South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-05-2007, 10:13 PM   #1
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
Tuned @ FAT by Snail Perf
Default Question to you guys up in Flag and cold weather.
Do your cars run rough during the snowy winter months? While I was up there and at the Grand Canyon there was a constant high-pitch sound coming from my engine at idle. I was worried that it could be my belts or my radiator but now that I'm back in Phoenix it sounds completely normal. Ideas?
Edit: Not just at idle either, also at higher RPMs.
BugeyePB Rex is offline   Reply With Quote
Old 12-05-2007, 10:31 PM   #2
TixArmy
Member#: 134248
2007 STi-Stage2 -RIP
"Desert Sand on White"
Flag is just like Connecticut is now - Cold... Very... Very...Cold... (wonder why I moved?)
First question is why type of Oil are you using? I have noticed that if I didn't change over to the 5w30 from the 10w30 I was using, then my engine did seem a bit rough. (not that it should hurt anything, but it was noticeable.)
Could be many other things I know, but that is my 1st thought.. my 2 cents if you will.
Side note- when I changed over to 5w30 for these few 'cooler' months here in the valley, I noticed my car was acting Diff... so - who knows....
TixArmy is offline   Reply With Quote
Old 12-05-2007, 10:40 PM   #3
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
Oil weight stayed the same 10w-30 Castrol Syn. However, I've made trips up to Flag when I was running Mobil 1 10w-30 and there wasn't anything wrong. I hope the oil isn't the culprit...
Old 12-06-2007, 11:17 AM   #4
dunc_b
Member#: 154343
My car feels a tad ropey in the mornings after being left out overnight...
The gear shift is very notchy and the engine feels tight... I just put it down to it being a lot colder recently and the oil not being sloshed around the gearbox until it's turned a few times - by the end of the road all is normal...
come to think o fit - I feel ropey most mornings too
dunc_b is offline   Reply With Quote
Old 12-06-2007, 11:21 AM   #5
r0bman
Member#: 87015
Ha. Try <20 degree (Farenheit, you silly European) mornings. It was a bitch to get my STi into first gear if I didn't let it warm up a bit.
r0bman is offline   Reply With Quote
Old 12-06-2007, 11:22 AM   #6
racingfish
Member#: 60976
1969 LGT
FATURBO
raise the flag in cold weather?
racingfish is offline   Reply With Quote
Old 12-06-2007, 03:02 PM   #7
BugeyePB Rex
Member#: 138915
2003 WRB WRX Vf48
All of the things that you guys are mentioning happened. However, it was the engine in particular. Dunno, if it wasn't a Sunday I would have taken it to the Subaru dealership up there or something, but nobody was open.
Old 12-06-2007, 03:06 PM   #8
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
I had the same problem last christmas, then on the way home I lost my header to uppipe gasket
Most likely not your problem.
My car is always weird when I go to Flagstaff even if its in the summer (I go once a month and stay the weekend)
v8eaterWRX is offline   Reply With Quote
Old 12-06-2007, 05:28 PM   #9
Keyser
Member#: 82168
07 dyno-comp'd
CGM WRX Wagon
Prolly the altitude. Phoenix at 1200 ft, Flag is around 7000.
Keyser is offline   Reply With Quote
Old 12-07-2007, 01:51 PM   #10
dunc_b
Member#: 154343
Originally Posted by r0bman View Post
(Farenheit, you silly European).
HAHA
I was in the weird chsool year they did the switch so I understand fareinheit as well as the correct celsius
now what I don't understand is inches - they're just stupid!
Old 12-07-2007, 06:07 PM   #11
pyrex
Member#: 45757
2005 WRX STi
CGM/Silver
My car runs just fine when it's cold up here in Flag. In fact it runs much better then it does when it's hot out, just don't run super heavy oil especially if you park it outside. Flag doesn't get very cold though.
pyrex is offline   Reply With Quote
Old 12-07-2007, 07:38 PM   #12
ram95
Member#: 121051
08 8k RPM
Vtak HoNdUh
Justin you dont know what you are talking about Have you been out side today???
I have to leave the FXTS out side over night and when i first start it it sounds rough and the first few times i put it into gear it doesnt feel too lovely. It just needs to warm up for a bit. by the time i am a mile from my house it feels fine again
ram95 is offline   Reply With Quote
Old 12-07-2007, 09:56 PM   #13
Clayton
Member#: 121184
2004 WRX
Ya my car runs a little rougher during the winter months, and first gear is nearly impossible to get into if im even rolling 2 mph lol...
Clayton is offline   Reply With Quote
2.5i Idle and Cold Weather Questions. kruga225 Normally Aspirated Powertrain 10 11-08-2007 03:53 PM
Question to all those with Modded injectors and cold starting? 2002WRXSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 12-23-2004 12:57 AM
TXS stage 4 and cold weather.... carpetsloth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-26-2002 10:29 AM
Perf Tires and Cold Weather kpratte Brakes, Steering & Suspension 1 06-29-2001 09:41 AM
Turbos and cold weather -> special measures? Mr. Jones Technical Forum Archive 5 09-06-2000 09:32 PM
