Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 11-29-2007, 02:16 AM   #1
sperry7
Member#: 110079
06 WRX
Black on Black
Default My IAM will not move from 1
I've been logging my car and my IAM will not move from 1. I've always had this problem and I'm not sure why. As far as I can tell I am not getting any knock, my knock correction is always right up by 9 at WOT. Never dips below 5 in probably 20 logs over the past few weeks. Anyone know what's up?
Thanks!
sperry7 is offline   Reply With Quote
Old 11-29-2007, 04:25 AM   #2
3barboost
Member#: 73609
2002 wrx
its supposed to be on 1 (100%)
if you reset it it will drop to 0.5 (50%)
I think you thinking in 16bit ecu terms and looking for a 16(100%)
you got a 32 bit ecu and 1 is the best it gets
3barboost is offline   Reply With Quote
Old 11-29-2007, 04:32 AM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
yes, 1 = best for 32bit (04+sti & 06+wrx)
Nuke209 is online now   Reply With Quote
Old 11-29-2007, 12:30 PM   #4
sperry7
Member#: 110079
06 WRX
Black on Black
haha thank you! I am a super newb at this as you can tell haha.
Old 11-29-2007, 12:49 PM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Also 1 for 05+ RS
My RS has IAM=0.368. My ship, she is broke
Old 12-01-2007, 06:45 AM   #6
jose27madrid
Member#: 165621
Another IAM question...I have increased my IAM to 26, due to use of high octane fuel. Do you think is a good idea if no knock is present? Or are other implications that can damage my engine?
jose27madrid is offline   Reply With Quote
Old 12-01-2007, 11:18 AM   #7
nhat
Member#: 140163
03 STi
hellaflunctional
not to be a dick but you have zero information in your profile and you've provided zero information to us about your car...so it's going to be rather difficult to help you.
Old 12-01-2007, 11:28 AM   #8
wage0052
Member#: 127556
2006 WRX
RomRaided.
In addition, IAM maxes at 16 (16 bit ECU), or 1.0 (32 bit ECU). Is 26 a typo?
wage0052 is offline   Reply With Quote
Old 12-01-2007, 11:57 AM   #9
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
IAM can only be as a high as 1 on 32bit ecus or 16 on 16 bit ecus. I think you meant Knock Correction is set to 26...
Without more information it is hard to tell what you are doing. BUT there is such as thing as too much timing, even if you don't get knock it will kill your rod bearings if such a case was present.
What octane fuel are you running by the way?
Old 12-02-2007, 06:10 AM   #10
jose27madrid
Member#: 165621
Sorry about the lack of information.
No. I have change the IAM using enginuity from 16 to 26. Also change wastegate and turbo maps to give 0.69 bar instead of 1.2 bar to put less pressure on fuel.
Here is my log (please, use download as... to prevent explorer exe the file.)
I am using a 2002 JDM STI. My question is if this IAM increase have any other effect more than detonation or misfire.
Old 12-02-2007, 06:21 AM   #11
jose27madrid
Member#: 165621
I am running a home made fuel using methanol, toluene, a bit of heptane and a bit of lubricating motor oil . Also I use to mix it with a little of regular gas, but is difficult to know the octane rating of the mix. Probably 108 or higher.
Old 12-02-2007, 08:35 AM   #12
Tea cups
Member#: 103136
The IAM is dynamic based on knock. You are changing the INITIAL IAM outside the intended range of 0-16, which you should not be doing. What will happen is that after a reset OR when ECU decides to re-evaluate the IAM, it will be set to 26, but the instant that the IAM increases (anytime, even after it drops), it will be immediately capped at 16 until the next re-evaluation or reset. The correct way to tune for race gas would be to modify the base timing and advance maps, not change the initial IAM greater than 16.
Tea cups is offline   Reply With Quote
Old 12-02-2007, 12:41 PM   #13
riderz
Member#: 148896
Thanks!
To start with have you serviced recently. Simply thing like the fuel filter, cleaner injectors, or maf cleaning may stop the problem. If that doesnt work then you can look at the timing issues.
Oh are you getting boost spikes at all? you may not see knock in the logs but you should see some timing being pulled.
Also if you have a wideband post the logs showing ign timing and also your afrs so we could best evaluate the problem.
riderz is offline   Reply With Quote
Old 12-02-2007, 03:48 PM   #14
sperry7
Member#: 110079
06 WRX
Black on Black
Yeah someone answered my problem earlier, I have a 32 bit ecu so the max my IAM can go is 1! I've only logged on an 04 wrx before this so I thought 16 was the highest for my car as well.
I'm not getting any spikes, the boost is progressive and builds up to 21 and then tapers to 16 or so.
My wideband is not working, I can't get the stupid serial to USB cable to work on my laptop. I installed the drivers but it's not recognizing it!
Old 12-03-2007, 01:51 PM   #15
jose27madrid
Member#: 165621
Absolutely right. Every change return it to 16. Not 20, 22, just go to 16. I am going to touch timing maps and try.
Thanks.
Car will not move in any gear WRteXan Transmission (AT/MT) & Driveline 2 01-07-2010 08:46 AM
Help! Car will not move 05subylah Service & Maintenance 8 10-18-2008 03:16 AM
Help me my car will not start!!!!! 4npower Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-01-2003 11:36 AM
My engine will not jack up! codean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-30-2002 05:41 PM
('93-'01) my window will not go down all the way gasser Impreza Forum 9 05-08-2001 08:30 PM
