Old 12-09-2007, 01:05 PM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default the battle between dom3 and sz55
2 great turbos...1 damn car. im in for a turbo upgrade for my rex... but cant come to my senses on which 1 to get. 99% street driven still. Any comments? I prolly cant live with lots and lots of lag so... ya, advice advice advice.
i have the ssac fmic, coolingmist varicool stage 2, some other minor supporting mods. will be dropping DW injectors as well. im also hooked up with UTEC and might be switching to openecu. The drive train is totally stock and i dont want it to get toasted real quick. some kind soul pls.
jacky599r is offline   Reply With Quote
Old 12-09-2007, 01:34 PM   #2
j87w
Member#: 123349
06 wrxsti
aspen white
Kind of WRX? What year? Are you setting up a car for drag racing or road racing? Need lots more info to help you
j87w is offline   Reply With Quote
Old 12-09-2007, 01:51 PM   #3
jacky599r
Member#: 137631
2006 WRX
Red
2006 rex, stock internals and tranny. road racing.
Are the 2 very much different? how abt reliability? some guys mentioned the dom3 needs more psi to achieve the same power another turbo of its class
Old 12-09-2007, 02:41 PM   #4
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
Both will make short work of your transmission. If you don't want it to "get toasted real quick" you probably shouldn't be looking at 52+ lb/min turbos.
With that being said, I would lean towards the Dom3 for a 99% street driven car. I've seen some (well tuned and well supported) 2.5's make full boost by 3700 on the 3.0R. SZ55 will probably be a little laggier.
KevlarSTi is offline   Reply With Quote
Old 12-09-2007, 05:22 PM   #5
MGAMAN
Member#: 24671
2010 Audi S4 PP
2006 R1 - 06/08 hybrid
You could scale back a bit; go w/ the Dom 2.5, its a sweet turbo from everything I've seen and heard; and the issues that it had earlier were resolved; faster spooling and a ball bearing turbo.
MGAMAN is offline   Reply With Quote
Old 12-09-2007, 08:07 PM   #6
MattPersman
Member#: 139385
get the SZ55, if you are even thinking of going that big, might as well. trans will break eventually no matter which one you choose, so throw that out of your mind and just focus on your turbo/power goal.
30r would be better if it is in your budget
MattPersman is offline   Reply With Quote
Old 12-09-2007, 08:41 PM   #7
Hines
Member#: 116398
08 STI OBP
Tuned By Agile
what, no GT52 turbo?? . think the gt52 is right there with the dom III an sz55.
just installed my 52 this weekend an get it tuned on wed.
Hines is offline   Reply With Quote
Old 12-10-2007, 03:29 AM   #8
jacky599r
Member#: 137631
2006 WRX
Red
how abt spool characteristics? dom3 gets a full BB. sz55 thrust bearing... so effective usable power on the street, doesnt it mean the dom3 has an advantage.... i dun always gun the car throttle to the metal also... so. ya.
Old 12-10-2007, 06:46 AM   #9
MattPersman
Member#: 139385
spool is going to vary on way too many factors of your setup. should a 52lb wheel spool faster with BB compared to a 55? sure. will it? hard to say, you would have to do the 2 back to back same tuner same day.
some dude might say yeah I have the Dom 3 and it spools at 3500, some dude might say no way my friend has it and it sucks and only spools at 4800.
both should be similar, may want to run it by whoever is going to tune your car based on there experience. maybe they have made a ton of power on SZ55s or had bad luck with them
Old 12-10-2007, 06:49 AM   #10
jacky599r
Member#: 137631
2006 WRX
Red
aight, anyone has the logs for both? or point to me a thread that i can find the comparison between them...
any idea the CFM @ 1 bar?
Old 12-10-2007, 12:01 PM   #11
jacky599r
Member#: 137631
2006 WRX
Red
help......
Old 12-10-2007, 03:31 PM   #12
albie1kanobi
Member#: 101607
06 Subaru STi
[email protected] has logs of his dom3, i think 26psi by 3600rpm.
albie1kanobi is offline   Reply With Quote
Old 12-10-2007, 04:23 PM   #13
Paintballguy
Member#: 77810
2006 Evo IX SE
Tarmac Black
dom 3 is the same as the gt52 except the dom 3 has the garrett ball bearing chra.
