Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 11-28-2007, 07:32 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Holiday Electronic Special-Apexi-Greddy-HKS-Accesports-STRI-DEFI
Happy Holidays everyone. We have some great specials on all of our electronics and gauges. Dont miss out on some of the best deals anywhere guaranteed to have the best prices anywhere. As a special offer purchase any item on this post and get a pair of Gruppe-S Carbon fiber hood dampers for only $50!
Happy Holidays
Gruppe-S
Apexi AFC Neo
The SAFC NEO marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful SAFC II, the AFC NEO has taken piggy back style fuel control to a new level. The AFC NEO boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data.
$275 Shipped
Apexi AVCR Digital Boost Controller
The AVC-R is a digital boost controller that allows the user to modify the boost pressure level on turbocharged vehicles. While there are many boost controllers on the market, none of the other includes as many features as the AVC-R, period. Despite all of the complex features included the unit, the AVC-R is flexible enough to be used by beginners. Entry level users need only to input a desired boost level and the AVC-R's trademark self learning CPU processor does the rest.
The AVC-R also uses a highly durable, fast action solenoid valve to physically control the boost . The valve movement (Boost Duty Cycle) can also be modified. Raising the duty cycle increases boost response, while lowering the duty cycle will slow boost response. This feature allows boost response adjustment for varying turbo sizes. Since larger turbos take longer to spool up ( bad low end response) the duty cycle should be raised under lower RPM's for better response. The opposite should be done for smaller turbo's ( excellent low - mid range response, but limited top end power.) A'PEXi engineers address this issue by including extra menus for RPM based boost control. Drag racers may want to utilize the Gear based boost control function. Aside from the basic functions above, the AVC-R has a Start Duty Setting (allows the boost to momentarily overshoot according to gear).
The AVC-R also includes a Scramble Boost function which allows the user to momentarily raise or lower the boost level at the push of a button. Raising the boost level is commonly used when an extra burst of power is needed (ex. entering a freeway). This feature can also be used in drag racing. The driver can set the main boost level to a low setting for maximum traction then, once full traction is achieved, the scramble boost can allow the vehicle to boost full power.
The AVC-R displays data in three different modes: Numerical, Analog, and Graph. Numerical Mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. The Analog Mode displays up to two values in an easy to read meter style display. Peak Hold is also included in this function. The Graph Mode offers real time graph plotting with a Ghost map trace feature built in. The graph can replay movement up to 60 seconds.
$375 Shipped
Apexi Super Grounding System
Developed using innovative new concepts, the new A'PEX Super Grounding System stabilizes electrical noise and voltage spikes. The Super Ground System maximizes electrical component efficiency by combining an electrical grounding system with a battery current and voltage stabilization control unit. The control unit features an electrical charging system and electrical noise filter. The double noise filter smoothes turbulent electrical current, providing a stable and consistent voltage flow to all your vehicles electrical devices. The A'PEX Super Grounding System maximizes the efficiency of all factory vehicle electrical systems, allowing smoother engine operation, more efficient electrical component operation, and improved electrical current. The stylish voltage stabilizer box compliments any engine bay with its attractive case design and ominous backlit A'PEX logo.
- Uses a high capacity Double Condenser and Double Noise Filter
- The A'PEX Super Ground System uses a high purity, temperature resistant OFC cable (non-oxidized copper) Copper wire diameter: 0.12mm X 665 utilizes inter-twined wire
$175 Shipped
Greddy V-Manage
The V-Manage, Variable Valve Timing Controller was designed by GReddy engineers to take advantage of some of the modern technology OE Manufactures* are now commonly incorporating into their latest engines. Based on the intuitive controls, datalogging and Maps of the e-manage Ultimate software, a tuner with a laptop computer, can now alter the factory’s ECU control of valve-timing at any RPM and load to optimize power output and fuel economy. However by purchasing GReddy's application specific V-manage Kits, you can simply "plug & play." V-manage Kits, include the V-manage, CD software, Plug-in Harness with adapter, and Pre-programmed MAP to optimise cam timing for increase horsepower, toque, and boost response.
04-06 STI AVCS ENGINES ONLY
$475 Shipped
Greddy Informeters
Designed with a compact plug and play color LCD display, the Informeter allows you to monitor, set warning points and datalog your vehicles performance though it's own On Board Diagnostic sensors. Select through important signals like Speed, Tach, Temps, Air Flow, Voltage, etc. (up to 25 channels depending on application), to monitor. The easy to use navigation menu allows you to select between various screens and displays: Digital, Analog or Bar Graph and 2ch, 3ch, or 6ch screens. You can also set warning points and pre-warning points, which will alert you with audible and visual highlights of important readings. Datalog up to 6 channels of data, and replay them. This is great for tuning. In addition to being functional the Informeter is also infinitely fashionable. Seamless changes in backlighting color, GReddy signature wall papers and colored backgrounds, along with a clear bezel to install colored face plates or even custom face plates, offer a endless options to match any vehicles interior. And to aid in mounting the unit can flip the display 180 degrees to free even more options. The GReddy Informeter is a key tool for all; beginners to pro tuners.
