Old 01-02-2008, 01:53 PM   #76
DetailersDomain
Member#: 165558
Originally Posted by jryan87 View Post
I got my order today from DD...Thanks Im very happy, It came so quickly..And I watched the adams DVD, Very very helpful..cant wait to try everything out : )
Great make sure you take pictures of the work
DetailersDomain is offline   Reply With Quote
Old 01-02-2008, 06:02 PM   #77
retroXvertigo
Member#: 118922
2007 Doggy Doo
Sno-cone
Originally Posted by detailersdomain.com View Post
Don't be intimidated by the PC its a safe machine to use.
See here for the PC videos and removing swirls with it.
http://www.detailersdomain.com/index...on=Custom&ID=3
Depending on what you use for wax the PC can be a great tool.
can the PC also be used to wax? Or is it just a polishing machine?
retroXvertigo is offline   Reply With Quote
Old 01-02-2008, 07:45 PM   #78
DetailersDomain
Member#: 165558
you can use the PC for waxing as well (works best with liquid waxes eg. Adam's Buttery Wax)
Old 01-02-2008, 08:32 PM   #79
retroXvertigo
Member#: 118922
2007 Doggy Doo
Sno-cone
thanks
Old 01-03-2008, 12:19 AM   #80
DetailersDomain
Member#: 165558
sure thing anytime.
Old 01-03-2008, 08:30 PM   #81
GlobalWaste
Member#: 74792
Is there any way, short of power buffing the windshield to get rid of the outline that appears outside the wiper region? Even on sunny days when not using the wipers, it seems the region outside the wiper's area picks up dust and what not a lot more then the area that gets cleaned by the wiper.
Normal glass cleaner isn't cutting it...
GlobalWaste is offline   Reply With Quote
Old 01-03-2008, 11:31 PM   #82
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
I was wondering how I make my headlights clear again. They have started to fog/haze over and I am looking into making them clear again? Thanks.
-Justin
xxxjuhstenxxx is offline   Reply With Quote
Old 01-03-2008, 11:46 PM   #83
DetailersDomain
Member#: 165558
You can try cleaning the window with your window cleaner and then use this polish : http://www.detailersdomain.com/index...ROD&ProdID=131
Old 01-03-2008, 11:54 PM   #84
DetailersDomain
Member#: 165558
-Justin
Justin,
You can try hand polishing them but that might take a while you can use a PC and step down the polishes from aggressive to final polish.
Old 01-04-2008, 12:41 AM   #85
BigD54
Member#: 148280
2007 WRX Limited
UGM
Your website says you can mix the polish with the swirl and haze removal. Is that recommended or is it supposed to be one before the other?
BigD54 is offline   Reply With Quote
Old 01-04-2008, 12:47 AM   #86
DetailersDomain
Member#: 165558
yes depending on the level of cut that you need, you can go with swirl followed by revive or you can go with a mix of swirl and revive. Depends on what you have to fix. Let me know if that helps.
Old 01-04-2008, 01:10 AM   #87
BigD54
Member#: 148280
2007 WRX Limited
UGM
that helps. I only have a few spots that have some haze so would i only use the swirl and haze on those spots and the revive for the rest? The rest of the car doesnt need too much attention.
Old 01-04-2008, 01:22 AM   #88
DetailersDomain
Member#: 165558
BigD54 a good rule to follow is always go with the least aggressive polish on a small section and work you way to a more aggressive polish to compound.
So for your small spot try Adam's Revive Polish, then mix Revive and Swirl, and if that doesn't work try swirl alone.
Old 01-04-2008, 01:36 AM   #89
Daggah
Member#: 152077
2014 Subaru BRZ
World Rally Blue
detailersdomain.com,
Is there anything that I can do with cleaning products about paint damage like this:
Daggah is offline   Reply With Quote
Old 01-05-2008, 02:09 AM   #90
DetailersDomain
Member#: 165558
daggah,
are they scratches or is it etched paint, can't really tell? If they are scratches you might be able to clean it up a bit same with etchings...however it also looks like something caked on the paint. let me know what you think it is and if you can get closer shots that may help.
Old 01-05-2008, 11:14 AM   #91
Daggah
Member#: 152077
2014 Subaru BRZ
World Rally Blue
They're scratches in the paint...I'm not sure what caused them, my car came like this. But I can definitely feel the dips in the paint as opposed to a raised surface if something was caked on.
Here's a cropped section of that same photo from before me scaling it down:
Old 01-05-2008, 04:29 PM   #92
DetailersDomain
Member#: 165558
if your finger catches there is not much you can do except touch it up.
Old 01-05-2008, 11:54 PM   #93
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
What should I use to get rid of swirl marks ect? Should a polish do it? Thanks
Old 01-05-2008, 11:56 PM   #94
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
I used a bunch of different tire glazes over the past summer to see what worked best. I found out there are some really crappy slinging ones out there. One tire glaze I used slung up alot and I was not able to wash my car for a week but when I finally did wash it there was a yellowing in my CGM paint where the tire glaze stuck to my car for that week. I tried everything Meguiars (polish, paint cleaner, clay bar and even Goo Gone) but nothing worked. Any suggestions?
Subydude81 is offline   Reply With Quote
Old 01-06-2008, 12:02 AM   #95
gtlegg
Member#: 67837
04 tahoe
i never really detailed before, always just washed my car with the so called car washes out there. but now i really wanna be able to do it myself, so i do it all by hand, or use the porter cable. the paint its pretty mint minus some rock chips but thats what highway driving does. should i invest in a detail kit (ie the adams kit) or just start off with a few simple products?
Thanks
gtlegg is offline   Reply With Quote
Old 01-06-2008, 12:02 AM   #96
DetailersDomain
Member#: 165558
what do you currently have (polishes) if any?
will you be using a Porter Cable or a machine?
Old 01-06-2008, 12:04 AM   #97
DetailersDomain
Member#: 165558
Thanks
the adam's detail kit is a great start, its got all the basic products plus a dvd and cheat sheet, this is a good base to grow on.
Old 01-06-2008, 12:07 AM   #98
DetailersDomain
Member#: 165558
I would consider using Adam's VRT for the dressing you wont get sling anymore....I've been using this for over 2 years and this product does not sling. It also gives a matte finish.
As for the discoloring do you have pictures?
http://www.detailersdomain.com/index...n=Custom&ID=11
Old 01-06-2008, 12:10 AM   #99
gtlegg
Member#: 67837
04 tahoe
should i invest in the porter cable or just do it the old fashion way by hand
Old 01-06-2008, 12:13 AM   #100
DetailersDomain
Member#: 165558
The porter cable is a great investment, it will definitely give you better results. is it worth it I guess it all depends on what you need to do.
Detailer's Domain HUGE HOLIDAY SALE DetailersDomain Car Care & Detailing 14 02-22-2008 02:19 PM
Detailer's Domain is proud to be a NASIOC Vendor DetailersDomain Car Care & Detailing 22 12-05-2007 11:28 PM
