View Poll Results: Newer or older gc8 chassis better for swap?
Save money on the chassis; there all the same 3 75.00%
Newer chassis are structurally stronger, better 1 25.00%
Voters: 4. You may not vote on this poll
Old 11-29-2007, 07:15 PM   #1
soslow
Member#: 95027
'13 BRZed
pretend racecar
Default Any reason to go with a newer MY chassis for gc8 swap?
Was wondering if there would be any real difference in the different model year gc8 chassis when it came to doing a swap? Is there any difference in torsional stiffness or are the later gc8 chassis superior from a strength standpoint from 93 to 01?
soslow is offline   Reply With Quote
Old 11-29-2007, 10:05 PM   #2
ZZcorollaVV_Ti
Member#: 121869
1994 Impreza L
Green
get a 94 because it isn't obd II.
ZZcorollaVV_Ti is offline   Reply With Quote
Old 11-29-2007, 10:18 PM   #3
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
Word. Then put a 2.2T in that sumnabi...
Arctic Assassian is offline   Reply With Quote
Old 11-30-2007, 03:57 AM   #4
jamal
Member#: 71875
98 Legacy GT
my wheels fit
why would it matter since the swap will require a new ecu and wiring?
I personally would get the newest and straightest chassis I could afford.
jamal is offline   Reply With Quote
Old 11-30-2007, 05:24 AM   #5
ChrisRT
Member#: 125941
200x WRX
High miles plus potholes and train tracks could = a frame that will split in half while you are driving down the road?
ChrisRT is offline   Reply With Quote
Old 11-30-2007, 07:15 AM   #6
soslow
Member#: 95027
'13 BRZed
pretend racecar
Impreza GC8
So a low mileage (less than 50,000) 93 impreza would be just as good as a 2001 with the same miles assuming the 93 is rust free, etc.? I'm asking because obviously the less money I spend on the chassis the quicker I can swap in the fun stuff . I really dont want to spend more than $4000 on the chassis.
Old 11-30-2007, 07:33 AM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
emmission requirements for OBDII cars. Swapped cars usualy cant pass OBDII emmisions
only problem is finding a low mileage older chassis with no rust. Subaru's do rust, and people keep them forever.
Old 11-30-2007, 07:53 AM   #8
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
There's no difference in chassis strength.
A FWD Brighton will be slightly more difficult because some bolt holes (for cowl braces and rear swaybars (??)) aren't drilled and tapped... but will be the cheapest to buy.
In '97 the Imprezas got a new dash, new front bumper cover/headlights, etc. In '99 the headlights were updated again (to glass).... but I'd stick with an OBDI compliant car vs OBDII as others are suggesting... OBDI compliance ended with MY95.
Your other option is an OBDI Legacy. Nearly everything is the same, except they weigh a little bit more and have marginally longer wheelbases (which may mean a driveshaft length issue).
Oh, and THEY'RE
Old 11-30-2007, 09:35 AM   #9
soslow
Member#: 95027
'13 BRZed
pretend racecar
Originally Posted by Beaverboy View Post
Oh, and THEY'RE
GRAMMAR NAZI.. j/k; should have paid more attention, I text to much..
Old 11-30-2007, 05:46 PM   #10
ChrisRT
Member#: 125941
200x WRX
Dude, YOU DO NOT need to spend more then 1k on a chassis. There are PLENTY of 1993-1994 Impreza FWD-AWD available for $500-1200... Don't screw yourself over and take a look on Craigs List.
Old 11-30-2007, 06:42 PM   #11
jamal
Member#: 71875
98 Legacy GT
my wheels fit
My car is registered in a state with no testing so I always forget about that...
But still, if you take an unmodified ODBII driveline and ecu drop it in another ODBII car it should pass, right?
Old 12-01-2007, 12:35 AM   #12
ChrisRT
Member#: 125941
200x WRX
It will pass if it isnt throwing any CELs. I'm probably going to toss my EJ-20 in my OBD2 car and they shouldn't know anything unless they ran VINs and all that great stuff.
Which Resonator to go with? Check out my horrible raspy vid Mike 01Hawk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 03-04-2010 01:10 AM
Any reason to change my spark plugs with only 31k miles? overdose Service & Maintenance 9 05-14-2006 03:34 PM
Another reason why to go with the wagon... alwrxwu Newbies & FAQs 7 10-21-2004 12:20 PM
EJ20 X-member, do I need to go with WRX control arms on my GC8. underground-mpyre Subaru Conversions 8 09-25-2003 12:39 PM
Can anyone here give me a reason NOT to go with 8.5lb wheels? thebusiness999 Brakes, Steering & Suspension 9 07-02-2002 07:48 PM
