#301 |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
Yes, your factory metal brackets will work. The opening in your factory bezel/fascia will be 1/2" wider on the sides, but it will work. I thought I sent you a link to this post.
#302 |
Member#: 268254
Vehicle:2008 Impreza 2.5i S Obsidian Black Pearl |
Thanks for the pictures that made it so much easier for my alpine headunit upgrade!
#303 |
Member#: 263322
NESIC
Vehicle:2011 WRX Limited WRBP |
great write up but i highly recommend getting some interior removal trim tools.
i picked these up: they thing worked great and it did not require removing the passenger side trim to get to the trim around the head unit. sorry if this was already mentioned. |
#304 |
Member#: 307725
Vehicle:2012 WRX ISM |
hey all, i just bought a 2012 wrx base, ill be picking it up this week. i have a kenwood ddx418 double din that i would like to put in the wrx. i see people say i need the nissan wiring harness, could someone tell me which exact one? also do i have to buy the JDM dash trim to have zero gap? thanks!
#305 |
Member#: 254163
Vehicle:2011 WRX 20GXTR Black |
^crutchfield. input car, hu, it'll tell you all you need to know.
#306 |
Member#: 307725
#307 | ||
Member#: 25837
South East
#308 |
Member#: 307725
#309 | |
Member#: 143688
Last week I found this forum post to be very helpful when I was installing my Parrot Bluetooth MKI 9200 in my Subaru Impreza 2010.
However I wanted to make a note that I decided to try and skip taking the dash off from the right side. Turns out the trim around the stereo is easier to get off than I thought. I just used my fingernails and started to work behind the grey trim (starting from the top). It popped right off. Just make sure you have your car warmed up. If it's cold out like it was for me (living in Colorado) then you'll want that plastic and the clips to be warmed up so they don't snap off when you're working with all the plastic. Thanks for the great tutorial and images! Just thought I'd share my experience of skipping the first few steps. I had my Parrot installed in about 2 hours. Nice and fast! Quote:
#310 |
Member#: 293491
i have an 08 impreza base model. looking to add the under seat subwoofer. does the factory radio have the port for the harness to connect to on the back side???
#311 |
Member#: 299104
Vehicle:09 2.5i Premium Satin White Pearl |
ok, so i bought a new 2011 radio for my car (model CZ624U1). the ORIGINAL radio was said 6 disc changer. the connector on the back for the steering wheel controls has changed (and so have the wire colors from what i can tell)
my question is this - can anyone tell me which wires to splice to be able to use my steering wheel controls with my new BlueTooth radio? i have the connector and wire leads for the new radio (the car in which i got it from was totaled, the junkyard gave it the ol' snip) help would be appreciated! |
#312 |
Member#: 310053
Vehicle:2008 Impreza 2.5i Dark Gray Metallic |
Just bought my first 08 Impreza wagon last night and ripping out the stereo for a better one will probably be my summer project, so thanks for this thread, it was pretty helpful. I want to get sat. radio at some point soon. Should I just wait till I upgrade my stereo? The in-dash receiver is supposed to be sat ready, so I think there shouldn't be too much work involving that (at least I think).
*Just did some more searching around the forums and decided it's probably better to replace the stock HU and buy a separate XM receiver. Last edited by howtypical; 02-14-2012 at 12:23 PM. |
#313 |
Member#: 316954
I have a 09 Impreza 2.5i I just replaced the stock headunit with an aftermarket one. On the stock one there was a blue/black connector wire that was just plugged into a metal piece on the back of the stock headunit. I believe its some kind of ground wire. When I put in the new headunit I did not reconnect this plug to anything, the new headunit still worked and played fine. My question is, does anyone know the purpose of this connector and is is necessary to have it connected anywhere. On a side note, the stock stereo also worked fine without this plug connected.
#314 | |
Member#: 25837
South East
See post 11 in this thread: Stock head unit information -- pin-outs, subwoofer, aux inputs, and more |
#315 |
Member#: 306368
Vehicle:2011 Impreza 2.5i DGM |
I just replace my HU with a Pioneer AVH-p1400dvd
everything came out good except now my blue mood light next to the cigarette lighter doesn't turn on ={ |
#316 |
Member#: 325245
Really useful, thanks
#317 |
Member#: 141991
Vehicle:08 STi AW 06 Saabaru 2.5i |
This is awesome, thanks!
#318 |
Member#: 334844
here is a link to the service manual i have retrived on-line from some site in russia.
haha its in english though.any ways it states the stock radio is: over 16 watts x 4 seems pretty low of a estimate. pretty impressive details of pcb, pin outs and everything check it out here: ![]() https://docs.google.com/open?id=0B3B...2V2N3dBNzF4WG8 |
#319 |
Member#: 320642
So doing a little repainting on the dash pieces and the lower part of my dash is tan (where the glovebox is) I was wondering how i can take that off? i have got most of the screws out but i cant find any other screws and it still feels attached and i dont want to break it....
#320 |
Member#: 338523
Thanks for the guide. Was super handy when trying to replace my stereo. Too bad I only found out the stereo mosfet drivers were dead after fully installing it in the car. I guess I'll need this guide again in a few weeks...
#321 |
Member#: 305941
Vehicle:2008 impreza 2.5 Charcoal |
does anyone know how to remove the HVAC thats manual(adjusted by cables) and not digital? ive tried looking around and cant find anything.
#322 |
Member#: 301179
BAIC
Vehicle:2009 Outback Sport Sage Green Metallic |
Do the 08 2.5is have similar connection diagram as the 2012 wrx?
Thanks |
#323 |
Member#: 224097
NESIC
Vehicle:2012 WRX Hatch - DGM -=Tuned by Bren=- |
^ cant see why they would change the harness
#324 |
Member#: 301179
BAIC
#325 | |
Member#: 25837
South East
* The new Imprezas and Crosstreks dropped the CAN data bus. That only matters if you're trying to transplant OEM HUs across different models/years. * The new Imprezas and Crosstreks now have a pin for the illumination "bright" mode (night illumination dimness cancellation - 'NIDC'). Pin 11 (formerly one of the CAN pins). * The new Imprezas and Crosstreks have Vehicle Speed Signal (VSS) on pin 19. That is used for the speed-sensitive volume feature on the OEM HU (as well as locking out functions while you're moving). A few aftermarket navigation HUs can use that signal to improve position tracking. I can include an extra wire for VSS on my harness if you request it. 2011-2013 WRX and STI, and 2011 Impreza/OBS are all still the same (they have CAN bus, and no pins for VSS or bright mode -- they use CAN bus for the speed volume and NIDC features). |
| Thread Tools | |
| Display Modes | |
| Remove the 2008 Impreza Front Bumer | Boots | Interior & Exterior Modification | 6 | 08-16-2012 04:14 PM |
| SOA 2008 Impreza Accessories P/N & Installation Guides (includes iPod Interface Kit) | Jon [in CT] | News & Rumors | 50 | 06-09-2011 10:39 PM |
| Anyone else notice the angle of the 2008 Impreza dash? | GodWhomIsMike | General Community | 36 | 09-14-2007 01:43 AM |
| 2006 Impreza 2.5i Radio Removal | code_hat | Normally Aspirated Powertrain | 3 | 10-05-2006 09:57 AM |
| 2000 Impreza-need trim removal guide. Any links? | Chewyguru | Off-Topic | 12 | 05-03-2004 03:15 PM |
