Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 12-06-2007, 09:06 PM   #1
skyline31
Member#: 72588
Default Is low speed in high gear (5th) causing knock easily??
If driving in low speed with high gear (5th), will it cause knock easily??
skyline31 is offline   Reply With Quote
Old 12-06-2007, 09:26 PM   #2
STIBungy
Member#: 51684
I've picked up alot of false knock in the lower rpms in any gear. Usually between 2-3.5k.
STIBungy is offline   Reply With Quote
Old 12-07-2007, 02:11 AM   #3
Badler
Member#: 133597
If you floor it at low RPMs, yeah, easiest way to knock.
Badler is offline   Reply With Quote
Old 12-07-2007, 10:19 AM   #4
Dynasty336
Member#: 103561
2006 STi
Hmmm i tend to try to get through my gears as quickly as possible to get to 5th or 6th and usually im cruising in 5th or 6th at 2k rpms or so. So would it be better for me to cruise around in 4th at 3-4k rpms or so instead (I have a lot of 40mph speed limits around me) ?
Dynasty336 is offline   Reply With Quote
Old 12-07-2007, 10:40 AM   #5
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
just don't accelerate too hard and you'll be fine.
Old 12-07-2007, 12:46 PM   #6
Badler
Member#: 133597
I have to do the same, 40mph in 4th . I generally don't like to be in 5th or 6th at <2700 rpms. Boggy and a lot of engine load when accelerating.
Old 12-07-2007, 12:57 PM   #7
WRXJAY03
Member#: 121824
07 SwP STI - HeRs
05 AW STI - MiNe
going to 2.5rpm will be fine.. jus dont go any lower.. its hard on the engine.. If you start hearing bogging noise jus step on the gas a little and youll be fine.
WRXJAY03 is offline   Reply With Quote
Old 12-07-2007, 12:58 PM   #8
Badler
Member#: 133597
No, that is the problem. Downshift.
Old 12-07-2007, 01:22 PM   #9
Menik
Member#: 105966
2005 Cobb Stg2 STi
w/ WRX Wing & Roof Vent!
Maybe I should search, but why is this? Also, define "low" rpms...
Are you saying that cruising in 5th or 6th gear at less than 2500rpm is bad for the engine? I may be way off base, but that sounds absurd... I cruise on the freeway at ~2000rpm all the time, and when I put the pedal down to pass someone, there's hesitation, but I've never noticed detonation... I was under the impression that it was just turbo lag?
Menik is offline   Reply With Quote
Old 12-07-2007, 01:36 PM   #10
Badler
Member#: 133597
No, but when you floor it to speed up it is putting an amazing amount of stress on your engine.
Old 12-07-2007, 02:31 PM   #11
Menik
Member#: 105966
2005 Cobb Stg2 STi
I see. That makes sense. I don't think I've ever floored it in that situation; mainly because it just makes more sense to downshift if you need to get moving fast very quickly. Still, though, would that strain on the engine really cause detonation? I would think it would be more likely to lead to mechanical problems, no? Just curious...
Old 12-07-2007, 02:36 PM   #12
Freon
Member#: 88322
2009 BMW 135i
This has been asked, answered, and discussed several times. Do a search for false knock or low rpm knock.
Freon is offline   Reply With Quote
Old 12-07-2007, 04:44 PM   #13
Badler
Member#: 133597
Detonation = Mechanical problems.
Old 12-07-2007, 05:08 PM   #14
Menik
Member#: 105966
2005 Cobb Stg2 STi
I always thought that detonation lead to mechanical problems. (eg: things melting, breaking under extra stress, etc.) Not arguing, just trying to learn.
Old 12-07-2007, 11:00 PM   #15
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Correct
sense of nature is offline   Reply With Quote
Old 12-08-2007, 03:38 AM   #16
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Just tune the car correctly. It should be set up to handle a WOT load in any gear at any RPM. The problem is 90% of professional tunes only tune for WOT pulls from around 2000rpm to redline in one gear, with (if you are lucky) a little bit of road tuning for drivability.
When I tune I spend a lot of time tuning low RPM load sites at various throttle angles for this very reason. I do a 5th gear pull starting from like 1200rpm and I just floor it while datalogging, and I let it pull till about 4000RPM or so just so I can hit the load sites in that range. (obviously that isnt the only pull and gear I use, but I do it so I can get those load sites. I want a good solid tune everywhere.)
