Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 12-04-2007, 08:42 AM   #1
Overlord2kx
Member#: 138443
2005 Impreza WRX
Default Which tables need to be tuned for which mods?
Hey everyone,
Im slowly trying to learn to tune myself, and I have a pretty dumb question: Which mods are related to which tables on the ECU?
For example, changing the intake requires tuning of MAF scaling table, changing injectors requires tuning of injector latency among other things, etc etc.
Im not saying I need an EXACT list, but if anyone has a rough summary of the relation between mods and certain changes on the ECU, that would be extremely helpful.
Thanks.
Overlord2kx is offline   Reply With Quote
Old 12-04-2007, 04:47 PM   #2
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
only scale the maf setting w/ a larger than 70mm inlet, inj latency is not for noobs , adj flow scaling for u/g inj.
Basically you can do a fuel tune w/out too many mods being done or any .
sense of nature is offline   Reply With Quote
Old 12-04-2007, 05:40 PM   #3
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
Don't listen to him ^. Any change in intake size (smaller or larger) will require MAF scaling.
06rexwagon is offline   Reply With Quote
Old 12-04-2007, 06:09 PM   #4
quazimoto
Member#: 70395
+1
quazimoto is offline   Reply With Quote
Old 12-04-2007, 06:10 PM   #5
quazimoto
Member#: 70395
Considering the stock one is 65mm...... giving tuning advice isn't for noobs either.
Old 12-04-2007, 06:13 PM   #6
boosteddx
Member#: 129504
2004 impreza
stage 2 OS-Tuning
double post
boosteddx is offline   Reply With Quote
Old 12-04-2007, 06:13 PM   #7
boosteddx
Member#: 129504
2004 impreza
stage 2 OS-Tuning
correctundo...check out osecuroms.org view some base maps and tables and compare them to your stock one to get an idea of chart layout and function with certain mods for example tbe, intakes, uppipes, tmic, boost control solenoids ect. and if you are really worried message braden and see what he can do for you. his maps are affordable and well worth the money.
Old 12-04-2007, 11:05 PM   #8
scraggy
Member#: 136384
06 WRX
Dipped with custom blend
Uh no, my intake is 66.5 mm and I needed to tune it.
scraggy is offline   Reply With Quote
Old 12-04-2007, 11:47 PM   #9
sense of nature
Member#: 112759
SexyRP
So everyone who has a larger than 65 or 66.5 mm intake has had to have they're maf rescaled ? I guess you could ,why ? The ecu does compensate for some degree of change , Unless it's too great a volume ?
Anyway To each tune is their own , My afr's /loggs are strait along w/ my tuned rides , No complaints, no blown decks .
Old 12-04-2007, 11:58 PM   #10
06rexwagon
Member#: 114730
9.8@150
The ecu only does a/f corrections in closed loop. At really high load/rpm you're in open loop and the ecu CAN NOT make fuel corrections. If you're happy with really high a/f correction and learning at low rpm/load I guess that's up to you. Do you even tune with a wideband?
Old 12-05-2007, 12:29 AM   #11
Overlord2kx
Member#: 138443
2005 Impreza WRX
hmm ok thanks for the input so far guys. I guess ill compare some maps to see the changes.
Old 12-05-2007, 09:15 AM   #12
quazimoto
Member#: 70395
100% YUP.Once you change the size of the MAF housing the sensor is no longer in calibration for Openloop operation since it relies on the MAF.O2 feedback is no longer used,which is a good thing because the stock sensor cannot read below 11.25:1 AFR and is pretty unreliable under 13:1 AFR.
http://www.cobbtuning.com/info/?ID=3223
http://www.ecutek.com/tuning/induction/
Old 12-05-2007, 09:23 AM   #13
quazimoto
Member#: 70395
Anything different than stock.How exactly are you tuning openloop?
Old 12-05-2007, 10:50 AM   #14
06rexwagon
Member#: 114730
9.8@150
Nevermind
Old 12-05-2007, 05:07 PM   #15
TheKid
Member#: 153199
02 WRX
Blue/Carbon Fiber
long term and short term fuel adjustments are made in the ecu
TheKid is offline   Reply With Quote
Old 12-05-2007, 05:25 PM   #16
quazimoto
Member#: 70395
Not in openloop,just closed loop fuel correction.Read the links I posted.
What parts does ur car need to be tuned for? streetsweepa617 General Community 43 01-04-2010 03:29 PM
2009 what mods need to be tuned felya589 Newbies & FAQs 7 11-15-2009 04:17 PM
Does an AftaMaf hose need to be tuned for? fulltimeW.O.T. Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-27-2009 12:57 PM
do i need to be tunned for a front mount with other mods stolen04 UTEC 0 02-07-2007 10:36 PM
USDM STi camshafts: Exactly which holes need to be plugged? Si2WRX Subaru Conversions 8 01-01-2007 03:40 PM
