Alaskan Impreza Club
Old 01-26-2002, 12:28 AM   #1
zemmo
Member#: 5416
2002 Wrx wagon
Default Cold-weather fluids?
Still searching for info on various brake and clutch replacement fluids. Has anyone tried anything that works much better in cold weather than the OEM DOT 4? Thanks for any info.
zemmo is offline   Reply With Quote
Old 01-28-2002, 12:44 AM   #2
WRXnFX
Alaskan Mafia
Member#: 10398
Bump. I'm about to do brake lines and want opinions on fluid. Winslow
WRXnFX is offline   Reply With Quote
Old 01-28-2002, 02:11 AM   #3
hotrod
Member#: 14141
2002 Impreza WRX
Default not sure if this will help but ---
The silence has been deafening on your query.
Unfortunately my experience with extreme cold has been limited to the -35 deg F range here in Colorado during mountain rescue missions, and I was interested in what the answers would be.
I was able to find the following links, hope they help.
http://www.icbm.org/erkson/ttt/silicone.txt
http://www.caterpillar.com/products/...f/SEBU6250.pdf
http://www.usarak.army.mil/usarak_pu...on%20750-4.pdf
http://www.adtdl.army.mil/cgi-bin/at...9-207/appa.pdf
http://www.usarak.army.mil/usarak_pu...et%20750-1.pdf
http://www.turtleexpedition.com/vehicles/turtle4.htm
Larry
hotrod is offline   Reply With Quote
Old 01-28-2002, 01:16 PM   #4
zemmo
Member#: 5416
2002 Wrx wagon
I'm still working on it. As usual, there are so few of us who care about performance at very low temperature that there's not a lot of information available. I have ordered a number of fluids and will let the board know how they work out, but I'm not sure when I'm going to swap everything out yet.
Right now, it looks like I'm going to use Redline 75W90 gear oil in the differential. LSDs like a bit of friction modifier, but, according to Redline at least, transmission synchros work a lot better w/o those modifiers, so I plan to run Redline lightweight gear oil 70W80 in the tranny.
I ordered some Motul 5.1 for the clutch and the brakes, it SHOULD offer improved performance in cold weather, am real curious to see.
Redline D4ATF for the power steering box. Redline makes several ATFs, and this looks to be the best for cold to moderate weather.
Otherwise, intend to use a hoppy ale therapeutically...
Old 01-29-2002, 11:40 PM   #5
Resbum
Member#: 13935
1999 Forester S
Green
Default Here's something to look up
Zemmo- Try looking up "Neo Synthetic Oil". It's great stuff, but pricey. I run it in my truck. It's been a while since I found it on the web so I can't remember where to direct you. They have all types of fluids and greases. If I remember correctly alot of the racers who run the 24 hour races use it. The stuff supposedly doesn't break down and stays very fluid way down into the negatives.
Resbum is offline   Reply With Quote
Old 01-29-2002, 11:50 PM   #6
Resbum
Member#: 13935
1999 Forester S
Green
Thumbs up Oh Yea! Almost forgot.
There's nothing wrong with Redline products, either. I used them in my dirt bike when I did some desert racing. I still use their "Water Wetter" in all my vehicles. They claim it helps the coolant dissipate heat 15 to @ 20% better and I've noticed those claims to be true.
Winslow - Maybe you could talk to Red Line about carrying their product line?
Old 01-30-2002, 02:00 AM   #7
WRXnFX
Alaskan Mafia
Member#: 10398
That's a good idea. Usually large companies require a large buy-in but I'm sure we can get them from a wholesaler at a discount. Winslow
Old 01-30-2002, 01:55 PM   #8
zemmo
Member#: 5416
2002 Wrx wagon
Thanks for the suggestions, guys. I have been holed up running dogs, trading stocks, and learning about synthetic molecules. There's a lot to learn, last night I read about polyalphaolefins vs. polyol esters. Fascinating stuff, if you're a bit prone to obsession. Winslow, I ordered a case of the Motul 5.1, I'd be happy to sell what you need for the clutch and brakes. It's kind of expensive, about 10 bucks a half liter with shipping and handling. But I doubt you'd use 3 bottles for brakes and clutch both.
Old 01-31-2002, 02:20 PM   #9
WRXnFX
Alaskan Mafia
Member#: 10398
Motul 5.1 fluid is used in both the clutch and brake systems? We'll need enough for two cars because we are doing brakes soon. Might as well do the clutch fluid, too. Winslow
Old 01-31-2002, 09:52 PM   #10
zemmo
Member#: 5416
2002 Wrx wagon
I believe the Sub. manual calls for DOT 3 or 4 in both. The Motul 5.1 claims to be suitable for any DOT 3-4 systems. The DOT 5.1 was developed specifically for ABS systems. Neo-synthetic also makes a high-end brake fluid; although the low-temp viscosity is a bit higher than the Motul, the boiling points are considerably higher. Might be a better fluid if you plan on doing a lot of autocrossing or something. You can get a case (12 half-liters) of the Motul from panteracars.com for about $105. The neo synthetic stuff is available from a link on their website, but it's more expensive. Luck, Alan
Old 02-01-2002, 01:19 AM   #11
WRXnFX
Alaskan Mafia
Member#: 10398
How many half-liters does one car take? Winslow
Old 02-01-2002, 01:34 PM   #12
zemmo
Member#: 5416
2002 Wrx wagon
Good question. Nobody seems to know for sure, but everyone seems to agree it'll be less than 2 liters for both. Does anyone know the true amount needed to bleed and refill both clutch and brakes?
The price for the Motul case is more like $97 bucks. The neo synthetic comes in 12 oz bottles for around $11 plus shipping. If it never gets so cold down there that the clutch and brakes work poorly, I might go with the neo for the increased boiling point.
Old 02-01-2002, 06:07 PM   #13
WRXnFX
Alaskan Mafia
Member#: 10398
Neo-synthetic, huh? I'll check into it. Winslow
Better trans fluid for cold weather veener79 Service & Maintenance 19 01-01-2010 10:42 PM
Hot weather vs Warm Weather vs Cold Weather - RPM issue. SausageCat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-01-2009 08:51 PM
Cold Weather and New Tranny Fluid tfields04 Newbies & FAQs 4 12-18-2008 10:03 PM
"mixed" fluid in cold weather timmah Transmission (AT/MT) & Driveline 12 08-30-2005 01:46 PM
Cobb stage 2 cold weather boost vs warm weather OvrClkdPmp Engine Management & Tuning 4 04-22-2005 07:54 PM