As far as detonation=mechanical problems, it doesnt always cause problems. All it takes is one det event to blow a motor, but it doesnt have to be the first event. It could knock for years and never blow, or it could knock once and lose a piston. If detonation blew motors every time, then every early 04 STI and every 06+ STI and most 06+ WRX's would have blown motors the first time someone floored it. Luckily that isnt the case.
Defiant Autospeed is offline   Reply With Quote
Old 12-08-2007, 07:07 AM   #17
hotrod
Member#: 14141
2002 Impreza WRX
It depends on the engine load! If you are on a slight down hill you can cruise at light throttle 5th gear at 1500 rpm. There is almost no load in that situation. If on the other hand you are pulling a long gentle up hill you would not want to pull the engine down below about 2000 - 2200 rpm (depends on which engine too, 2.0L will not pull as low an RPM as the 2.5L). The engine will tell you when you are working it too hard at low rpm if you will just pay attention to it. If you feel a vibration or surging sensation as you increase throttle, that is the engine struggling to pull the load, down shift. If it readily accepts additional throttle you are probably okay.
Have you ever ridden a multispeed bicycle and accidently shifted up to a gear that is too high where you can barely push the peddles down? That is what you are doing in a car when you are in too high a gear for the load. Like on the bicycle if you are on level terrain or a slight down hill you can peddle a long gear, as soon as you hit a small up hill you suddenly cannot create enough pressure on the peddle. Inside the engine you push cylinder pressures and bearing loads through the roof when you over load the engine in a high gear, and you are setting up ideal conditions for severe detonation since engines are much more prone to detonation and damage due to detonation under those conditions.
Larry
hotrod is offline   Reply With Quote
Old 12-08-2007, 08:59 AM   #18
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Yep, its in the tuning forums.
I had this problem as well, here was my resolution:
http://forums.nasioc.com/forums/show....php?t=1327893
cucamelsmd15 is offline   Reply With Quote
Old 12-08-2007, 10:52 AM   #19
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
Hasn't anyone heard of downshifting? lol.
I do agree with what Defiant Autospeed just said. Most tuners will not test the car from a low-RPM WOT pull in 5th gear ON THE ROAD. This is an absolute must if you want to be able to use 5th/6th for accelerating on the highway without downshifting.
t
WolfPlayer is offline   Reply With Quote
Old 12-08-2007, 11:07 AM   #20
Badler
Member#: 133597
Yeah, I guess that was little vague. But still pretty true.
Old 12-08-2007, 12:48 PM   #21
reddoak
Member#: 147628
2013 Beep beep
it's a Jeep.
I think that downshifting rather than bogging is pretty much common sense, here.
I suggest an automatic to those opposed to downshifting a manual.
reddoak is offline   Reply With Quote
Old 12-08-2007, 01:02 PM   #22
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Agreed, but it should still be tuned in that area.
Old 12-08-2007, 01:17 PM   #23
reddoak
Member#: 147628
2013 Beep beep
it's a Jeep.
Well, yeah, but even if he's tuned correctly, it's poor driving, and pretty straining on the car. Accelerating that is, not cruising.
Old 12-08-2007, 02:56 PM   #24
Davenow
Member#: 23676
true
I dont downshift to pass in 5th gear. But I have an FXT which has 4.44 final drive, and a 20G setup, which I have spent a LOT of time tuning low throttle angle load sites. But at 65ishmph, I am well past 2000rpm anyway so I guess its kinda irrelevant.
Even so, a ported/polished exh manifold, larger up pipe, catless TBE, TurboXS tmic (easier breathing by a longshot) and the large exh housing on my turbo all contribute to a LOT better "off boost" throttle response and power, which makes low RPM work a lot less strain.
Still, its a turbo car, not an NA car. sub 2k rpm isnt going to be good for power.
Old 12-08-2007, 02:59 PM   #25
Davenow
Member#: 23676
false knock is almost always real knock. Especially at low rpm/high load.
true story.
Tranny clunk under low RPM in high gears causing hesitation tr3 Transmission (AT/MT) & Driveline 0 03-03-2006 06:46 PM
Is low-speed engine bucking bad? volkl23 Newbies & FAQs 2 09-04-2004 10:44 AM
Low speed using high gears Azjon Newbies & FAQs 20 11-01-2003 08:48 PM
Top speed in each gear? WS6toWRX Proven Power Bragging 9 01-27-2003 04:11 AM
Low Boost in first gear SubiDo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-15-2002 09:51 PM
