Old 06-06-2010, 08:15 AM   #226
DLWRX
Member#: 242689
2013 WRX 5-door
Originally Posted by Gdave89 View Post
Just curious but where can I find a premium stereo head for my base model 08 impreza
I wouldnt waste your money. Its still crappy and has horrible sound quality, go aftermarket, will most likely be cheeper to. Unless of course you are going for a factory only look.
DLWRX is offline   Reply With Quote
Old 06-08-2010, 09:32 PM   #227
Alpha14
Member#: 116537
I have a 2010 2.5i Impreza. I just installed the AUX cable and everything was going fine until I was going to screw in one of the 4 screws that holds the Head Unit in place and I dropped the screw. It fell below the Head Unit area and I can see it but it will not budge and I cannot get the last clip off on the right side on the silver trim piece. Can anyone give me some suggestions on how to get that last clip off? Its bugging the hell out of me that the screw is there.
Alpha14 is offline   Reply With Quote
Old 06-08-2010, 09:39 PM   #228
greddy90
Member#: 147065
just remove the shifter trim if you want to instead, it lifts up with some clips, very easy
hopefully you can find it, I dropped one and never saw it again even though I have removed everything including the carpet before
but its only 30 cents from subaru each
greddy90 is offline   Reply With Quote
Old 06-08-2010, 09:49 PM   #229
Alpha14
Member#: 116537
Already tried removing the shifter trim, no luck. Its somewhere lodged where the air controls are located and the only way to get to it is if that entire silver trim piece is removed. I know the screw is cheap its just that I can actually see it but can't get to it without removing the silver trim piece completely.
Old 06-08-2010, 09:55 PM   #230
greddy90
Member#: 147065
have you tried just using a magnetic screwdriver?
Old 06-08-2010, 10:02 PM   #231
Alpha14
Member#: 116537
Haha yup, I can feel it "grab" the screw but the screw will not budge. I realize that means it's probably not going anywhere but its just bugging the hell out of me and would really like to get it.
Old 06-09-2010, 05:44 AM   #232
SLDWYS
Member#: 58877
BMW 340xi
From JDM to DTM
Is there an easier way to take off the front AV Panel? Just got my JDM AV panel and am going to be doing an AV swap here soon. I'm a little worried about pulling on my far right trim piece.
SLDWYS is offline   Reply With Quote
Old 06-09-2010, 08:11 AM   #233
elwray
Member#: 194826
'09 WRX 5dr PP DGM
'07 VTX1300c, '03 VFR800
There's no removal of any parts needed.... just pull the edge of the AV panel trim, and work your way around it, and it'll pop out. This is how I've been doing it for the last two years... You might want to try a thin plastic item (something "softer" than the panel so you don't scratch it) to pry it off with, but I am able to just use my fingers...
elwray is offline   Reply With Quote
Old 06-09-2010, 03:09 PM   #234
greddy90
Member#: 147065
Like above said, been stated many times. No need to remove the lower HVAC piece, just the AV piece
Old 06-24-2010, 01:25 AM   #235
djmano
Member#: 13150
I just installed an Alpine IDA-X303 in my 09 rex. I used the Scosche Kit w/ the pocket b/c my head unit is a single DIN.....everyone has been commenting that the Scosche kit fits perfectly but I had a little trouble putting it together. Am I fail?
The screws that attach the pocket don't really hold it there very well. Also, after mounting the head unit chassis into the dash kit, the side mounts are kind of bent outwards b/c the head unit is pushing them outwards. After tightening the side screws down it got a little better but its not completely (hella) flush. Am i installing it improperly?
I've attached a picture diagramming my fitment issue. Also, it doesn't look like there's room for the trim ring to fit. Is this normal? Any possibility the IDA-X303 is a little larger than the CDA, CDE series? Thanks for looking.
http://img195.imageshack.us/img195/4...400su2027b.jpg
djmano is offline   Reply With Quote
Old 06-24-2010, 08:22 AM   #236
elwray
Member#: 194826
'09 WRX 5dr PP DGM
Did you verify that the stereo you are using is actually a true single DIN size?
