Old 12-02-2007, 01:25 PM   #1
shaz1980
Member#: 136105
Default semi build block 2.5 version 7 head with gt35
can anyone help me timing n afr
since im new to sti motor not sure how much timing am i suppose to give 97 octane in our country with 27 psi max boost so that motor make power and be safe
from 4000-5500 (peak TQ) at at 27 psi?
from 5500-8000 (peak HP) rpm at 27 psi?
wat sort of afr i should have in boost
i just want the rough figures
thanks
shaz1980 is offline   Reply With Quote
? 2.2 block, 2.5 twin cam heads ? schrott Built Motor Discussion 6 01-03-2009 07:49 AM
2.2 block 2.5 heads HopesAndDreamsRacing Normally Aspirated Powertrain 10 02-05-2007 04:44 PM
WTB: 2 SOHC 2.5 Longblocks (just heads, block and oil pan) Tattoo Collector NESIC Private Classifieds 0 02-07-2006 02:14 PM
Version 7 heads and balanced blueprinted short block? O4STInger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-21-2005 02:53 PM
Building my 2.5 Block from ground up paulnose Normally Aspirated with bolt-on Forced Induction Powertrain 33 05-14-2003 11:50 AM
