Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC > BAIC Vendor Classifieds
Closed Thread
Old 11-30-2007, 01:57 PM   #1
SpeedElement
Vendor Sales Rating: (61)
Member#: 18920
2004 WRX/STI
Exclamation New Product! Swift Spec-R Springs for STI! Install Special!
SWIFT Springs have just released for the Spec-R Sport Springs for the U.S Market!!!
Sport Springs SPEC-R
For motorsports minded individual with a passion in winning.
SWIFT made Sport Springs Spec-R is made for true track racing enthusiasts that wants to take their vehicle to the next level.
Sport Springs Spec-R is engineered with 2 main characteristics.
1) Redesign lowering ride height to maximize the suspension performance allowing the vehicle to fully absorb road condition for maximum traction.
2) Increase in spring rate to further enhance cornering speed through entry & exit. The increase in spring rate is based on the vehicle factory stock valving settings. Sport Springs Spec-R is increase to the optimal rate that the stock shocks can handle. Higher performance shocks are not required, but recommended.
The Spec R springs are wound with the same engineering as their sports springs. With the exception of stiffer rates and slight change in ride height; you can expect the same characteristics as their sports springs.
Applications: 04 STI and 05+ STI
Front Spring Rates: 5.1 kg/mm (285 lbs/inch), Rear Spring Rates: 4.9 kg/mm (275 lbs/inch)
04 STI Ride Height Drop: 0.8" Front and 0.6" Rear
05 STI Ride Height Drop: 1.0" Front and 1.0" Rear
Introductory price: $455 Installed OTD!!
We also have the Sport Springs!
04+ STI Front Spring Rates: 2.5-4.5 kg/mm (140-252 lbs/inch), Rear Spring Rates: 1.6-4.0 kg/mm (90-224 lbs/inch)
04 STI Ride Height Drop: 1.0" Front and 0.8" Rear
05 STI Ride Height Drop: 1.2" Front and 1.2" Rear
02-03 WRX Sedan Ride Height Drop: 1.18" Front and 0.59" Rear. Spring Rates: 3.3k front and 2.7k rear
02-03 WRX Wagon Ride Height Drop: 1.18" Front and 0.59" Rear. Spring Rates: 3.3k front and 2.89k rear
04+ WRX Sedan Ride Height Drop: 0.98" Front and 0.79" Rear. Spring Rates: 3.4k front and 2.7k rear
04+ WRX Wagon Ride Height Drop: 1.18" Front and 0.59" Rear. Spring Rates: 3.3k front and 2.89k rear
Get any of the above Sport Mach Springs for: $440 Installed OTD!!
Check out Swifts FAQ page and there Advantage page for more detail on what makes these springs so good! :RockOn - not mine:
Give us a call to set up an appointment.
-Rob
510-226-8822
SpeedElement is offline
Old 12-21-2007, 12:46 PM   #2
banilla
Member Sales Rating: (16)
Member#: 121864
03 WRX Wagon
Spec-Rs are great on the STI. I rode in that very STI pictured! Its Mann Engineering's STI used to prototype the Spec-Rs. Notice it says MANNENG on the front license plate. LOL. I'm curious, where did you guys get that photo from?
banilla is offline
Old 12-21-2007, 03:07 PM   #3
SpeedElement
Member#: 18920
2004 WRX/STI
We got that picture from Swift.
Old 01-02-2008, 10:33 PM   #4
209.DaNk
Member#: 164416
05 WRX Wagon Stg 2
03 Yamaha R6
400 installed wow. how much is the spring by itself?
209.DaNk is offline
Old 01-08-2008, 04:09 PM   #5
SpeedElement
Member#: 18920
2004 WRX/STI
PM'ed
Old 01-14-2008, 02:03 AM   #6
heyarnoldmbj
Member Sales Rating: (3)
Member#: 71638
07 WRX
how about the sport springs for an 07 wrx sedan?
heyarnoldmbj is offline
Old 01-15-2008, 06:04 PM   #7
SpeedElement
Member#: 18920
2004 WRX/STI
Thanks for reminding me. First posted updated with WRX spring install pricing too.
Closed Thread
TI: 04-07 STi Swift Spec R Springs nightcrawler60 SCIC Private Classifieds 16 07-10-2010 02:38 PM
FS IL: STI swift spec R springs and 2 front tic bumpstops**** jawwadh Suspension/Brakes/Handling 1 05-06-2010 02:29 AM
FS (tx) Swift Spec R springs for the 04-07 STi-- Near New! tewrxasti Suspension/Brakes/Handling 17 08-26-2009 11:22 PM
04+ sti Swift spec-r springs and sway bars. pitstops Suspension/Brakes/Handling 5 11-13-2008 06:34 AM
Swift Spec-R Springs Intro Sale! Evasive Motorsports Suspension/Brakes/Handling 38 01-21-2008 02:07 PM
