Old 12-08-2007, 12:47 PM   #1
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
Default just getting started and had some Q's
i just got someones older laptop and finally upgraded the memory (from 256mb!!!) and the first thing i wanted to do was get enginuity and data log and then try and figure out what it all ment.
first, what other open ecu software is there and is it worth getting or should i wait for enginuity to come back?
second, i think the first thing i wanna do is get this mbc off of my car and put on a GM bc solenoid. what things would i need to change in the boost part of my stock map?
third, which prolly should be first, where can i read up on this stuff and figure out what to do and what not to do?
thanks for the help in advance
romanlynch is offline   Reply With Quote
Old 12-11-2007, 10:41 AM   #2
krisco
Member#: 113135
Im in the same situation as you. Wish there was like a tuning tutorial
krisco is offline   Reply With Quote
Old 12-11-2007, 10:44 AM   #3
Tea cups
Member#: 103136
Read the "Enginuity down..." thread - you can find a link to the Enginuity software and definitions at a temporary mirror.
Tea cups is offline   Reply With Quote
Old 12-11-2007, 12:36 PM   #4
romanlynch
Member#: 126684
02 wrx
i read some of that but i didnt notice that part, thanks
also is there a write-up anywhere i can read on that GM bc?
Old 12-11-2007, 02:45 PM   #5
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
since I failed at the search, how is the gm unit better than the stock one? does it hold more boost?
Wheeler Bement is offline   Reply With Quote
Old 12-12-2007, 12:34 PM   #6
romanlynch
Member#: 126684
02 wrx
geez theres only 1000 threads about this just in the 2.0 forum, how many more do ya need??????? j/k its an improvement over stock as it can hold more boost and its more acurate (sp?) also its only $30ish for the solenoid and pigtail from your local GM place
Old 12-13-2007, 10:49 AM   #7
gutano
Member#: 147673
06 STI
My understanding of it:
GM allows you to hit a greater variance of targets (but changing your targets requires possible timing/fuel adjustments)
To simply hit your stock targets (pre-tune?) some scaling and recalibration of Initial Wastegate Duty map(s) (I've heard .7 of stock values is a good start, bump up as needed). Also the engines response to over/under boost via the Turbo Dynamics tables (Integral/Proportional) will likely be too extreme (I don't recall good numbers for this).
Please search for a more informative post before acting on this, this is meant as a rough summary.
gutano is offline   Reply With Quote
Old 12-17-2007, 10:11 PM   #8
romanlynch
Member#: 126684
02 wrx
so i just downloaded 0.4.1b, do i need subaru standard units definitions, standard units definitions, or standard units logger definitions? where do i put the files if i need them?
ie would the logger def's go in enginuity->src->enginuity->logger->definitions->xml?
Old 12-17-2007, 10:17 PM   #9
Tea cups
Member#: 103136
You need the Enginuity ecu defs 0.8.0b (standard (i.e. imperial units) or metric units depending on your preference). Unzip the ecu_defs.xml file which replaces the same file in the main Enginuity directory.
Also need Enginuity logger defs 0.3.2b (standard or metric). Unzip the logger.xml file which replaces the same file in the main Enginuity directory.
For Ecuflash, you can also DL the 0.8.0b ECU defs for Ecuflash (standard or metric). To install, DELETE the Subaru folder in the openecu\ecuflash\rommetadata directory and then unzip and place the new Subaru folder in the same directory (if you are unsure of this directory, you can look it up in File->Options (metadata directory) from within Ecuflash.
Old 12-18-2007, 12:23 PM   #10
romanlynch
Member#: 126684
02 wrx
sweet, thanks
Old 12-19-2007, 12:23 PM   #11
romanlynch
Member#: 126684
02 wrx
well i was gonna start logging last night with a cable that my brother scrounged up when he had his audi but it was a com port and my laptop doesnt have one of those. i remember reading about a deal where you can get the tactrix cable and the LC-1 or it might have been the LM-1 wb o2 and i was wondering if someone had that link? does that package come with a gauge too or would i have to get one myself?
Old 12-21-2007, 12:28 PM   #12
romanlynch
Member#: 126684
02 wrx
well i found the website and it doesnt come with a gauge, but it will work with any of the 5V analog gauges out there.
just bought a catback apexi exhaust and had some questions goose05 Newbies & FAQs 11 08-16-2006 08:54 PM
Ok, just getting started here gregor2001 Newbies & FAQs 23 07-03-2005 11:24 PM
just getting started nickster Member's Car Gallery 2 12-13-2003 09:09 PM
('93-'01) New and have some Q's Monkeyballs Impreza Forum 2 06-29-2001 01:03 AM
please help me out, car hurt and need some q's answered on aftermarket parts 98mpreziveRS Technical Forum Archive 4 08-03-2000 05:50 PM
