Old 12-01-2007, 04:48 AM   #1
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
Unhappy Rear Main Seal problem
Ok, Im back on here again. THanks for the comments and help guys and gals. I have a more serious problem now than the door issue. I have a rear main seal that needs to be replaced. Now I'm not a sub tech and dont know much about these boxters but doesnt the block split on them??? I called a few places and it would seem cheaper and easier for me to drop in an early 2.5 NA. I could use some real help with this one. Also I need to have a tranny seal replaced so I thought about having a shop do it when they do the trannys but it would be about an extra 400-500 to replace it. Its too cold for me and my brother to do a swap but if its gonna cost more than 800 to do it I can buy a boneyard 2.5 and drop it. Any insight would be awesome, thanks people.
Gabe
rivman05 is offline   Reply With Quote
Old 12-01-2007, 07:35 AM   #2
mikeythejew
Member#: 141672
You do not split the block to replace it. Be careful in it's removal and installation.
mikeythejew is offline   Reply With Quote
Old 12-01-2007, 08:02 AM   #3
obs2008
Member#: 163068
08 outback sport
yeah if you live in alaska its probably not something you want to do out side. the trans has to be pulled to do it. its really not much of a job besides pulling the trans (and clutch if you got one) and replacing the seal. like mike said, you just have to make sure you install the seal correctly
obs2008 is offline   Reply With Quote
rear main seal 1998 2.5L dreaminsubys Service & Maintenance 5 03-27-2006 02:14 AM
Installing a clutch? Why not throw in a new rear main seal. Tim Sanderson Transmission (AT/MT) & Driveline 0 07-08-2004 10:02 AM
rear main seal mybluesubi Service & Maintenance 11 02-09-2004 06:28 PM
rear main seal replacement?+ flywheel and pressure plate bolt torque? Haase14 Transmission (AT/MT) & Driveline 7 01-17-2003 10:42 AM
('93-'01) Rear main seal gone - 650kms? Help! JNaubur Impreza Forum 6 05-25-2001 12:29 AM