Paintballguy is offline   Reply With Quote
Old 12-10-2007, 06:48 PM   #14
WOR440
Member#: 106807
---> 2011 EVO X
I have a Dom III right now, great all around turbo. But I want more already.
WOR440 is offline   Reply With Quote
Old 12-10-2007, 07:50 PM   #15
jacky599r
Member#: 137631
2006 WRX
Red
wo.....dom3's quite a fast spool turbo man consider its size.
sz55? damn.... i need one new turbo real quick...
Old 12-11-2007, 03:31 AM   #16
keaniegenie
Member#: 94494
2005 Element 92x
Upgrade your trans. A legacy GT 1-2 setup will at least help a ton if you take it easy in 1st. OEM stock clutch will be your friend.
GT52. Spool is ridiculous and will reliably get you around 450whp on your current setup. Phil was hitting 436whp on almost the same setup you have but was losing boost due to not having an EWG on the dyno (held boost perfectly on the road). That means he was probably between 450-460whp considering he was holding 2 more lbs of boost on the road.
http://www.elementtuning.com/Turboch...bochargers.htm
keaniegenie is offline   Reply With Quote
Old 12-11-2007, 03:46 AM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.......with either turbo, you WILL soon shred the clutch, trans, and rearend.....probably in that order, unless you break an axle or something else somewhere in between.
That much power requires some serious thought about the driveline first, IMO.....or ya might want to start looking for a wrecked STi NOW......and have all the parts on hand, ahead of time
Old 12-11-2007, 04:04 AM   #18
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
GO speak to Mike - he has Dom 4.0R coming out early n
wrxsti.l is offline   Reply With Quote
Old 12-11-2007, 08:47 AM   #19
jacky599r
Member#: 137631
2006 WRX
Red
^ nah... it seems too big for my appetite... i mean with the dom3 or sz55 alot of things are on the verge of breaking... i cant imagine what a 3.5R will do to my car. Besides, i need a responsive BIG turbo, fun to drive and doesnt take donkey yrs to spool and before i know it, its time to upshift. SO..... DOM3?! yes?
Old 12-11-2007, 08:53 AM   #20
jacky599r
Member#: 137631
2006 WRX
Red
Old 12-11-2007, 08:54 AM   #21
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
oops - typo.
I meant Dom 4.0R is based on the GT3540 BB CHRA - the Dom 3.5R is based on the GT3040 BB CHRA :P
Old 12-11-2007, 09:18 AM   #22
jacky599r
Member#: 137631
2006 WRX
Red
whaha..same man.
wats ur mods like? so i can use it as a benchmark
Old 12-11-2007, 09:20 AM   #23
jacky599r
Member#: 137631
2006 WRX
Red
haha, doesnt matter...its big or hella big.
anyway, wats ur mod like? wanna use it as a benchmark
Old 12-11-2007, 09:03 PM   #24
jacky599r
Member#: 137631
2006 WRX
Red
some thoughts, will it be dumb to buy a dom3 and run it at 1 bar? i went through the airflow calculator and approx power i could get will be say 394g/sec? which is like wat close to 400whp? i think by that time things are starting to give way ya?
Old 12-11-2007, 09:06 PM   #25
Paintballguy
Member#: 77810
2006 Evo IX SE
Tarmac Black
1 bar would be nowhere near 400whp as its only like 14.7psi. You would need like 22psi to get that power.
The Battle Between The Vendors & The Dealership Rages On wackit Vendor Reviews 27 06-08-2005 03:03 AM
The Official "Who would win in a battle between Pirates and Ninjas" thread MattDell Off-Topic 17 11-22-2004 12:18 PM
Are the gauge wiring the same between Autometer and HKS? jarelee Electrical & Lighting 3 09-19-2004 03:19 AM
anybody know the diff. between GT and OB springs? sybir Legacy Forum 5 05-01-2001 07:10 PM
what is the difference between V4 and V5 wings Cata Vancouver Impreza Club Forum -- VIC 1 09-28-2000 08:47 PM
