Old 01-26-2002, 07:05 PM   #1
TSDScooby
Member#: 2856
2008 Outback XT
Default Dyno Dynamics Results for cobb cai, stromung mid and ex., and safc
I just came back from a dyno day organized at Adrenalin Motorsports in MA. I was there just out of curiosity and had no real plan in my mind. Just wanted to run the car and see what numbers I would get..
Anyway, I just wanted to share this info even though it is
common knowledge what numbers to expect with these type of mods.
Car: 2000 2.5 RS sedan
Mods: Cobb CAI, Stromung SS mid-pipe, and exahust, and
S-AFC.
S-AFC settings:
High Thrtl Settings:
3000 : - 5%
3500 : -10%
4000 : -11%
4500 : -12%
5000 : -13%
6000 : -15%
Low Thrtl Settings set all to 0%
Low Thrtl. point: 25%
High Thrtl. point: 75%
Results:
HP: 118.3 @ 5500RPM
Torque: 125 @ 4000RPM
Cheers,
TSDScooby
-Emilio
TSDScooby is offline   Reply With Quote
Old 01-26-2002, 07:12 PM   #2
TSDScooby
Member#: 2856
2008 Outback XT
Default A/F ratio
A/F ratio graph:
Old 01-26-2002, 07:58 PM   #3
nomorefocus
Member#: 9677
2002 2.5 RS
What kind of gain is that over stock?? It's to bad somebody didn't do a stock run on that same dyno because without it there is no way to see any kind of gains or anything.
What kind of 1/4 mile do you run now?
nomorefocus is offline   Reply With Quote
Old 01-26-2002, 08:01 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Unfortunately its not much use to most people without a stock curve, or at least the brand and dyno type used. That way people can at least try and compare.
Midwayman is offline   Reply With Quote
Old 01-26-2002, 08:46 PM   #5
TSDScooby
Member#: 2856
2008 Outback XT
Yup. I knew I was missing that.
Excuse my ignorance I thought the brand was Dyno Dynamics... I will get that info and post it.
a 2.5 RS (not my car) stock posted 105 HP the same day I did this on the same dyno...
Cheers,
TSDScooby
-Emilio
Old 01-26-2002, 09:09 PM   #6
nomorefocus
Member#: 9677
2002 2.5 RS
"a 2.5 RS (not my car) stock posted 105 HP the same day I did this on the same dyno..."
I wonder why some dyno's show like 120hp stock... My Ford Focus could put out 105hp to the wheels stock and 115 hp with my mods, yet I know my RS is quicker.
Old 01-26-2002, 09:12 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
My stock 2.5GT dyno'd at 106.6hp a couple months ago on this dyno, and dyno'd at 100.5hp today on this dyno. So, basically you're looking at somewhere around 100-105hp for a stock 2.5L car.
Pat Olsen
'97 Legacy 2.5GT sedan
Edit: nomorefocus posted while I was typing. To answer his question, the numbers are different depending on the type of dyno used. The dyno at Adrenalin Motorsport is a Dyno Dynamics Low Boy, which is a load-bearing eddy-current type dyno. Load-bearing dynos will always produce lower numbers than an inertia type dyno (such as a Dynojet or Dynapak), and load-bearing dynos are supposed to be more accurate than inertia type dynos.
Old 01-26-2002, 09:20 PM   #8
traskw
Member#: 9604
2005 LGT '94SS MR2
AtlanticBlue, Red, Silver
Where is MA is Adrenalin Motorsports? They have an AWD dyno?
traskw is offline   Reply With Quote
Old 01-26-2002, 09:27 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Old 01-26-2002, 09:55 PM   #10
etam
Member#: 439
www
Thanks for sharing the data!
One thing I want to say is:
97 GT is DOHC
00 RS is SOHC (supposed more torque??)
Ernest
etam is offline   Reply With Quote
Old 01-26-2002, 10:16 PM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Originally posted by etam
97 GT is DOHC
Ernest
True, but the peak power is the same on both engines, and even peak torque is only off by 4ft-lb according to the factory ratings.
Pat
Old 01-26-2002, 11:35 PM   #12
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
You want a stock curve? You got one! I did a stock run on my 2000 RS today, here are the charts:
HP & Torque:
<img src="http://www.wpi.edu/~msawaya/hptorque.png">
HP & A/F R
<img src="http://www.wpi.edu/~msawaya/hpairfuel.png">
Marc Sawaya is offline   Reply With Quote
Old 01-27-2002, 12:32 PM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Your graphs aren't coming through for some reason, Marc. I noticed the same thing in the NESIC thread.
Pat
Old 01-27-2002, 03:32 PM   #14
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
That's strange. They should work now.
Request: WRX Dyno Sheet for Cobb AP Stg 2 + Sti Inyectors and VF34 blindstuff Proven Power Bragging 0 01-30-2006 11:41 AM
FXT 4EAT Dyno Dynamics results - 258tq 239hp AaronB Proven Power Bragging 2 12-08-2004 01:03 AM
Injen Posted dyno results for their CAI run on a 2004 WRX trustWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 73 01-24-2004 05:07 AM
Dyno Day results for me! Force[FED] Tri-State Area Forum 35 11-19-2003 12:37 PM
Relocated sensor for Cobb CAI. Is it OK? OsakaGangsta Normally Aspirated Powertrain 8 08-30-2001 05:46 PM
