and be on pump.
I need advice. N00bie relationship advice. Pretty Waste Off-Topic 52 07-28-2006 01:13 PM
Where to put my nitrous fogger? Need help from you specialist. Pictures Inside! STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-25-2003 11:31 AM
Nitrous help needed tonight silverscooby South East Region Forum 3 07-03-2003 11:22 PM
11:1 compression and nitrous, need advice. dcoty Normally Aspirated Powertrain 16 12-07-2002 04:44 PM
Want Nitrous Need Advice Xscreamer Normally Aspirated Powertrain 8 02-14-2001 04:01 AM
