Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 12-06-2007, 02:48 PM   #1
Member#: 24977
2003 WRX
Default Difference between the A, B and C maps
I haven't owned a WRX since '03 but am planning on an '08 STi. I've been looking into Enginuity (engine management has come so far since I owned a subbie!).
I've been messing around with Enginuity using a stock DBW STi map and a Stage 1 STi DBW map. So far I pretty much get everything. One thing I'm not getting though is why there are "A", "B", and "C" version of the fueling, timing and boost maps?
DocDetroit is offline   Reply With Quote
Old 12-06-2007, 03:59 PM   #2
Tea cups
Member#: 103136
First, make sure you download and install the latest Enginuity ECU and logger definitions:
ECU: http://forums.openecu.org/viewtopic.php?t=3029
logger: http://forums.openecu.org/viewtopic.php?t=3030
It looks like you are looking at an 07 USDM STi ROM. For target boost and initial wg duty, for this ECU, only 2 of the 3 maps are potentially used (this is reflected in the new ecu defs). The 3rd table (renamed "unused" in the new defs), is there for compatibility with those who own Accessports and are using Enginuity to tune with.
We do not know exactly when every multiple table (A,B, etc.) is switched. If it were known, then they would be renamed as such. In most cases, only one table is active. If you wish to learn more about this, check out the description in the logger def post above for the map ratio extended parameters which will allow you to determine the active table(s) for some tables by logging and also explains the potential ramping behavior.
None of the CANbus models (08s+ or 07+ FXT/LGT) are supported by Enginuity or Ecuflash. We have to wait until Colby of Ecuflash comes up with a flashing method and a new tactrix cable. Until then, no support for these models is possible through the open source tuning methods.
Tea cups is offline   Reply With Quote
What are the differences between the 2002 WRX and the 2003 WRX? Red Rexx Newbies & FAQs 43 04-18-2008 07:02 PM
Anyone who knows clear differences between the 06 TR and the 04 WRX... Rally_WRX1 General Community 14 09-12-2006 09:58 PM
Differences between the BMW 325 and the 328? Sephro Off-Topic 8 08-10-2005 09:15 AM
What`s the difference between the US wrx and the one in Europe/Asia aWeX General Community 3 07-26-2002 02:53 PM
What's the difference between the US Imprezas and the Japanese WRX? Subies General Forum Archive 15 10-03-2000 06:44 PM
