Old 12-06-2007, 02:50 PM   #1
mistaanime
Member#: 137287
02 WRX
Default just installed vf39 on a 02 wrx CEL
ok so i just put in a vf39 on my 2002 wrx and i took it out for a drive. As i am going everything is fine and then i came to a stop. I wanted to try to see how fast it takes off and as i am working up to the red line area car stalls for a moment and check engine flashed and then i just changed to 2nd and it does the same thing as i am lurking up the redline area..i was just wondering if its normal...
I am running cobb accessport v2
vf39
07 sti BLUEs injectors
Walbro Fuel pump
catless xs power 3in dp and exhaust.
ssautochrome tmic.
cobb intake.
Running VF39-S ACN 91oct MAP
mistaanime is offline   Reply With Quote
Old 12-06-2007, 02:57 PM   #2
sti-ish
Member#: 164675
2003 Wrx
MBP
i have pretty much the same set up in my car....it also flashes when i get on it pretty hard...mine didnt hesitate though....when i read it, it said that it was miss-firing...i had it checked out and everything was all good...Do you have an after market fly wheel??..Sometimes they will throw a miss-fire code due to the Lightness....hope i could help a little
sti-ish is offline   Reply With Quote
Old 12-06-2007, 03:24 PM   #3
mistaanime
Member#: 137287
02 WRX
haha nah nothing..stock flywheel and clutch.
Old 12-07-2007, 11:42 AM   #4
mistaanime
Member#: 137287
02 WRX
bump.
Old 12-07-2007, 02:56 PM   #5
Spec V to Wagon
Member#: 129715
03 Wagon
Called a bigger turbo. Read the codes with the AP and tell us what they are.
My guess is you should get tuned.
Spec V to Wagon is offline   Reply With Quote
Old 12-07-2007, 03:06 PM   #6
jack klompus
Member#: 152885
2014 Malibu LTZ
right on^^
Read your codes and get a damn tune.
jack klompus is offline   Reply With Quote
Old 12-07-2007, 03:17 PM   #7
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I'd suggest you get a protune. My car gained over 30whp with a custom protune over OTS map.
fubarud, nice whp!
Old 12-07-2007, 04:04 PM   #8
Spec V to Wagon
Member#: 129715
03 Wagon
fubarud, nice whp!
Want my honest opinion? Dump the AP for like $300 and get tuned via OpenSource and the go
Old 12-07-2007, 07:37 PM   #9
mistaanime
Member#: 137287
02 WRX
hahaha so...you guys are saying once i get it tuned..everything will be alrgiht from there on out? i am ready for a tune too lol..i just wanted to make sure everything was ok before i take it in. btw my cluster gauge is acting hella weird..the speedo is kinda bouncing like when im driving 60 mph..it would be boucing from 58-61 mph on the speedo and the temp gauge goes up and down a little..but on the AP everything is fine. lol..there is CEL 1,2,3,4 cycliders misfireing.
Old 12-08-2007, 10:50 AM   #10
jack klompus
Member#: 152885
2014 Malibu LTZ
Try clearing the codes, better yet do a battery reset.And clear the codes with the cobb. Make sure your map is a base map and not a realtime map. Plus is the cobb map you are running correct for those injectors?
Oh and dont beat on it at all. I saw when you got to redline you started having problems. Cobbs map is just good enough to get you to your tuner without blowing up. Its not a actual performance map.
Old 12-08-2007, 12:01 PM   #11
mistaanime
Member#: 137287
02 WRX
good advice..i'll try that when i get off of work...but i know what your saying about the maps..i just wanted to know if it was normal..that it doing this until i get a protune...lotta people are saying its not normal..but some are saying that it is..and that i just need to get a pro tune and bam..fixed..and ++ horspower.
Old 12-08-2007, 03:27 PM   #12
Foska Oats
Member#: 144081
2003 WRX
The battery reset is a good effort, but getting a tune would be the best thing.
Let the tuner look at everything. Then you both go out and run it hard as hell, to ensure that there are no more issues.
Foska Oats is offline   Reply With Quote
Old 12-08-2007, 10:54 PM   #13
mistaanime
Member#: 137287
02 WRX
ill try that when i get home.. thanx for the advice. sounds like a good idea tho.
Old 12-11-2007, 11:23 AM   #14
mistaanime
Member#: 137287
02 WRX
tried...same thing occurs..takin it to DB tunning probably this friday.
Old 12-11-2007, 11:35 AM   #15
sjrexwagon02
Member#: 141896
2002 STi Wagon
Sedona Red Pearl
good descision
i saw almost 60 whp gain from a protune vs Cobb OTS map
302whp 285 ftlbs on a vf34 though but you should be in the same area
sjrexwagon02 is offline   Reply With Quote
Old 12-11-2007, 01:09 PM   #16
mistaanime
Member#: 137287
02 WRX
damn that would be sweet...I am hopeing for 300whp...how much was it to get protune?
06 Wrx Just Installed Vf39 Turbo And Tbe, Now White Smoke From Exhaust! Help lordizzy626 Newbies & FAQs 10 02-12-2010 03:10 PM
Questions on installing vf39 on 06 wrx? brian06wagon Newbies & FAQs 2 11-24-2009 01:52 PM
02 WRX CEL on after IC hoses installation! danpalms15 Newbies & FAQs 2 10-03-2009 05:27 PM
Just installed VF39/Pinks/Walbro; Boost not stable Noah Open Source Reflashes 1 12-29-2008 06:15 PM
considering a vf39 swap on my 02 wrx ict-wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 07-10-2007 07:32 PM
