Old 12-09-2007, 04:07 PM   #1
ferrari355
Member#: 144246
2006 WRX TR
Default Will a Cobb AccessPort void the warranty?
Hello,
I was curious on was found about warranty issus with upgrading to Cobb access port 2...I have herd this does leave a mark on the ecu...in the way of a different checksum to it not leaaving a trace...let me know your experiance. Thanks....Jeff
ferrari355 is offline   Reply With Quote
Old 12-09-2007, 09:15 PM   #2
layzienoy
Member#: 91505
I would assume that any kind of ecu modifications could and most likely would lead to the denial of a warranty claim on the powertrain as you are adding more power than the car had stock and changes to the programming of the fuel computer is pretty easily used as a cause for some type of failure. I have heard that it does leave some trace in the ecu programming when it is hooked up to the diagnosis. if you were to get one i wouldn't try to hide it if you need service as that makes you look like you broke something and are trying to cover it up, i've heard of and seen honesty take a person pretty far.
layzienoy is offline   Reply With Quote
Old 12-10-2007, 09:04 AM   #3
bo9877
Member#: 31452
1995 Legacy L FWD
Power Windows & Locks!
Yes, honesty can take a person far, but it is definitely not a given. To be on the safe side, assume that the AP will cause a warranty denial on any failed powertrain components. Can you afford to pay out of pocket for a new engine or transmission? If the answer is "no" or "yes, but it would really hurt," play it safe and don't modify your car. Have fun with it for 60K miles, save up some money during that time, then go all out when the warranty has expired.
bo9877 is offline   Reply With Quote
Old 12-10-2007, 01:20 PM   #4
jarvis210
Member#: 129547
2004 WRX Sti
Platinum Silver Metallic
mod that ***** from day one.....when you play you will pay....
jarvis210 is offline   Reply With Quote
Old 12-10-2007, 02:16 PM   #5
JoePokah
Member#: 154734
2005 Legacy GT LTD
lol that is a good quote on the flip side....
I am going to say i would drive it AT LEAST til 25-30k without modifying it if you cant afford a new transmission or engine. You want to make sure nothing major goes wrong. If you know how to pull a tranny and replace it/rebuild it or put in a new clutch and what not.... then maybe it wouldn't hurt as bad. You can find trannys on here, the thing they kill you on is labor. But ya +1 to whoever said that if you cant afford it... dont do it. **** breaks when you drive your car hard... i know bout that one and <=== this is what you look like when it actually happens. just my $.02
Jeff
JoePokah is offline   Reply With Quote
Old 08-12-2008, 07:57 AM   #6
mikessti1
Member#: 185561
2010 WRX
grey
Get a Cobb Access Port.Switch back to the stock ECU Mode.No trace on ECU.Period!
As long as there in no other visible mods,we all should be fine with the Warranty
mikessti1 is offline   Reply With Quote
Old 08-12-2008, 03:06 PM   #7
rkramer
Member#: 118209
2015 WRX Limitec
nope...
yes there is a checksum that will be changed by an AP, and no, your average dealership PROBABLY isn't going to check it, at least until you need a new engine.
Old 03-10-2014, 10:21 AM   #8
Trumpet112014
Member#: 384143
2014 Wrx
Graphite Grey
Default Accessport warranty question
Yes, just spoke to my Subaru mechanic, in any power train related failure, step 1 is to research the ecu. Nothing is invisible.
Trumpet112014 is offline   Reply With Quote
Old 03-10-2014, 10:22 AM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Well good job on bumping the thread from 2007 to tell him.
Old 03-13-2014, 01:15 AM   #10
Trumpet112014
Member#: 384143
2014 Wrx
Graphite Grey
Default Cobb accessport
Yes, after speaking with a Subaru mechanic, the first thing that will be checked if it's anything power train related (as instructed by SOA), is the ecu. SOA will find out if you flashed your ecu which in turn allows them to deny warranty. So if your turbo goes out prematurely and you are only stage 1, your outta luck.
Old 03-13-2014, 03:45 PM   #11
MaddMax
Member#: 9264
2016 BMW M235i 6MT
They won't know if you change back to stock and are using a Cobb AP.
MaddMax is offline   Reply With Quote
Old 03-13-2014, 07:55 PM   #12
sc00by4life
Member#: 97135
All evidence suggests the opposite.
But either way, we don't promote warranty fraud on this forum.
Old 03-13-2014, 09:28 PM   #13
heavyD
Member#: 194216
2016 MK7 Golf R
Originally Posted by rkramer View Post
nope...
When you uninstall AP it puts back your original factory tune therefor the checksum would be the same as the one last recorded by Subaru when your car left the factory or when a dealer performed an update.
According to Cobb there is no flash counter so they should find no actual evidence you changed your tune. The dealer can tell when the ECU was reset so if you uninstall it the day before you bring the car in it does look suspicious but they really can't prove that you didn't disconnect your battery for some reason.
heavyD is offline   Reply With Quote
Old 03-14-2014, 04:05 PM   #14
sc00by4life
Member#: 97135
Originally Posted by heavyD View Post
When you uninstall AP it puts back your original factory tune therefor the checksum would be the same as the one last recorded by Subaru when your car left the factory or when a dealer performed an update. According to Cobb there is no flash counter so they should find no actual evidence you changed your tune. The dealer can tell when the ECU was reset so if you uninstall it the day before you bring the car in it does look suspicious but they really can't prove that you didn't disconnect your battery for some reason.
