Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 12-04-2007, 06:59 AM   #1
StoryBookSin
Member#: 85514
2009 Now screwing
Over the PPl of nasioc
Default Headlights are dead, No Speedo, No ABS
I have a 2003 WRX that i was putting the Hella Horns on. I was going to run them to a switch but as i was splicing in the wries to the fuse box i must have grounded out and lost my Headlights, Speedo and ABS. I have the head lights riggered so they will turn on when the car turns on. All my fuses and relays are good to go. Where do i look next? Most likely ill have to follow each wire individually. i know/believe that the problem is after the fuse box in the engine bay, but who knows... Any suggestions from the people in NASIOC land?
Rob
StoryBookSin is offline   Reply With Quote
Old 12-04-2007, 07:04 AM   #2
gte123v
Member#: 114481
2006 Sti
double check your fuses again, as in actually pull each one out and check them (both in the engine bay and the panel on the driver side). If that's not the problem, then you better start taking things apart and check for burned wires, did you smell burning plastic when this happened?
gte123v is offline   Reply With Quote
Old 12-04-2007, 07:30 AM   #3
StoryBookSin
Member#: 85514
2009 Now screwing
didnt smell a thing. the fans kicked on when the headlights shorted out.
Old 12-04-2007, 04:26 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Check for voltage on both sides of fuse #18 in the dash fuse panel.
So my headlights don't work and my wipers are dead OL Off-Topic 7 10-22-2009 12:17 PM
My headlights are dead! thumpetto007 Electrical & Lighting 9 02-15-2008 10:49 AM
left turn signal no work when headlights are on Chuck the swimmer Electrical & Lighting 1 07-05-2006 09:19 AM
Speedo/headlights are not working subaru mike Electrical & Lighting 5 05-24-2004 02:01 PM
No speedo, CE light and stalling - Help? BoomerRS New England Impreza Club Forum -- NESIC 20 12-06-2000 08:55 AM
