Old 12-06-2007, 04:25 PM   #1
JMS77
Member#: 136833
Default 07 STI Ltd, SZ49....Dyno Graph...Precision Tuned
MODS: Perrin FMIC
GT SPec Header
1 step Colder Plugs
TXS Intake/Walbro
SZ 49/TBE(HKS/Invidia-with cat)
APS-Inlet/Fuel Rails
PE 850/TGV Del.
The reason that there are 2 runs is because I had to fix the MAF scalar and fuel curve...it was a little out of wack with the intake....MAF scaling is a PITA to get right...lol The RED is the final tune.
The car is very linear, I am considering going with a TD06-20g/8cm for a little better spool. I will wait until after I put the Meth Kit in next week. I want to see if the car takes to a little more aggressive AVCS map with the meth before I completely ditch the turbo.
The car is tuned at Precision Tuning(LAkewood-NJ) for 21.8 psi on 93 Octane, with a conservative timing curve. I really try to make my tunes as linear as possible, AVCS has really helped with that.
Thanks for looking,
John
The link to the run is in the next thread....389HP397TQ
JMS77 is offline   Reply With Quote
Old 12-06-2007, 04:30 PM   #2
03 RS
Member#: 81227
2012 Wrangler 4DR
Gecko Green
Default posting graph for john
03 RS is offline   Reply With Quote
Old 12-06-2007, 05:22 PM   #3
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Lean for quick spoolup?
wcbjr is offline   Reply With Quote
Old 12-06-2007, 06:28 PM   #4
stealth06wrx
Member#: 131568
2006 WRX to 2015 WRX
OB Swirl / DGM
looks like a/f ratio need to be touched up a bit. Its going rich right in the middle there
stealth06wrx is offline   Reply With Quote
Old 12-06-2007, 08:26 PM   #5
crazymikie
Member#: 56321
2006 Honda El Camino
Green
it almost looks like the cl/ol settings- maybe they need to be modified a bit.
crazymikie is offline   Reply With Quote
Old 12-07-2007, 01:05 AM   #6
JMS77
Member#: 136833
You know it is very funny you say that. I was experimenting with the settings to see how it effected spool/knock. After this run I shifted it back about 350RPM. Very sharp observation. As you will see with my other tunes, I absolutely shift the OL/CL transition back. This is my car so I have a bit more freedom to play around.
Thanks.
John
04 STi Slowboy Gt35r Dyno Graph, Need opinion roccrew585 Proven Power Bragging 48 11-12-2007 12:15 PM
Rear pink sway bar problem on 07 STi Ltd dasnowman Brakes, Steering & Suspension 2 11-07-2006 05:23 AM
Factory Sub/Amp for 07 STI Ltd 06STIGO13 Car Audio, Video & Security 0 10-25-2006 01:31 PM
anyone looking for an 07 sti ltd?? never_summer Texas Impreza Club Forum -- TXIC 21 10-11-2006 08:39 AM
What cable to I need for 07 STI Ltd aux in? 06STIGO13 Car Audio, Video & Security 12 10-02-2006 01:59 AM