Multiple Subaru employees have posted that the checksum values are not changed by un marrying an AP.
Old 03-21-2014, 10:57 AM   #15
jason02wrx
Member#: 222893
2016 WRX DGM Limited
2002 WRB/2012 SWP Hatch
From what I know Cobb took advantage of some "extra"unused memory space that cannot be reversed upon removing the ap from the ecu. Any knowledgeable dealership service dept should pick up on this if they have a reason to look.
jason02wrx is offline   Reply With Quote
Old 03-21-2014, 09:17 PM   #16
trife86
Member#: 301368
2012 WRX
PBP
I have not heard of this
trife86 is offline   Reply With Quote
Old 03-21-2014, 09:41 PM   #17
jason02wrx
Member#: 222893
This has been discussed before. Bottom line...is that ap (or any other em) worth a warranty claim for $texas$ being denied? If you choose to go that direction and something breaks be honest and be prepared to pay.
Old 03-21-2014, 11:26 PM   #18
heavyD
Member#: 194216
2016 MK7 Golf R
Never heard of this and have a hard time believing this is plausible.
Old 03-22-2014, 08:41 AM   #19
jason02wrx
Member#: 222893
Search the other 500 threads about thus and you will see. You will also see that this was never directly answered by Cobb when presented to them.
I don't sit around making up ****. You can believe it or not. Have a friend who works for Subaru with a SSM3 tool?
Old 03-23-2014, 11:22 AM   #20
pawingo
Member#: 384447
2014 WRX hatch
It depends on Cobb's engineers and what they learned from reverse engineering the SOA ECU. Using unused memory space when 'attacking' embedded systems is very common. A popular method is to load custom code onto unused memory, and modify 1 line of the stock instruction set to call the custom code.
If this is the case, and Cobb wrote to unused memory space while 'Marrying' the AP, the can ZERO out the memory space used when umarrying it. The information we are trying to get a hold of exposes the innerworkings of the Cobb AP which is treated as closed IP as well as the innerworkings of the Subaru ECU also closed IP. (Don't expect straight answers from Cobb or SOA)
The real questions that need to be answered are the following:
1. Does marrying an AP change the Check Sum?
2. Does unmarrying the AP revert the CheckSum to factory?
3. Does the Subarau ECU Bootloader keep statistics on reads/writes?
4. Is the checksum calculated from only the loaded rom or all flash memory or just eeprom?
Answers to #3 and #4 would provide the necessary information on whether #1 and #2 occur. However, #1 and #2 can be answered without #3 and #4. All we need is a Scooby mech with a scooby and an AP with some free time to test. If the tools the mechs have are publicly available, then I might consider trying to get a hold of one (depends on price and reuseability) to test this out myself.
P.S- I am a scooby noobie but a software engineer by trade that specializes on life-critical embedded systems.
*Edit* Forgot to mention, we a scooby mech that is currently trying to get a straight answer to these questions from his Master Tech in this post
Hopefully we get some good info as the ECU Checksum stuff is debated as much as climate change and if you read the forums long enough, half say checksums change from stock even when unmarrying the AP while the other half claim it reverts to stock.
pawingo is offline   Reply With Quote
Old 03-23-2014, 01:13 PM   #21
Mdsiman
Member#: 360019
2013 Wrx
I'm sure they have other ways to tell if the ecu was tampered with. I believe on the new mustang gt when you unmarry there tuners the ecu counts how many times the motor was started after each flash. So if you have 8k miles and your motor blows and get it towed to dealer and shows 0 starts there going to deny your claim.
Idk if that's true or not but I have read it on there forums.
Mdsiman is offline   Reply With Quote
Old 03-23-2014, 01:20 PM   #22
pawingo
Member#: 384447
2014 WRX hatch
Hopefully ScubySnacks answers this once and for all on the other thread. Sounds like we find out on monday.
Old 03-23-2014, 01:22 PM   #23
Mdsiman
Member#: 360019
2013 Wrx
Eh I still think if you put a tune on the car just be ready if a warranty claim is denied.
Old 03-23-2014, 09:31 PM   #24
shotz86
Member#: 253506
2014 WRX
I found this thread to be helpful when i was asking myself the same question.
http://forums.nasioc.com/forums/show....php?t=2142671
shotz86 is offline   Reply With Quote
Old 03-24-2014, 07:20 AM   #25
pawingo
Member#: 384447
2014 WRX hatch
Thank you shotz! I think this answers it. Maybe that ^^^ thread should be a Sticky under Technical-> Engine Management -> AccessPort sub forum.
will a turbo timer void the warranty? svr_wrx Texas Impreza Club Forum -- TXIC 13 10-25-2006 11:55 AM
Dealer: synthetic oil will void the warranty on your STi. Bradus Service & Maintenance 27 04-27-2005 06:09 AM
Will a BOV void the warranty? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-23-2001 12:28 PM
Will installing a BOV void the warranty ? Jewbaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-30-2001 12:07 AM
will pully installed void the warranty? raptor Canada Region Forum 3 05-14-2001 04:59 PM
