Old 01-27-2002, 04:40 PM   #1
meatman
Member#: 10943
1996 Legacy L
Grandma Green
Thumbs up Ground Control for Legacy?
I have been looking for a cheap way to put together a ajustible hight coil over system. A few people have mentioned ground control but i have not be ble to find any for a legacy. Is there a kit for legacy my1996 if so where do u buy them and do u think it would be a good idea for ground controls with AGX's. If there are no GC's how does gt springs with AGX's sound. Thanx for the help
-ben
meatman is offline   Reply With Quote
Old 01-27-2002, 06:40 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Ground Control makes their famous sleeves for Subaru.
Any suspension part that fits an Impreza will almost certainly fit a Legacy.
Keep in mind that the Legacy is heavier, but they should give you higher rate springs as well.
DLC is offline   Reply With Quote
Old 01-28-2002, 11:15 AM   #3
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Exclamation
It remains my intent to do a GC/AGX combo in my car. The Whiteline (wagon?) springs have spring rates of 190lbs/in front and 160 lbs/in rear (correct me if I'm wrong) for a spring giving a 1 inch drop. I expect that you would be best served with springs with either the same or slightly stiffer rates in the GC (something like 225f and 185r)*.
  - Eric
    '98 2.5 GT Wagon - Pics - Page -
    ICQ #: 9292601
<small><i>* The author of this message has pulled these numbers entirely from his backside. Please treat them with the same caution you would afford anything coming from that source.</i></small>
Radio Flyer is offline   Reply With Quote
Old 01-28-2002, 12:32 PM   #4
RandyF
Guest
Member#:
..will almost certainly fit a PRE-MY2000 Legacy.
True that... there are springrate guides around, and I thought there were some for GC.
A
Old 01-28-2002, 05:12 PM   #5
meatman
Member#: 10943
1996 Legacy L
Grandma Green
Thanx for the help but, they DO make them for suby's? However i whent to the GC web site and they didn't list any subaru's. So where can i buy them?
Old 01-29-2002, 10:28 AM   #6
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Exclamation
Call 'em. They do Subies.
Old 01-29-2002, 11:19 AM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
1st Rule of Subaru Aftermarket: If you don't see it on their site, they probably make it.
Call 'em, i know a number of people using them on 1G Legacy Wagons, and there are a lot of GC8 Impreza owners using them as well.
Old 01-29-2002, 04:24 PM   #8
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
I have Ground Controls on my 99 Legacy with currently 250/225 rates with 8" springs. I am still a little bouncy. I wanted to go down to 200/175 in 9" springs because of the bounce, for one, and reason two is that even with 250/225 rates when I have the car raised all the way up the weight makes the car ride height a little under stock.
Unfortunitely they don't make 9" springs in rates other then 315/280 = Way too Stiff!!!!
Good Luck,
Brad
MY99 2.5GT is offline   Reply With Quote
Old 01-29-2002, 05:20 PM   #9
meatman
Member#: 10943
1996 Legacy L
Grandma Green
My99 2.5 gt what kin of shocks ae u using and could that be contributing to the bounce? also it sounds ike GC isn't for me becase i wnated to get them so i could raise my car up for my grandparents moutain property oh well thanx any way guys
Old 01-30-2002, 02:43 PM   #10
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
I am using FHI Ver 5 struts.
I used the struts on my Legacy before in combination with H&R Sport Springs and had no bounce problems.
I'm trying to replicate that ride qaulity with the Ground Conrtols except I will have the ability to adjust the height of the car.
I guess I will now search for springs that will work with my Ground Controls but with rates that I want and in a length that I want.
Old 01-30-2002, 03:37 PM   #11
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Are you using the stock top mounts?
I noticed a huge, very noticeable difference with my coilovers when i swapped in the STi top mounts. It's also a common cure for bounciness on the DMS and Teins.
Just a thought.
Old 01-30-2002, 03:52 PM   #12
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Up till now it has been cheaper to pay only shipping to swap out softer springs from Ground Controls used bin. I have a few options to weigh.
used ground controls for 02 wrx sonic_wrx Private 'Wanted' Classifieds 1 07-21-2006 03:15 AM
FS: Ground Controls for 02-03 Impreza Incl. WRX $280 obo Iroc8210 Private 'For Sale' Classifieds 1 08-01-2005 10:50 PM
Ground control kit for GC on '96 Legacy wagon? annointed Legacy Forum 2 02-03-2005 09:15 AM
anybody ground their agx for Ground Control before ? DEVO-2nd GEN Vancouver Impreza Club Forum -- VIC 3 06-04-2002 07:44 PM
Ground Control Legacy spring rates? seowitz Brakes, Steering & Suspension 19 10-23-2001 01:21 AM
