Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 12-01-2007, 05:33 PM   #1
wrxguy243
Member#: 159969
Default Need Help with the Starter
Im having some problems putting the starter bolt back in through the transmission. The bolt came out smooth before hand while replacing the clutch but for some reason it does not want to catch. The bolt i have works in the top hole but will not thread in to the bottem hole. I really need help with this as im trying to finish this up tommorow. Any help will be appreciated.
I have taken in to account that the threads inside might be burred but everything came out no problem. I am really hoping that i just am doing something completely wrong.
wrxguy243 is offline   Reply With Quote
Old 12-01-2007, 08:23 PM   #2
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Pull it all apart and make sure it will go together on the bench and address any boogers you have in the threads there. If you did make a boo boo in the threads, you can fix it with a thread file very easily. You can get a thread file at most hardware stores. Make sure you get a metric one.
specialev is offline   Reply With Quote
Old 12-01-2007, 10:48 PM   #3
wrxguy243
Member#: 159969
pull apart the transmission again. I hope i dont have to do this as it was very hard to begin with. Im sorry if i didnt clarify that i have a manual transmission.
Old 12-02-2007, 05:31 PM   #4
Pvilledan125
Member#: 149931
i have this problem aswell.
Pvilledan125 is offline   Reply With Quote
01 LGT Tranny into WRX. Figured out the basics, need help with the rest. elhalisf Transmission (AT/MT) & Driveline 1 03-10-2005 07:50 PM
help with the starter on an ej20g swap smacksube Subaru Conversions 5 12-13-2003 10:20 AM
Need help with the exhaust! Elliot Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-25-2002 06:22 AM
Need help with the Crank pulley The Wraith Normally Aspirated Powertrain 1 07-12-2001 06:43 PM
need help with the J&S knock sensor ChAi Normally Aspirated Powertrain 7 10-20-2000 10:32 PM
