Old 03-27-2008, 08:14 PM   #301
b00st3d
Member#: 9891
2015 RC-F
Ultra White
i think it may have been on the ground and i drove over it and it got kicked up. im pretty sure its sap and not paint. i get it pretty often unfortunately.
b00st3d is offline   Reply With Quote
Old 03-31-2008, 10:51 AM   #302
bwanaaa
Member#: 172602
2008 STi
gray
Originally Posted by bwanaaa View Post
i dont know if i should post a new thread but i need a little help. I have a 2008 sti and the front bumper as you know is low to the ground. I was parking the other day and scraped the front on some ice. These scrapes are into the clearcoat but not the paint.
I was thinking of using some meguiar's #2 then #7 and finally some #20 with a buffer. Or is there better stuff to use? Also,What kind of buffing pad should be used?
tnx.
stefan
well here are the photos.
what do you think?
bwanaaa is offline   Reply With Quote
Old 03-31-2008, 10:57 AM   #303
DetailersDomain
Member#: 165558
I would go into this as you have nothing to lose....i would give it a try and if you can't fix it get it spot repaired.
DetailersDomain is offline   Reply With Quote
Old 03-31-2008, 11:09 AM   #304
EsTeaEye
Member#: 153261
I picked up a PC 7424 not too long ago. One of my good friends wants me to tackle his car with it. His car is Red and has a good amount of swirls, I would say a lot more then average. Which pads should I use for severe swirls, then following it up? I have CCS Pads and a Velcro Backing Plate. I have a Black, Yellow, White, Orange, Green, Blue, and I think that's it, mainly one of each color. I currently have some Adam's Products (Scratch/Haze Remover, Revive Polish, Buttery Wax), Meguires (Gold Class Was, Polish, Scratch-X), Optimum (Polish), Turtle Wax 2001 (Polish, I believe), KIT (Scratch Out), Zymols (Cleaner Wax).
Now I'm pretty new with the whole PC thing, but have attempted to do Orange - Adams Scratch Remover, White - Adams Polish, and Black - Adams Wax on a similiar conditioned car but it didn't remove everything, maybe about 40-50% of scratches. Maybe I wasn't putting too much weight down on the PC? I really would love to have the finish you often get, or atleast get 80% of the stuff out for him and myself in the future, if it ever gets that bad.
So what do you recommend I use, which pads, which products, and what speeds on the PC? Like I mentioned, the car is Red, and has pretty severe swirls. Thanks,
EsTeaEye is offline   Reply With Quote
Old 03-31-2008, 05:25 PM   #305
bwanaaa
Member#: 172602
2008 STi
gray
actually, i was kind of hoping for recommendations of which product to use.
Old 03-31-2008, 06:10 PM   #306
DetailersDomain
Member#: 165558
try what you have on hand first.
if not you might want to try to wetsand/menzerna power gloss compound, menzeran ip , menzerna micropolish.
yellow pad/wool - then green pad, then white or blue pad.
I still think it might be a long shot.
Old 04-01-2008, 04:30 AM   #307
benw
Member#: 103320
1998 swapped
Forester L
dear detailersdomain.com,
whenever I wash my car, if I roll down the windows within 24 (or sometimes more) hours, the water will streak the glass when I roll them back up.
What do you usually do to combat this? I always dry the glass and clean it with a special glass cleaner etc, and rolling down the windows once usually negates all the work.
Any solution you might have is welcome.
benw is offline   Reply With Quote
Old 04-01-2008, 09:00 AM   #308
DetailersDomain
Member#: 165558
not much to do but used compressed air to blow out as much as possible by where the door and window is.
Old 04-01-2008, 09:43 AM   #309
b00st3d
Member#: 9891
2015 RC-F
Ultra White
there is a felt pad that slides on the window when you roll it down. its acts like a guide, but its on the inside of the door. Unfortunately it usually soaks up with water when you wash your vehicle. Unless you can somehow dry this pad, dont roll your windows down within 24hours!
Old 04-03-2008, 07:20 PM   #310
b00st3d
Member#: 9891
2015 RC-F
Ultra White
what clay bar are you using?
you can probably try P21S autowash followed by a clay bar then polish.
or you can get some 3m adhesive remover to try to get some of that off.
I used the 3m adhesive remover on the areas with the sap stains and it worked perfectly! It more than likely also removed the wax...what would you recommend that i do to protect the areas that i used the adhesive remover on? should i polish followed by wax?
thanks.
