Old 12-26-2009, 12:47 PM   #201
capsisking
Member#: 217782
Originally Posted by billtvt View Post
Hi- this is a great thread, with really good info. However, I could not find anything pertaining to the Ipod Adapter kit I need for my '09 Impreza with 6 disc changer (Premium but no Nav). I purchased a UPac from Crutchfield, and unfortunately found that the connector harness was too wide for the radio (24 pin, I need 20). Crutchfield does not have an adapter that will work with the 6 disc changer stereo, nor have I been able to locate one. Can anyone advise me where to find one (or if one is available?)
Thanks very much
if you purchased through Cruthfield call them. They have 24/7 customer service.
capsisking is offline   Reply With Quote
Old 12-26-2009, 05:08 PM   #202
J-Rod 555
Member#: 209231
2008 WRX, 95 leggy
White to the both of them
so i have a question, will a 6disc work in place of the base system, will it bolt right in without anything else being required?
J-Rod 555 is offline   Reply With Quote
Old 12-27-2009, 07:28 AM   #203
pleiadi
Member#: 158257
2008 Impreza 2.0R
Newport Blue
Yes it will, I sell the 6 discs one if you're interested (I just replaced it with another system).
pleiadi is offline   Reply With Quote
Old 01-01-2010, 06:01 PM   #204
gimli72
Member#: 232804
2010 WRX
WR Blue
Hello,
I'm a complete DIY newb. I am trying to install an aftermarket head unit on my '10 WRX. I've gone through all the threads here. They all assume that you know how to do wiring. What is the proper technique to connect the little colored wires from the head unit to the adapter? Do I just cut those cables, twist them together, and tape them? I don't want to create an unsafe mess. Thanks.
gimli72 is offline   Reply With Quote
Old 01-01-2010, 07:57 PM   #205
mpggomd
Member#: 74167
2011 WRX Sedan WRB
TP Stage 2, w/cust tweaks
Originally Posted by gimli72 View Post
Hello,
Buy some butt connectors and crimp them together. That, or solder them together but that's a lot harder!
Go to the Auto parts store and you can get the butt connectors and a crimping tool.
mpggomd is offline   Reply With Quote
Old 01-01-2010, 08:12 PM   #206
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by am3rican View Post
How difficult would it be to replace the stock 6-disc Stereo with a stock navi for a 2008 impreza? Would the steering wheel controls still work too?
It's not too difficult -- several people have done this. Threads:
Factory NAV into non-NAV swap
Need someone to answer a question about their stock Navi!!!
Factory dvd navigation unit install in a non-nav MY09 Forester
You'll need to put together a 20-pin to 14-pin adapter for the power and speaker wires, plus a 24-pin Navi harness (which has the wires for A/V input, SWCs, and several nav-related functions). You may also want the harness for the reverse camera input. E-mail me for info on obtaining all of those harnesses.
Your car's steering wheel controls will work. You just need to connect the two SWC wires from the 20-pin harness to the 24-pin Navi harness.
SVXdc is offline   Reply With Quote
Old 01-01-2010, 08:23 PM   #207
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Never simply twist the wires together and tape -- that won't last.
Soldering is best, but crimping works too. See offset’s Car Audio Manifesto and FAQ (one of the "sticky" threads at the top of the Car Audio/Video/Security sub-forum). In that thread, scroll down to his section "Car Audio Installation" and follow the links there.
Old 02-05-2010, 07:53 PM   #208
mxtreme311
Member#: 232236
2008 WRX
I have an 08 WRX with the Nav system and the underseat subwoofer... I've been looking everywhere for this, hopefully someone can help...
The nav system has controls for "Subwoofer" gain... how can I tap into that for an aftermarket sub amp???
mxtreme311 is offline   Reply With Quote
Old 02-05-2010, 07:55 PM   #209
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by mxtreme311 View Post
I have an 08 WRX with the Nav ... The nav system has controls for "Subwoofer" gain... how can I tap into that for an aftermarket sub amp???
I've posted an answer in the 'Discussion about Stock HU FAQ' thread, HERE
Old 02-13-2010, 08:53 PM   #210
TheBiRdMaN
Member#: 237107
Very nice writeup. I just installed an AVIC-x910 this past weekend. I did notice one thing however, you most definitely do no need to go through all the work of removing the lower trim piece. I used my plastic install tools and was able to remove the trim around the radio with ease. Just my experience.
TheBiRdMaN is offline   Reply With Quote
Old 02-14-2010, 04:15 AM   #211
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
Use these to connect wires
Use this to remove center console.
djinn is offline   Reply With Quote
Old 02-22-2010, 09:19 PM   #212
veener79
Member#: 204304
2008 WRX 4D Stage 2
I have a question on the 08 Nav system with a Ipod and Sat. I have a Zune and I like it but there is one think I hate. That is trying to change songs or any other things. I have to look down at my Zune and if I did not have to do that I would be happy.
I can only find the manuals online for the user guide with the none nav. HU. I am wondering two things. Can I have a Ipod and my sat system? I know they use the same plug. Also can I change songs from my HU or would it be the same as I am stuck right now with having to hold the Ipod in my hand to change songs?
If anyone has the user manual for the Ipod with Nav can you post a link? Before I buy a Ipod and cable I want to make sure I have what I want.
