Old 11-28-2007, 09:09 AM   #1
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Default FP Green - 2.0L - 360whp on 94 octane
This was a very fun car to tune, although the power band isn't what most people are used to it looks very similiar to something you'd see on a GT35R STI. The 94 octane around here is supposedly closer to 96, and it tunes like it I had a bit of trouble keeping the boost where I wanted it, an uppipe gasket blew out while on the dyno so this car should have more power now than it did on the dyno as the gaskets were replaced afterwards.
Mods that I know of:
Spec C Intake Manifold
GT Spec Exhaust manifold
PE 800 Injectors
FP Green - 2.4" inlet, oil cooled only version
UTEC Speed Density (this car hits 5.0v on the maf)
Some loud exhaust
Greddy FMIC
And here is the graph:
Old 11-28-2007, 09:20 AM   #2
mrcharIybrown
Member#: 143469
2007 WRX STi
holy lag.. nice numbers though
mrcharIybrown is offline   Reply With Quote
Old 11-28-2007, 09:36 AM   #3
98EJ20
Member#: 163184
98 Swapped Impreza
Red
Its not too bad, he's at 200whp at 4500rpm.....My buddies Integra has a GT40 something turbo, boosts at 7K Dumb.....
98EJ20 is offline   Reply With Quote
Old 11-28-2007, 10:06 AM   #4
SW00P_G
Member#: 5591
EJ257 Gt35r
WOW! nice numbers, but you are lagging WAY too much for a green. That up-pipe gasket must have had a massive leak.
SW00P_G is offline   Reply With Quote
Old 11-28-2007, 10:22 AM   #5
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Yeah I believe it did, since earlier logs of this car had full boost almost 800 rpm sooner. I think I need a chance to play with the car again since the gasket fix, make sure boost is where I want it and have him do some more dyno pulls. I'd like to see 380whp out of it before he makes it a 2.5L hybrid.
Old 11-28-2007, 11:39 AM   #6
Sjerzey05sti
Member#: 75309
05 STI
CGM GT35r
yeah it should def. spool alot faster then that. Are you hoping for 380whp on boost alone or with meth/race fuel?
Sjerzey05sti is offline   Reply With Quote
Old 11-28-2007, 11:42 AM   #7
Master2192
Member#: 83254
98 2.5 RS
04 WRX
boost alone, its making 360 with about 22 psi. It should hold 24 psi and the 94 octane is some good juice (So far it tunes like Meth on Stage 2 STIs)
Old 11-28-2007, 04:39 PM   #8
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
Thanks for posting this as i couldnt figure out how to post the dyno graph picture.. Due to the bad up-pipe gasket the turbo was spooling much later than usual.. Fixed the gasket now time for Sean to do a little fine tuning.. And i so would like to see this thing hit 380whp before the hybrid 2.5L setup..Thanks again master2192 for all the awesome tuning..
Since it erased the Graph sean originally posted here it is. Laggy.
wrxwagon253 is offline   Reply With Quote
Old 11-28-2007, 04:47 PM   #9
CatfaceType-R
Member#: 81102
damn...i want this 94(or 96) octane pump
CatfaceType-R is offline   Reply With Quote
Old 11-28-2007, 04:47 PM   #10
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
nice. 380 whp is alot of power out of 2.0 liters. how long do you think this thing will last?
mxpunk is offline   Reply With Quote
Old 11-28-2007, 05:11 PM   #11
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Yeah, considering our 92 octane is barely considered any better than Cali 91 it is kind of nice to have this pump 94 available. It is only available at the Cenex stations and there aren't a lot of them in the area. So far I've been able to lean out STIs to 12:1 afr and run so much timing it scares me without knock.
I am not sure, the 2.0L seems to be more sturdy than some people give it credit for. Friend of mine put 400whp, and IIRC 400wtq through his 2.0L for a short while and all it did was start pushing oil out the heads like crazy. I think he ran it at 350/350 with meth daily before the accident at the track. This motor is still alive, just temporarily at Stage 2 again.
