Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 11-30-2007, 01:20 AM   #1
iwantmyWRX
Member#: 154286
2006 CGM WRX
Dust Collector
Default VF39 vs. VF43
alright, im assuming that the 43 spools later than the 39, but whats the power difference between there two?
iwantmyWRX is offline   Reply With Quote
Old 11-30-2007, 01:21 AM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
only difference is a ported wastegate and housing that doesn't crack
in other words, the vf43 is the vf39 but built better
Old 11-30-2007, 01:23 AM   #3
howfast?
Member#: 102027
BugI Tsx retro lamps
for sale not listed pm me
i think the 43 is basically a 39 just newer and a little better/stronger. Peoples feel free to correct me if im wrong but i think it uses a lot of the same parts from the 39 just beefed up and a little newer...
howfast? is offline   Reply With Quote
Old 11-30-2007, 01:28 AM   #4
urfsin
Member#: 128975
2005 Outback XT
Golden Thunder
Something about the exhaust housing shape is different IIRC.
urfsin is offline   Reply With Quote
Old 11-30-2007, 01:31 AM   #5
Nuke209
Member#: 108089
2003 WRX
NF Performance
wastegate is a bit bigger to prevent boost creep
they still crack from what i've read
Nuke209 is offline   Reply With Quote
Old 11-30-2007, 01:35 AM   #6
jardine
Member#: 119595
2005 forester xt
aspen white
really there is not to much difference
lets just say a newer harder to find vf39 that sums it up
jardine is offline   Reply With Quote
Old 11-30-2007, 02:19 AM   #7
iwantmyWRX
Member#: 154286
2006 CGM WRX
Dust Collector
thanks for solving my confusion fellas
Old 11-30-2007, 04:21 PM   #8
Bluethunder505
Member#: 165368
2007 STi
Silverstone
Since I've heard conflicting information, let me get this straight: The 2007 STi AND STi Limited BOTH have the VF43 correct?
Bluethunder505 is offline   Reply With Quote
Old 11-30-2007, 04:36 PM   #9
0deucedub
Member#: 148030
2002 PSM Bugeye
:-o
this is correct,
And to the questiom asked, Both the vf39 and the vf43 both have the same p18 exhaust housing, the vf43 just has a different wastegate to prevent boost creep.
and the housing still cracks.
0deucedub is offline   Reply With Quote
Old 11-30-2007, 04:37 PM   #10
WRXJAY03
Member#: 121824
07 SwP STI - HeRs
05 AW STI - MiNe
yes sir your right!
WRXJAY03 is offline   Reply With Quote
Old 11-30-2007, 04:38 PM   #11
WRXJAY03
Member#: 121824
07 SwP STI - HeRs
05 AW STI - MiNe
also the 2006 models
Old 11-30-2007, 05:01 PM   #12
07SWPSTi
Member#: 158960
07 Impreza STi
correct
07SWPSTi is offline   Reply With Quote
Old 11-30-2007, 06:18 PM   #13
CynicX
Member#: 48199
06 WRX
Ignore the above. The 2006 STI uses the VF39, VF43 was first introduced with the USDM 2007 STI model....
CynicX is offline   Reply With Quote
Old 11-30-2007, 07:32 PM   #14
0deucedub
Member#: 148030
2002 PSM Bugeye
:-o
correct. main improvements for 07 sti's were vf43, and revised 3rd and 4rth.
Downgrades: Horrible oem tune...
Old 11-30-2007, 07:36 PM   #15
CynicX
Member#: 48199
06 WRX
Originally Posted by 0deucedub View Post
correct. main improvements for 07 sti's were vf34, and revised 3rd and 4rth.
vf34 were on the STi RA type C spec not the USDM STI....
Old 11-30-2007, 07:40 PM   #16
PowerTrip
Member#: 158674
'15 STi Limited
Revised 2nd, 3rd and 4th actually
PowerTrip is offline   Reply With Quote
Old 11-30-2007, 07:49 PM   #17
harrison88
Member#: 127639
06 T REX No Rear
Cupholder :(
yeah i think he meant to say 43 it's just that half of us on nasioc are
dsylexic arne't ew?
harrison88 is offline   Reply With Quote
Old 11-30-2007, 08:49 PM   #18
0deucedub
Member#: 148030
2002 PSM Bugeye
:-o
yeh i corrected it, i said it right in my first post.
Old 12-01-2007, 03:49 AM   #19
clbd39
Member#: 104078
2002 SRP VF43 WRX
P&L Jorge Tuned
vf43 - still cracks but is a little thicker so it cracks LESS also has a larger internal wastegate, it's slightly bigger so you will have more power
clbd39 is offline   Reply With Quote
Old 12-01-2007, 09:05 AM   #20
nhat
Member#: 140163
03 STi
hellaflunctional
actually, only 3rd and 4th were revised
http://forums.nasioc.com/forums/showthread.php?t=181343
Old 12-01-2007, 11:10 AM   #21
CynicX
Member#: 48199
06 WRX
Actually that link is incorrect the 2nd gear of the 07 sti should be 2.235....
Previous years had 2.375....
Thats what I've always thought....And when I checked cars101.com it not only said 2nd was revised it told me the same 2.235 ratio that I had thought.
If it hadnt been revised you'd have a gear jump of 2nd : 2.375 to the newly revised 3rd 1.521....To large IMO, at least for a 6 spd....
Old 12-01-2007, 11:34 AM   #22
nhat
Member#: 140163
03 STi
hellaflunctional
hmmm ok you win
Old 12-01-2007, 01:17 PM   #23
CynicX
Member#: 48199
06 WRX
I wasnt meaning that as a "I told you so!" comment. Because I could still be wrong, but to the best of my limited knowledge I always thought that 2nd, 3rd and 4th were changed. Hell I havent even driven an 07 STI....
Old 12-01-2007, 01:25 PM   #24
samo22
Member#: 119693
1995 L w/ ej205
so anyone know if 08 stis are going to have vf43 as well?
samo22 is offline   Reply With Quote
Old 12-01-2007, 01:59 PM   #25
clbd39
Member#: 104078
2002 SRP VF43 WRX
P&L Jorge Tuned
i couldn't imagine the vf43 being limited to only the 07's lol so surely they're in the 08's
i believe CynicX is correct with 2,3 and 4 being changed, my brother has an 07 (which obviously makes me no expert at all) and it pulls pretty damn hard, 4th gear is definitely longer with it making no effort at all to get above 99 mph, which seemed to be the avg. barrier for the previous models of sti's (correct me if i'm wrong)
But back on topic the basic difference is that the 43 is the new model of 39, just slightly redone like I said in my post #19
my little wrx will soon be the new home to a vf43
VF39 VS. VF43 Revisted Scooby South Proven Power Bragging 21 09-06-2013 12:50 AM
Vf39 vs. Vf43 aps turboback divider MKXIII Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-02-2007 12:06 AM
WTB: VF39 or VF43 polvo Private 'Wanted' Classifieds 4 03-21-2007 10:44 PM
WTB: VF39 or VF43 Evil XT Private 'Wanted' Classifieds 7 03-10-2007 01:27 AM
VF34 vs VF35 vs VF43 Kevin23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-02-2006 08:31 AM