Thanks,
veener79 is offline   Reply With Quote
Old 02-23-2010, 10:33 AM   #213
KManZ
Member#: 220694
2012 STi
Satin White Pearl
Stereo related, though not regarding the dash or radio...
Removing the door panels: do I need to take off the sail panels to get the plastic door cards off? I'd rather avoid doing that, as last night during install/reinstall, the sail panel would not go back on tight due to the little silver clip not being able to snap back in properly.
KManZ is offline   Reply With Quote
Old 04-15-2010, 04:54 AM   #214
GISek
Member#: 244105
Question
Hi everyone:-)
I`m from Poland, my father in law has got US spec Impreza WRX STI*********** (june 08). Know I`m trying to make conversion from US spec radio (CZ641U6) to EU spec radio (CP443L6). For a first glance both of them looks the same, they have same connectors (almost the same, because antenna connector looks different - it is not simple socket it has got wire with rectangular connector). My question is for what is the connector which is over the 8-PIN connector?
GISek is offline   Reply With Quote
Old 04-15-2010, 01:01 PM   #215
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
it is probably running the alternative subaru antenna plug, or possibly a European standard plug. All you will need is an antenna adapter to make it work.
Like the Metra 40-SB20
Or the Metra 40-EU20
It just depends on what plug they use over there. I'm not positive.
thedaddyb is offline   Reply With Quote
Old 04-15-2010, 01:58 PM   #216
GISek
Member#: 244105
Thank You Thedaddyb:-) And what about this 20-PIN Connector above 8-PIN Connector? Does anybody know something about this?
Old 04-15-2010, 02:20 PM   #217
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
The 20-pin socket is for Subaru's accessory modules for iPod or satellite radio (Sirius, XM). It could also be for an external CD changer, but I don't know if Subaru offers one for this radio.
There are after-market accessories that may work with that socket. See my post #169 in this thread. Also see this thread: uPAC-SB1 Installation. PAC's site now shows compatibility with "2008 Impreza," so they may have worked out the problems.
Old 04-23-2010, 08:46 PM   #218
The Database
Member#: 225192
2008 BMW E92 M3
Bat Mobile Black
Great thread, does anyone have pics of all of the driver side trim off too? Steering wheel column, driver dash guages.....
The Database is offline   Reply With Quote
Old 04-24-2010, 06:47 PM   #219
qronos
Member#: 241689
Default Don't Remove the Dash Trim
I just changed the stereo out my 2010 WRX Sedan. It is not necessary to remove the dash trim panel.
The dash trim panel clips on the top are much easer to work off than the ones on the side. The side corner ones are especially tight, do those last.
1. Don't touch the big trim panel.
2. Get a soft blade putty knife (plastic) or a trim remover tool (basically a thin, rigid plastic knife). The putty knife worked great for me.
3. Start at the top right. The knife should go straight down into the top right corner clip. Work that clip loose, the other 2 top clips will come out easily after that.
4. Do the side clips by hand after this.
Took me five minutes tops, not a scratch on the trim.
qronos is offline   Reply With Quote
Old 04-29-2010, 12:46 PM   #220
lithiumus
Member#: 231463
2010 WRX STi SE
Fantastic thread. I'm planning a non-nav to Nav install in my STi in the future. Anyone know if the rear camera is prewired or is that only for the SUVs?
lithiumus is offline   Reply With Quote
Old 05-08-2010, 11:59 AM   #221
GISek
Member#: 244105
I have succesfully changed US radio into Europe version model. Only anthena cable needed some modifications. By the way, do you know what is the price used CZ641U6 in US? I Have one to sell.
Old 05-10-2010, 03:08 AM   #222
GISek
Member#: 244105
Lithiumus my father in law has got SI WRX STi 08 US spec and there are no wires for the rear camera. There are additional cables for navigation
Old 05-10-2010, 04:26 PM   #223
snobrdr2324
Member#: 239380
2006 WRX Limited
This is a very good guide, who needs crutchfield when you have writeups like this.
snobrdr2324 is offline   Reply With Quote
Old 06-05-2010, 11:38 PM   #224
Gdave89
Member#: 247520
2008 Impreza 2.5i
Just curious but where can I find a premium stereo head for my base model 08 impreza
Gdave89 is offline   Reply With Quote
Old 06-06-2010, 12:23 AM   #225
peglegsteve
Member#: 209987
2009 Slow WRX
Slower Prius
I'd try ebay before going to the dealer. Or maybe check the for sale part of the forum here?
peglegsteve is offline   Reply With Quote
Remove the 2008 Impreza Front Bumer Boots Interior & Exterior Modification 6 08-16-2012 05:14 PM
SOA 2008 Impreza Accessories P/N & Installation Guides (includes iPod Interface Kit) Jon [in CT] News & Rumors 50 06-09-2011 11:39 PM
Anyone else notice the angle of the 2008 Impreza dash? GodWhomIsMike General Community 36 09-14-2007 02:43 AM
2006 Impreza 2.5i Radio Removal code_hat Normally Aspirated Powertrain 3 10-05-2006 10:57 AM
2000 Impreza-need trim removal guide. Any links? Chewyguru Off-Topic 12 05-03-2004 04:15 PM
