Welcome to the North American Subaru Impreza Owners Club Wednesday October 1, 2014
Vancouver Impreza Club
Closed Thread
Old 12-03-2007, 03:24 AM   #1
shum_87
Member#: 129898
2001 Impreza
Default dear tuning gods: when is a tune in order?
as I'm thinking more towards the future, when should the car be tuned?
taking my car, as an example: I only have a sri, and soon to have borla headers and custom sti exhaust. however, I might be picking up a set of lightweight pulleys and looking in the distant future, camshafts, valves, valve springs, spark plugs, spark plug wires, and throttle body spacer.
I've seen in threads that even for a sti that an intake, exhaust, u/p or d/p requires tuning. that got me thinking.
any comments would be nice
shum_87 is offline
Old 12-03-2007, 03:27 AM   #2
veightkiller
Member#: 78967
2011 335i
most of the guys just do engine swap as its a good baseline to make more power.
.02
veightkiller is offline
Old 12-03-2007, 03:33 AM   #3
AWDsub
Member#: 56303
2010 Legacy GT
Your car would run fine with no tuning, however if you did get some tuning you would pick up around 15-30hp depending on your mods. If you know how to tune, then a Perfect Power is good. If you dont know how to tune get an I-speed Reflash according to your mod list.
AWDsub is offline
Old 12-03-2007, 03:35 AM   #4
GlobalWaste
Member#: 74792
You can pick up used wrx motors pretty darn cheap
GlobalWaste is offline
Old 12-03-2007, 03:36 AM   #5
TheToby
Member#: 99241
I have a 2005 WRX bottom end that you can HAVE if you want to come pick it up from my house.
offer stands to anyone who wants it.
TheToby is offline
Old 12-03-2007, 04:23 AM   #6
shum_87
Member#: 129898
2001 Impreza
ahh..the n/a build vs. swap debate...haha
I've thought about going turbo for a long time, but I'm certain to keep her n/a. I also don't have to the means of dumping a huge load of money for a swap right now either.
would it be bad for the engine if I don't tune though? too lean or too rich are not good...
shum_87 is offline
Old 12-03-2007, 04:31 AM   #7
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
The sooner it goes, the sooner u can swap. That's how I look at it.. lol
Mirage is offline
Old 12-03-2007, 05:12 AM   #8
mannslayer
Member#: 94978
start saving your pennies for a swap. n/a build is expensive, with minimal results. definitely not worth the money in my opinion. to answer your question, you probably don't need tuning with your basic upgrades. but without tuning, these upgrades do very little as i am sure you've realized. to fully see the upgrades potential, a tune is definitely in order. once you start messing around with the motor, then tuning becomes much more important.
check out rallitek pp6 and i-speed reflash.
but i say leave the n/a builds for the honda boys.
mannslayer is offline
Old 12-03-2007, 05:26 AM   #9
AWDsub
Member#: 56303
2010 Legacy GT
NA is not a bad way to go, just not much light at the end of the tunnel. I did the full NA build on my RS. Intake, full exhaust, PP6= 120-130ish at the wheels. Intake, Full exhaust, PP6 and cams = 140ish whp, and Intake, Full exhaust, PP6, cams and head work = garanteed 170whp. If you add high compression forged pistons (11.5) =190whp. I have already done all this and now Im turboed and see the light. Nitrous is probably the cheapest horsepower and despite what most will say, it is safe to run on a stock block.
AWDsub is offline
Old 12-03-2007, 08:58 AM   #10
tora
Member#: 5851
09 Forester XT
+ NA Miata
That is the worst advice I have ever heard for an N/A Subie.
Do NOT Nitrous unless you want a very short engine span. Your WHP numbers are way off as you haven't stated what dyno you are talking about. On a Dyno Dynamics your 190 final number would be more like 150-160 at the most. I haven't seen any NA builds over 210-225 Crank HP.
Nitrous is a HIDEOUS idea, the engine is will not last with either nitrous OR turbo'd.
