Old 12-01-2007, 08:32 PM   #1
Kape
Member#: 133509
04 VF22 WRX Wagon
Default Fuel Tank Pressure.
Hey guys I got a fuel evap code. I re installed my fuel pump wrong then fixed the problem, in that process I snapped a stud on one of the 8 holding the lid on..... Trying to see what the psi readings are I am seeing -0.02 thru -0.09 I dont know if its supposed to be negative or positive, just trying to see if I screwed myself over. Whats normal? thanks
Kape is offline   Reply With Quote
Fuel Tank Pressure - Importance JSarv Open Source Reflashes 12 12-29-2010 09:22 PM
Fuel Tank Pressure Sensor SenorMcNasty28 Subaru Conversions 12 02-12-2009 01:08 PM
busted stud during fuel pump install, proper fuel tank pressure? overdose Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 09-25-2006 11:20 AM
P1400 Fuel tank pressure control solenoid valve circuit low input after utec install bozz Engine Management & Tuning 7 07-28-2004 11:47 PM
Lack of Fuel Tank Pressure mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-23-2002 11:49 AM
