Old 01-27-2002, 01:24 AM   #1
mike270
Member#: 12863
2002 2.5RS
Default What mods will help gas mileage??
I don't get on the gas too often but still only get 20mpg (city)....I have seen things that say they help mileage but do anyone of them work.. (ie intake, other fuel mods, etc.)???
Thanks
mike270 is offline   Reply With Quote
Old 01-27-2002, 02:23 AM   #2
phish
Member#: 10199
2000 Impreza 2.5rs
Blu Ridge Prl
you can try spiral max.....they say they can give you better gasmileage, + some horses, but all i've heard is crap about their product. try it if you want......
spiral max
phish is offline   Reply With Quote
Old 01-27-2002, 02:51 AM   #3
Imprezard
Member#: 3016
CBA GH8
WR Blue
Tornado fuel saver, as seen on TV
j/k, I don't know if it works.
Some people on the board said it's BS, but no constructive reason...
Imprezard is offline   Reply With Quote
Old 01-27-2002, 07:51 AM   #4
spd wgn
Member#: 8571
2002 wrx
put one extra large egg (uncooked) under the gas pedal
spd wgn is offline   Reply With Quote
Old 01-27-2002, 08:02 AM   #5
Chuck_Beef
Member#: 9903
2001 Impreza RS RIP
intake, exhaust, any sort of weight reduction. Anything to make the car more efficient.
Chuck_Beef is offline   Reply With Quote
Old 01-27-2002, 08:42 AM   #6
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default A good tune-up
Change your fuel filter, air filter, spark plugs, wires, clean your throttle body, go synthetic oil and the car should run smoother and more efficient. Probably even give you back a couple of horses too!!!
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 01-27-2002, 10:01 AM   #7
FastPorsche
Member#: 11125
2000 Impreza 2.5 RS
Silverthorne
Default Uni-Chip
For more power and more Miles per gallon go with Uni-Chip.
Find more at www.fastforwardperformance.com
Or E me with Questions
FastPorsche is offline   Reply With Quote
Old 01-27-2002, 11:04 AM   #8
bbbradley
Member#: 7715
2000 Miata
BRG-ish
Waste of money...
http://www.miataforum.com/ubb/ultima...&f=11&t=004433
/bill
bbbradley is offline   Reply With Quote
Old 01-27-2002, 01:22 PM   #9
rak328
Member#: 3858
Any mods that lean out the fuel will help your gas mileage if you can stay off the loud pedal. I got the unichip and I get 1-2 mpg more on the freeway when cruising but when driving hard it sucks gas worse than a V-8.
rak328 is offline   Reply With Quote
Old 01-27-2002, 02:53 PM   #10
Jon [in CT]
Member#: 2992
02 WRX Sedan
I don't believe that the Unichip can prevent the WRX's ECU from maintaining a 14.7:1 air/fuel ratio while cruising. Thus, the Unichip can't improve cruising fuel economy.
Jon [in CT] is offline   Reply With Quote
Old 01-27-2002, 03:43 PM   #11
mike270
Member#: 12863
2002 2.5RS
So an intake improves gas mileage???
SWEET!!! (if it's true)
Old 01-27-2002, 05:59 PM   #12
FastPorsche
Member#: 11125
2000 Impreza 2.5 RS
Silverthorne
Not Flaming you dont get bent,
You are wrong the Uni-chip allows complete tuning of ign, fuel, and boost map ( more in other applications)and can increase MPG as well as economy
Old 01-27-2002, 07:12 PM   #13
Austin
Member#: 7089
2016 STi
A large wood block under the gas pedal.
Austin is offline   Reply With Quote
Old 01-27-2002, 07:14 PM   #14
SubEd
Member#: 717
Remove the spare tire, jack, etc. Just don't get a flat....
SubEd is online now   Reply With Quote
Old 01-27-2002, 07:24 PM   #15
Austin
Member#: 7089
2016 STi
Put a horse collar on SubEd and have him pull your car instead.
Old 01-27-2002, 07:25 PM   #16
SubEd
Member#: 717
Thank you, Master! (Can I also don my rubber undies??).
Old 01-27-2002, 07:29 PM   #17
Austin
Member#: 7089
2016 STi
You can wear the entire rubber gimp suit as far as I'm concerned
Old 01-27-2002, 07:32 PM   #18
SubEd
Member#: 717
You talk pretty tough for a guy that's all the way across the country! :monkey:
Go Patriots!
Old 01-27-2002, 07:36 PM   #19
Austin
Member#: 7089
2016 STi
And you seem to be fairly normal... for a guy who owns a closet full of rubber clothes...
Old 01-27-2002, 07:40 PM   #20
SubEd
Member#: 717
Yes, but I've only been on The Jerry Springer Show twice!
(and this poor guy thought he was getting info on improving gas mileage!)
Old 01-27-2002, 07:46 PM   #21
Austin
Member#: 7089
2016 STi
To get back on topic...
Instead of a large wooden block under the gas pedal, place a large rubber block below the gas pedal... You could still go WOT, but you'd just get really tired doing it, so it would happen less...
Old 01-27-2002, 10:49 PM   #22
Asinus
Member#: 6435
2016 Honda Fit
I've been getting pretty decent mileage recently.. my only mods are ganz intake and k&n. 24-27 mpg for me... although I haven't been pedal happy.
Asinus is offline   Reply With Quote
Old 01-27-2002, 11:49 PM   #23
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
oh crap....i guess i must REALLY be pedal heavy cause the last time i filled up on gas my mpg was 17!!!!!! is that even possible? normally its just city driving for me, no freeway.
sidenote: where do you guys go to get gas??? shell,exxon, both cost more and they're more "brand name gas"...i buy cheap-o gas from HEB grocery store...do you think that might affect mpg?
Penguinking is offline   Reply With Quote
Old 01-28-2002, 02:42 AM   #24
Jung918
Member#: 10969
What about a ignition booster liket he Jacob's Ice Box...? If it is true then you would have more complete burn...
Jung918 is offline   Reply With Quote
Old 01-28-2002, 09:29 AM   #25
chuckpo
Member#: 8370
2002 Subaru WRX
Black, Gold 17" Wheels
Default gas mileage
The best answer to good gas mileage is to slow down and avoid quick take off from a stop.
to penguinking: The worst gas mileage and worst performance will be from cheap low octane gas. I would NEVER put that garbage in my REX. It is more important to me than a few pennies that you save with that inferior gas.
Just my .02
chuckpo is offline   Reply With Quote
What happened to my gas mileage? clsmooth Vancouver Impreza Club Forum -- VIC 21 02-03-2008 04:02 AM
What would give better gas mileage? Arnie General Community 27 07-31-2006 05:38 PM
Will a CAI help gas mileage? Moshpit552 Newbies & FAQs 59 07-09-2005 11:50 PM
What happened to my gas mileage? edgross1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-14-2002 11:55 AM
Simple ???: What Mod Would Increase Gas Mileage? ejicon Legacy Forum 19 03-17-2001 12:45 AM