Black & White Available
$270 Shipped
Greddy PRofec Boost Controllers
The ultimate in electronic boost control is incorporated in our multi-tasker, the PRofec e-01. Designed as a combination boost-controller, data display/logger and original e-manage programmer. The e-01 can provide superior boost response, increased boost, warning meter functions, 3 channel data-logging and access to programming features provided with the e-manage support tool. Even when used as a boost controller only, the e-01 has features to smooth out the boost curve. With both an auto and manual setting for both external and actuator style wastegates, the PRofec e-01 can alter its compact, high capacity solenoid valve via various RPM ranges. The large LCD screen with green electro-luminescent backlighting is easy to see. Other standard features include two preset boost levels, a timed over-take boost and compatibility with our Remote Switching System. The data display can view 3 different data channels simultaneously such as boost, RPM or any other channel inputted by the e-manage. The data can be logged up for 3 hours on an SD card while also giving warning set points and peak and hold values. There is also a non-PRofec e-01 version that is only used for e-manage programming and datalogging. (Some features require optional harness to be accessed.)
$515 Shipped
HKS EVC 6 Boost Controller
HKS celebrates the 20th Anniversary of the original Electronic Valve Controller (EVC) with an all-new EVC boost controller model. The original EVC released in 1987 was the first commercially available electronic boost controller, and revolutionized the aftermarket industry. HKS’ 20 years and five EVC generations of boost control knowledge has been harnessed into this all-new EVC.
The new HKS EVC has improved boost stability for maintaining pressure at high RPMs providing increased top-end power, and a new mapping feature allows boost pressure to be precisely tuned for throttle + RPM (or vehicle speed). The new EVC also offers a selectable kPa or PSI unit of measure, and a unique warning feature where if over boosting occurs, boost pressure can be programmed to drop to a user preset level. The new target boost setting and volume knob with three button user interface makes setup and tuning intuitive and simple. The design of the new EVC features a sleek black case with a clear acrylic faceplate and a positive lit LCD display offering a sophisticated look.
$550 Shipped
HKS A/F Knock Amp
The HKS A/F Knock Amp is an electronic monitoring device that displays two of the most vital engine conditions for tuning; engine knock and air/fuel ratio. Engine knock occurs when there is abnormal combustion knock as detonation; which can rob power, reduce engine longevity and even lead to catastrophic failure
$699 Shipped
HKS Circle Earth Grounding System
Circular Grounding System - By utilizing a 24 karat gold plated distribution block and multiple grounding points, improved idle and drivability are often obtained as the additional grounding points equalize resistance and voltage between various ground points. Each 8 gauge spiral twined cable is wrapped with signature HKS purple plastic to protect and add color to the Circle Earth System. Vehicle specific kits included pre-measured cable lengths and distribution blocks.
$115 Shipped
CLICK HERE FOR ELECTRONIC SPECIALS -- UPDATED DAILY
Call in to order!
We accept Visa, Mastercard, and paypal.
[email protected], please specify vehicle, part, and your info.
Thanks,
Gruppe-S Sales
www.gruppe-s.com
20521 Teresita Way
Lake Forest, CA 92630
949-457-1234 x 2
Gruppe-S is offline
Old 11-28-2007, 07:32 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Blitz R-Vit I Color
R-VIT i-Color
R-VIT i-Color is a monitoring multi meter designed for 2003 or later Toyota CAN-bus or vehicles equipped with 1996 or later ISO14230 diagnostics connector. Installation is simple, it is install just by connecting to the vehicle diagnostics coupler. It features a 65,000 Color LCD screen and multi angle display. It can be set on three different angles depending on the location of the installation. R-VIT i-Color monitors a maximum of 29 items and able to display 6 monitored items simultaneously. Monitored items are: Speed, RPM, Water Temp, Ignition Timing, Fuel Injection Time, Air Flow Voltage, Outside Temp, Intake Manifold Pressure, Boost, O2 Voltage, O2 Rear Voltage, AF 1, AF 2, Intake Air Mass , Battery Voltage, Throttle Output, AT Temp, Gear Position, 4WD Ratio, Fuel Pressure, Momentarily Fuel Consumption, Malfunction Diagnosis Code, Lock Up ON ・ OFF, External Voltage Input (Press, A/F Box) / External Temp Input, Fuel Pressure Control, Fuel Injection Control / Electric Fan Control, etc. Depending on the vehicle, the monitored items vary or cannot be monitored.