To the OP, f you want to stay N/A but get some decent power gains, get Equal Length Headers, Borla will just give you more grumble with minor gains. Get a highflow cat and not too big diameter cat-back or header back piping. I'd do cams as well and call it a day, if you start getting into an engine build you are better off putting that money towards a swap.
tora is offline
Old 12-03-2007, 02:22 PM   #11
AWDsub
Member#: 56303
2010 Legacy GT
If you dont have a clue what your talking about then you should probably not add in advice. I have done every stage of a NA build and all those numbers are accurate according to a Dynojet Dyno which is a common dyno. I assume you havent read "Zero to Hero" in Subiesport Magazine as their NA RS project car was based off mine build. Nitrous is safe in moderation and a good setup. I ran a wet 75 shot for over 40,000 miles on a stock RS block with 120,000 miles on it. And when I first put it on my RS, I used it so much that I filled it up once a week during drag racing season. Did I blow my motor? Yes, I finally put a 100 shot on and after 2 months I filled it over 13 times and constantly drove around with it on and then finally burned a hole in the piston when I was holding it down in 5th gear for over a minute. So Yes nitrous is safe in moderation and your RS block is rather durable as I have tested.
AWDsub is offline
Old 12-03-2007, 02:55 PM   #12
tora
Member#: 5851
09 Forester XT
+ NA Miata
I suppose my three years at Rocket Rally dealing almost solely with Subaru's does not give me the right to express my opinion and caution someone towards safety when a member who is clearly NOT concerned with it come to the board and posts that Nitrous is the way to go on a stock block.
If you were willing to WARRANTY a nitrous set up on the OP's stock block then I will retract my comments...if not, my point is extremely valid and stands.
At the shop we would run very high boost through stock JDM blocks on the rally cars with the knowledge that the lifespan is limited...but would we have pushed the same amount of boost through a customers block who had just spent $20K on a JDM swap into their RS....NO....we would push a safe amount of boost so that they could enjoy great power AND longevity.
tora is offline
Old 12-03-2007, 05:17 PM   #13
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
I think your missing a nitrous horror story to prove your point...
Sko is offline
Old 12-03-2007, 06:05 PM   #14
steve
Member#: 4718
~ too
many to list
I thought you were the secretary there?
ouch.
steve is offline
Old 12-03-2007, 06:50 PM   #15
mannslayer
Member#: 94978
+1...
20k for a swap...
Old 12-03-2007, 07:16 PM   #16
steve
Member#: 4718
~ too
many to list
OMGHi2U
Originally Posted by mannslayer View Post
+1...
don't drag me into your war, yo!
tora is a b&b'r, and that's a b&b joke, straight up. It's not a knock to anyone personally, publically, or professionally.
that is all.
now here is a dancing banana.
steve is offline
Old 12-03-2007, 07:24 PM   #17
fukamoto
Member#: 13339
2014 SWP WRX Wagon
I'm a TORA Supporter
fukamoto is offline
Old 12-03-2007, 07:26 PM   #18
mannslayer
Member#: 94978
nothing against tora at all, didnt mean it in a bad way. just sayin, its not like he was tuning cars there.
the next part was a rocket rally beak tho
you know, i am always given em some verbal.
Old 12-03-2007, 07:46 PM   #19
steve
Member#: 4718
~ too
many to list
I know your role, it's cool.
steve is offline
Old 12-04-2007, 12:31 AM   #20
L_Box
Member#: 123064
95 Impreza LWRX
Ruby Red
That is the worst advice I have ever heard for an N/A Subie...
...Nitrous is a HIDEOUS idea, the engine is will not last with either nitrous OR turbo'd.
Wow, seriously? I know you're highly respected on this forum because of the experience you have working at RR. But what's with the attitude? It's not like he told the guy to throw on a dry 100 shot and expect to get another 200,000 miles out of his motor. Everyone's entitled to their opinions, i guess. I just don't see why some people feel the need to be so abrasive about it
L_Box is offline
Old 12-04-2007, 12:58 AM   #21
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
We're all friends boys!
semaj is offline
Old 12-04-2007, 01:50 AM   #22
shum_87
Member#: 129898
2001 Impreza
thanks to everyone for their input
expecially to tora!
close thread please!
shum_87 is offline
Closed Thread
When is WRC airred in Canada? circa_bc Vancouver Impreza Club Forum -- VIC 7 03-23-2009 07:36 PM
When is a tune necessary??? wrx425 Factory 2.0L Turbo Powertrain 19 08-22-2008 02:24 PM
Cars is done - thanks in order stevepius Mid West Subaru Owners Club Forum -- MWSOC 8 11-30-2007 12:18 AM
I call2u computer gods: This is what I see when cntr+alt+delete (pic) chemicalviper Off-Topic 9 09-20-2006 07:11 PM
New home construction, when is interest locked in? Akirasoft Off-Topic 5 03-24-2005 03:56 PM
