Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 12-01-2007, 09:51 AM   #1
jmanSTI
Member#: 108020
2005 Impreza WRX STi
CGM - Stage 2
Default Anyone change spark plugs in an STi?
I am going to attempt this this weekend, I think.
Anything that I need to take into consideration specific to an STi above and beyond a few "generic" how-to posts that I have seen and picking up the proper tools?
If anyone is willing to lend a hand that would be cool too. I plan on doing this Sunday afternoon.
I am in Northwest Austin.
Thanks!
jmanSTI is offline   Reply With Quote
Old 12-01-2007, 10:13 AM   #2
TJ
Member#: 41735
I'm on your lawn
do something about it
you should be fine, changing plugs in the Legacy is WORSE!
TJ is offline   Reply With Quote
Old 12-01-2007, 10:24 AM   #3
Mighty E
Member#: 152553
2005 05 STI-Dom3
2006 B9 Tribeca Ltd.
get TWO spark plug sockets....remove the rubber fitting from inside one.
use the one with the rubber fitting to remove the spark plugs (since the rubber will hold them in place & make it easier to pull them from their hole).
use the socket without the rubber fitting to install the new spark plugs. otherwise you're going to have a hard time pulling that socket off the spark plug with the 2.3" you have between the frame rail and the valve cover. the only other option is to find a ratchet which locks the socket/extension on and a locking extension too. (cheap spark plug socket from auto zone costs much less). otherwise it's not that bad. remove the air cleaner and move the windshield washer bottle outta the way.
Mighty E is offline   Reply With Quote
Old 12-01-2007, 10:35 AM   #4
Zoharid
Member#: 151771
1994 RX-7
Mighty E's advice came in really handy for me.
Also I'd say use some sort of gloves to protect your poor knuckles from getting torn apart.
Zoharid is offline   Reply With Quote
Old 12-01-2007, 11:34 AM   #5
jmanSTI
Member#: 108020
CGM - Stage 2
Agreed.
Gloves are a must!
Old 12-01-2007, 03:14 PM   #6
meld
Member#: 91217
06 Evo IX / 04' R1
Tarmac Black
I can lend a hand sunday afternoon, Pm me for details. I am in Austin
meld is offline   Reply With Quote
Old 12-01-2007, 10:52 PM   #7
jmanSTI
Member#: 108020
CGM - Stage 2
Thanks Meld. I Pm'd you.
Anyone know where to find the replacement OEM NGK Plugs in Austin?
I tried 3 places today an no one had them in stock...... I was hoping to get them replaced for a tune at EngineLogics next Saturday.
Current plugs seem fine, just figured I may as well swap them out for the tune. Is it worth swapping in new ones if the exsting ones seem OK?
Thoughts?
Old 12-01-2007, 11:23 PM   #8
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Yeah if for some reason Meld isnt available, I should be.
I have another car I have to go fix asap though (long story self pwnage on my part basically) but that will likely be Monday at some point.
Defiant Autospeed is offline   Reply With Quote
Old 12-02-2007, 01:07 AM   #9
jmanSTI
Member#: 108020
CGM - Stage 2
Thanks Defiant.....
Do you have the plugs in stock?
Old 12-02-2007, 02:19 AM   #10
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I dont
Old 12-02-2007, 08:41 AM   #11
jmanSTI
Member#: 108020
CGM - Stage 2
No worries.
Looks like I am going to wait and swap out the plugs later.
Old 12-02-2007, 12:06 PM   #12
livnlegacy
Member#: 97207
10 Mazda3 2.5L 5dr
05 Nissan Pathfinder
I have some used (1k miles or less) NGK LFR7AIX #2309. These are the one-step colder iridiums for 05 LGT. Not sure if they are same for STi. I can also help with the install. About a 30-45 minute job, I've done a few and know some little tricks.
livnlegacy is offline   Reply With Quote
Old 12-02-2007, 02:44 PM   #13
jmanSTI
Member#: 108020
CGM - Stage 2
OEM NGK are IFLR6B
One step colder for STi are LFR6AIX
Thanks for offering though. I may hit you up at a later date.
Old 12-02-2007, 05:41 PM   #14
Scav1180
Member#: 56832
2004 STI
Java black
Scav1180 is offline   Reply With Quote
Old 12-02-2007, 11:47 PM   #15
jmanSTI
Member#: 108020
CGM - Stage 2
Word.
I missed that one. Thanks for the heads-up.
Anyone Changed Spark Plug Gap!? KENT56 Service & Maintenance 6 04-30-2008 12:37 PM
How to change spark plugs in an 05 Legacy 2.5 Gondi Service & Maintenance 3 12-11-2007 06:48 PM
Changing Spark Plugs in a WRX 2.0T wrxnova1 Newbies & FAQs 5 08-23-2006 04:03 PM
WRX Spark Plugs in an ej25? FatCatTurbo Normally Aspirated Powertrain 5 09-24-2003 10:51 AM
When to change spark plugs in WRX? scoobyrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-28-2002 07:49 AM