$315 Shipped
Blitz SBC i-Color
This product's purpose is to control the boost of the turbocharger and improve the output of the engine. A state of the art digital controller for an accurate gain in boost pressure, which controls two highly efficient sequential solenoids, achieves a minimum over shoot on peak boost and a stable boost pressure.
Features of the product
Boost control & power meter function.
An added function, the Result graph, which displays the results of power, torque, boost, and A/F overlapping to each other on one screen. It has a function as al logger according to the RPM to compare a maximum of three channels on the horizontal axis that are power, torque, boost and A/F.
The ultimate boost controller
The known full auto function evolves further in the SBC i-D series. A still more precise control is added to the auto boost setup. In addition to the new full auto function in which the self-learning method can be chosen in three steps, a boost according to the RPM and speed is possible to setup to match on all the stages.
Full color (65.000 colors)
The graphics that the full color display made it possible are; such as displaying from analog to digital meter, graph comparison display and a possibility to produce a variation of back ground images. If the optional TEMP sensor and PRESS sensor are connected, it is also possible to display water temperature or oil temperature and oil pressure. If the optional A/F Box is connected you will be able to display real time A/F ratio.
$625 Shipped
STRI Gauges
Stri DSD warning gauges offer full function, features, and extreme accuracy.Driven by rugged stepper motor, control by advance microprocessor, DSD is the latest technology in precise monitoring device. DSD gauge series is equipped with laboratory grade sending units.
DSD Series Black Dial-White LED/ White Dial-Amber LED
Available in Metric and Imperial
52/60mm Boost $135 Free Shipping
52/60mm Water Temp $105 Free Shipping
52/60mm Oil Temp $105 Free Shipping
52/60mm Oil Press $160 Free Shipping
52/60mm Fuel Press $160 Free Shipping
52/60mm Ext. Temp $139 Free Shipping
52/60mm Tach $95 Free Shipping
52/60mm Volt $95 Free Shipping
52/60mm Intake Pressure $150 Free Shipping
52/60mm Boost 3 Bar $150 Free Shipping
DSD Series Smoked Lens-White LED/ Smoke Lens-Amber LED
52/60mm Boost $140 Free Shipping
52/60mm Water Temp $115 Free Shipping
52/60mm Oil Temp $115 Free Shipping
52/60mm Oil Press $170 Free Shipping
52/60mm Fuel Press $170 Free Shipping
52/60mm Ext. Temp $145 Free Shipping
52/60mm Tach $105 Free Shipping
52/60mm Volt $105 Free Shipping
52/60mm Intake Pressure $160 Free Shipping
52/60mm Boost 3 Bar $160 Free Shipping
WRX/STI STRI Gauge Package
-ATI Triple Gauge Pod
-Boost DSD Smoked
-Water Temp DSD Smoked
-Oil Temp DSD Smoked
$500 Free Shipping
Defi Gauge Combo
The design of this system allows each of the gauges to be attached to the control unit with a single "daisy chain" wiring system. The system eliminates the need for multiple tubing or wiring to each of the gauges.
BF-R 60mm Boost $230 Shipped
BF-R 60mm EGT $255 Shipped
BF-R 60mm Fuel Press $255 Shipped
BF-R 60mm Oil Press $255 Shipped
BF-R 60mm Oil Temp $190 Shipped
BF-R 60mm Water Temp $190 Shipped
WRX/STI Package
-Defi V2 Control Unit
-Boost + EGT + WT or OT
Defi 52/60mm Combo $725 Shipped!
Defi BF 52/60mm Combo $799 Shipped!
Defi BF-R 52/60mm Combo $799 Shipped!
Turbo Timers
All Items In Stock
Apexi Auto Timer Silver/ Black $90 Shipped
Blitz DTT DC2 Silver/ Black $120 Shipped
Greddy Auto Timer Black/ Silver $90 Shipped
HKS Type 1 Black/ Silver $115 Shipped
HKS Type 0 Limited Edition Black $95 Shipped
Gruppe-S is offline
Old 11-28-2007, 11:57 PM   #3
blueribbon
Member Sales Rating: (2)
Member#: 22668
2006 AE86 Levin it
NA1
do you carry the Defi Link display?