Old 06-24-2010, 08:34 AM   #237
whitey615
Member#: 207865
2016 Sti
Wrb
subscribed
whitey615 is offline   Reply With Quote
Old 08-04-2010, 08:25 PM   #238
Domino81
Member#: 223361
2008 Mazda
Speed 3
What the hell is the single wire coming out the back?
Domino81 is offline   Reply With Quote
Old 08-05-2010, 08:58 AM   #239
razrielle
Member#: 205698
for what radio?
razrielle is offline   Reply With Quote
Old 08-05-2010, 09:00 AM   #240
elwray
Member#: 194826
'09 WRX 5dr PP DGM
Are you maybe referring to the grounding wire that attaches to the clip on the stereo chassis?
Old 08-05-2010, 12:51 PM   #241
Domino81
Member#: 223361
2008 Mazda
Speed 3
That's a grounding wire, eh? OK. Just trying to understand why on my harness I don't have a wire for the dimmer. Anyone else have this issue?
Headunit # DEH 3100 IB
Old 08-05-2010, 01:09 PM   #242
elwray
Member#: 194826
'09 WRX 5dr PP DGM
On the stock stereo you're talking? Does the stereo lighting dim when you put the lights on, then get brighter/darker with the light dial on the dash?
Old 08-05-2010, 08:42 PM   #243
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
I'm not sure about the Pioneer DEH 3100 IB (aftermarket HU), but some HUs don't have a dimmer wire. Either the mfr wanted to save a few pennies, or they use a different scheme for dimming (e.g., ambient light sensor, GPS time/location).
Also, some cheaper radio installation harnesses omit the pin/wire to connect to the car's dimmer wire.
SVXdc is offline   Reply With Quote
Old 08-14-2010, 06:09 AM   #244
ITW2
Member#: 239147
2010 Impreza
Pearl White
How do I take apart the steering wheel?
Im trying to take the covers with the cruise control and radio controller of, but I cant get to removing the back so I can get to the single screw holding the plate in place.
Any ideas, og how to out there?
ITW2 is offline   Reply With Quote
Old 08-14-2010, 11:34 AM   #245
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
See links in this post.
Old 08-14-2010, 05:13 PM   #246
ITW2
Member#: 239147
2010 Impreza
Pearl White
Thx, was hoping for an way without removing the steering wheel, because the nut have some blue paint on, like warranty stuff, so was an bit worried about removing that.
Old 08-16-2010, 04:55 AM   #247
kmb3asv141
Member#: 254897
how to remove inner trim panel? i want to install reversing camera
kmb3asv141 is offline   Reply With Quote
Old 08-29-2010, 01:01 PM   #248
Kings028
Member#: 241526
2010 WRX Limited
E85 tuned -352hp/389tq
DOPE WRITE UP.. Nice to see a well written layout
Kings028 is offline   Reply With Quote
Old 09-13-2010, 05:43 PM   #249
Thesystem3
Member#: 233014
2008 Impreza Hatch
Satin White Pearl
so if i want my amp to turn on with the car and shut off with the car, do i do 12v battery or 12v accesory? for remote wire and if its the 12v accesory, what color is the wire. Yellow/Red?
Thesystem3 is offline   Reply With Quote
Old 09-14-2010, 08:28 PM   #250
Thesystem3
Member#: 233014
2008 Impreza Hatch
Satin White Pearl
BUMP Help Please
Remove the 2008 Impreza Front Bumer Boots Interior & Exterior Modification 6 08-16-2012 04:14 PM
SOA 2008 Impreza Accessories P/N & Installation Guides (includes iPod Interface Kit) Jon [in CT] News & Rumors 50 06-09-2011 10:39 PM
Anyone else notice the angle of the 2008 Impreza dash? GodWhomIsMike General Community 36 09-14-2007 01:43 AM
2006 Impreza 2.5i Radio Removal code_hat Normally Aspirated Powertrain 3 10-05-2006 09:57 AM
2000 Impreza-need trim removal guide. Any links? Chewyguru Off-Topic 12 05-03-2004 03:15 PM