Old 11-28-2007, 05:49 PM   #12
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Tuned this same setup ( NO SD ) in late 03 made 367whp on just pumpgas.. Car still ran as of 2006.. Did another one in 04 that made 405whp on c16 and 350-360 pump.. That motor is still running in another car.
Junior
Junior2JZ is offline   Reply With Quote
Old 11-28-2007, 06:31 PM   #13
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
So OP, are you using a WRX 5 speed with regular gears? PPG gears? STi trans of some sort? Just curious... Didn't see that listed.
Looks like ALOT of power and ALOT of fun.
SilverSurfer04STi is offline   Reply With Quote
Old 11-28-2007, 06:50 PM   #14
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
any pics?
bhhamblin is offline   Reply With Quote
Old 11-28-2007, 06:54 PM   #15
BlueRallyWrx
Member#: 104876
2003 WRX, HEMI Jeep,
DD Honda Accord
Nice #s. What kind of gears, tranny you running?
BlueRallyWrx is offline   Reply With Quote
Old 11-28-2007, 06:59 PM   #16
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Junior
nice. how are those cars driven? im assuming pretty hard..
Old 11-28-2007, 07:04 PM   #17
woodenchopstix
Member#: 159053
2003 WRX Steel Grey
18x9.5 Wheel Bearing Kill
lots of lag up front but nice numbers on a 2.0
woodenchopstix is offline   Reply With Quote
Old 11-28-2007, 07:59 PM   #18
wrxwagon253
Member#: 125620
05 3076R Wagon
Im running a stock 05wrx transmission with stock gears..Not sure how long its gonna last.. And about the lag I had a huge up-pipe leak that was causing me to spool about 800 rpms later..All fixed now..
Old 11-28-2007, 08:00 PM   #19
wrxwagon253
Member#: 125620
05 3076R Wagon
Go you my youtube for a short clip and some vids of my friends cars as well..
Http://Youtube.com/Rodgazinya
Old 11-28-2007, 08:10 PM   #20
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
LOL... I like how you waved bye bye when you started pulling in one of those first runs.
Get ready for lots of street racing angst....
Old 11-28-2007, 08:24 PM   #21
wrxwagon253
Member#: 125620
05 3076R Wagon
Considering the fact that isnt my sti i doubt i will..I drive a wagon..And besides to each his own..If someone wants to do a few freeways pulls so be it..But that is for another thread..You can clearly read on the vids which one is mine..Fpgreen wagon..
Old 11-28-2007, 08:51 PM   #22
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Is this an EJ205 with spec c heads? So no avcs?
garface is offline   Reply With Quote
Old 11-28-2007, 08:54 PM   #23
wrxwagon253
Member#: 125620
05 3076R Wagon
Nope, im running stock wrx heads..I have a tgv'less Spec c intake manifold not the heads..
Old 11-28-2007, 10:33 PM   #24
Sypher
Member#: 106366
2006 WRX
hah I saw your car on youtube before I saw this thread. Car rolls face dude good job to who ever tuned yah!
Sypher is offline   Reply With Quote
Old 11-28-2007, 10:36 PM   #25
Special
Member#: 145585
2002 S202 [email protected]
Yellow
How does it feel on the street?
Special is offline   Reply With Quote
fp green, fmic, supporting mods, on 2.0L size18boarder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 08-27-2009 09:26 PM
FP Green 8cm, EWG.... 500whp on 91 Octane!! Equilibrium Tuning Proven Power Bragging 27 03-05-2008 07:02 PM
wtb fp green 2.4 inlet or fp 20g pyrosyrus Private 'Wanted' Classifieds 3 09-23-2007 03:25 PM
fp green 2.4" inlet on sti dezwrx03 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-08-2006 01:28 PM
is running on 94 octane a problem? milenko11 Newbies & FAQs 3 04-04-2003 02:17 PM