If so could you quote me a price shipped to Renton, WA 98056
I need the Defi Link Display with oil pressure, oil temp, water temp,
Mike
blueribbon is offline
Old 11-29-2007, 04:25 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Mike
$110 for the link
$290 for the display
$150 Oil PSI
$75 Oil temp
$75 Water temp
$700 Shipped
Gruppe-S is offline
Old 11-29-2007, 08:40 PM   #5
blueribbon
Member#: 22668
2006 AE86 Levin it
NA1
Another question before I place an order.
- Is the speedo rated in mph or km?
- Is the temp rated in C or F?
Thanks
Mike
Old 11-29-2007, 09:02 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thanks
Mike
All items are rated in metric.
Thanks
Ben
Gruppe-S is offline
Old 12-01-2007, 09:40 AM   #7
Seraphinwolf
Member Sales Rating: (8)
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
On the vManage. Is it the eManage Ulitimate that has extra programming(I know they are preprogrammed just asking) to run the VVT? And if so would it be able to do something simular for the EZ30R set up with the stock ECU. ( I have future plans I"m saving up for. And yes you guys are likely in them. Always great prices) Thanks for any answers
-Gaddis
Seraphinwolf is offline
Old 12-03-2007, 07:42 PM   #8
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
-Gaddis
Gaddis,
The V manage has not been tested with the ez30 and stock ecu I would imagine it would the only obstacle being the wiring mess. I would suggest speaking to Greddy Tech for this one
GReddy, (949) 588-8300
Gruppe-S is offline
Old 12-05-2007, 06:55 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 12-06-2007, 01:25 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 12-07-2007, 02:49 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 12-11-2007, 09:47 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 12-13-2007, 07:50 AM   #13
mykrrrr
Member Sales Rating: (22)
Member#: 733
'16 Fiesta ST
Platinum white metallic
How's the quality of the STRI gauges compared to say a GReddy (I've had those in the past) The deal on the website seems pretty good.
mykrrrr is offline
Old 12-13-2007, 01:43 PM   #14
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
STRI gauges are not bad at all. Kinda hard to compare to Greddy (dont have any personal experience with them) I suggest you search the product reviwe section for peoples experiences.
Thanks
Ben
Gruppe-S is offline
Old 12-18-2007, 03:56 PM   #15
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 12-19-2007, 02:14 PM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 12-20-2007, 06:29 PM   #17
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 12-21-2007, 02:39 PM   #18
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Gruppe-S
Gruppe-S is offline
Old 12-21-2007, 10:39 PM   #19
subaru21
Member#: 122086
03 built 2.5 going
big this time
Do you still have the deals on the avcr boost controller
subaru21 is offline
Old 12-22-2007, 09:54 PM   #20
WizardGandoff
Member#: 36667
04 DrgSmugrXps
Blackwiththablingblingold
Default 2004 sti cluster
WizardGandoff is offline
Old 12-26-2007, 05:22 PM   #21
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Yes they are still available
Originally Posted by WizardGandoff View Post
Gruppe-S is offline
Old 12-27-2007, 01:28 PM   #22
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump Guys
Remeber Sale Ends 12-31-07 at 11:59pm
Gruppe-S is offline
Old 12-28-2007, 03:15 PM   #23
SupraScooby
Member Sales Rating: (34)
Member#: 52123
05 WRB STi
04 AW STi GT30R [RIP]
You have a PM!
SupraScooby is offline
Old 12-29-2007, 05:20 PM   #24
Zinc
Member Sales Rating: (1)
Member#: 10930
2006 STi
Do you have the Defi Oil sandwich adapter?
Zinc is offline
Old 12-31-2007, 10:12 PM   #25
MotorCity
Member Sales Rating: (10)
Member#: 85085
'11 Fiesta
Ole'
Originally Posted by Gruppe-S View Post
Bump Guys
Got my order in at 10pm nothing like procrastinating..
MotorCity is offline
Closed Thread
Gauges Clearance!! Boost, Wideband, EGT, etc - AEM, Defi, Apexi, Greddy, HKS InjectedPerformance Gauges & Electronics 183 07-23-2010 03:49 PM
Apexi | GReddy | HKS | AEM | Innovate | Sun Auto | Blitz | more InjectedPerformance Engine Management 35 04-15-2010 04:14 PM
Gauges!! Clearance Sale - Defi, Apexi, Greddy, HKS InjectedPerformance Interior/Dressup/Audio & Security 184 11-24-2009 10:16 AM
$89 Walbro Kits, AEM, Defi, APS, Tanabe, Koyo, Greddy, HKS, Blitz, Apexi - LOW PRICES InjectedPerformance Engine/Power/Exhaust 199 08-10-2009 05:40 PM
All IN STOCK Electronics! Defi STRI HKS Apexi GReddy Cobb AEM MORE! Z1 Performance Interior/Dressup/Audio & Security 87 09-12-2008 05:16 PM