Old 04-03-2008, 07:29 PM   #311
DetailersDomain
Member#: 165558
yes that would be a great idea. wash the area polish wax.
Old 04-03-2008, 11:17 PM   #312
b00st3d
Member#: 9891
2015 RC-F
Ultra White
thanks for the help!
Old 04-04-2008, 02:35 AM   #313
DetailersDomain
Member#: 165558
sure thing.
Old 04-04-2008, 03:39 PM   #314
EsTeaEye
Member#: 153261
Any tips on my previous request?
Old 04-04-2008, 06:59 PM   #315
Boost_Happy
Member#: 125292
2006 STI
FPgreen SGM
I want to say thanks, because I bought some product from you and am really impressed. I was kind of confused on a wax to buy so I bought the menzerna sealing wax. What is the life of the wax on a car that stays outside and how durable is it. Should I put something else on top to seal? I also have my sti in the garage and am looking for a great sealing/protecting product as well, what would you recommend. thanks
Boost_Happy is offline   Reply With Quote
Old 04-04-2008, 09:47 PM   #316
DetailersDomain
Member#: 165558
Sure thing.
I would recommend Einszett Glanz Wax. I've heard that its good for 2-5 months from my customers in Seattle.
As for the sealing wax I would say 1-2 months max.
Old 04-04-2008, 11:03 PM   #317
Boost_Happy
Member#: 125292
2006 STI
FPgreen SGM
How is Einszett Glanz Wax applied, hand or 7424? I have the 7424 so I can do it that way, but what is the best way to apply? If its 7424 then what speed, 2500rpm?
Old 04-08-2008, 05:17 PM   #318
wrx junkie
Member#: 151039
07 WRX
UGM
should i throw away my used microfiber towel or can i put it in the washer machine? what do you recommend? thanks alot.
wrx junkie is offline   Reply With Quote
Old 04-08-2008, 06:39 PM   #319
DetailersDomain
Member#: 165558
depends on how bad it is, you can use a our microfiber restorer detergent.
as long as its not beat up throw it in the wash. cold/warm water cycle and dry with no heat.
http://www.detailersdomain.com/index...ROD&ProdID=155
Old 04-08-2008, 07:28 PM   #320
wrxftl
Member#: 174469
05 wrx
what insurance do you have for your business?
wrxftl is offline   Reply With Quote
Old 04-09-2008, 09:06 AM   #321
RIP EP3
Member#: 119335
02 JDM LOVE
Not So Flossin
my paint for my 02 PSM wrx is in great shape. but i am getting the front bumper rear bumper and hand full of parts painted and put on. i am trying to make my car show ready but been slacking waiting for paint to get done. my questions is more or less how i can get the whole car to look a good as the newly painted additions. i don't think a clay bar is needed, but then again that's why i am asking you. i don't see to many swirl marks or imperfections in the older paint (its gargae and well taken care of). any suggestion's on how i can bring the whole car together looking good for a up coming car show??
-Kyle
RIP EP3 is offline   Reply With Quote
Old 04-10-2008, 03:04 PM   #322
GregsblueRex
Member#: 31997
08 QSM Spec Bizzle
96 XJ Beater
What do you guys suggest using to actually wash the vehicle?
As in...Mitt...towel...rag...sandpaper
I am tired of using my current mitt and I might as well buy whatever works best.
GregsblueRex is offline   Reply With Quote
Old 04-10-2008, 09:47 PM   #323
DetailersDomain
Member#: 165558
I actually went back to using a wool mitt.
Old 04-10-2008, 11:00 PM   #324
RevaL
Member#: 156935
I have a question about einszett shampo premium car wash. There is a cap on top of the bottle but there is no seal on the actual bottle when you open the top cap. Is this normal? This is my first time buying this brand and ussally with other washes I buy they have a seal on the bottle and cap. Thanks for taking the time for looking at my questions all your help is appreciated. BTW that grit guard bucket thing i bought from you works awesome, all the dirt was at the bottom on it and it was nice to see.
RevaL is offline   Reply With Quote
Old 04-10-2008, 11:26 PM   #325
DetailersDomain
Member#: 165558
yes no seal on the bottle. this is normal, none of the premium car washes we carry have a seal on the top.
awesome to see you like the grit guard.
Detailer's Domain HUGE HOLIDAY SALE DetailersDomain Car Care & Detailing 14 02-22-2008 01:19 PM
Detailer's Domain is proud to be a NASIOC Vendor DetailersDomain Car Care & Detailing 22 12-05-2007 10:28 PM
