Old 12-09-2007, 04:26 PM   #1
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
Default Full race twin-scroll header question
I don't see in any of the pictures of their twin-scroll header design a provision for the front stock O2 sensor? Looking at ultimate-racings twin scroll setup I don't see one either. So where do they expect you to put the front O2 sensor?
Or a bigger question which 2 cylinders do you choose to tap for the O2 bung? Or do you simply put the O2 sensor after the turbo to get all cylinders into the equation? But isn't the front O2 sensor meant to operate under a fairly narrow range of temps that might be to low after the turbo/first common collection point of exhaust gases?
davidm_sh is offline   Reply With Quote
Old 12-09-2007, 04:59 PM   #2
root
Member#: 55854
2004 STi
Blue/silver
The Full-Race kit puts the front O2 sensor in the downpipe. And the exhaust is still plenty hot immediately post-turbo. Plus my logging of my moved O2 sensor versus my wideband show no adverse effects.
root is offline   Reply With Quote
Old 12-10-2007, 09:18 PM   #3
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
root - thanks for the reply. That is correct, the o2 sensor is relocated to the downpipe. The reason for this is that a twinscroll configuration only has 2 pulses to read from, due to the cyls being seperated.
as a result, the o2 readings are not as accurate as if they were post-turbo, reading from all 4 cylinders. if you have any other questions feel free to ask!
Full-Race Geoff is offline   Reply With Quote
Old 12-29-2010, 02:13 AM   #4
Scoobydroo
Member#: 266345
2002 impreza wrx
white
i went on the full race site and the kit under the 02 twin scroll kit does not say that it fits the 02 just 05 and up. also is it possible to get just the header and up pipe?
Scoobydroo is offline   Reply With Quote
Old 12-29-2010, 11:07 AM   #5
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
yes - you can order just the header and up pipe AND it will fit the 02 **ONLY with an sti oil pan**
Old 12-30-2010, 09:30 AM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Hey, I call foul. It took some effort to get our pan to work with your header
KillerBMotorsport is offline   Reply With Quote
Old 12-30-2010, 10:36 AM   #7
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Full-Race is working on an oil pan for 2011 release
Old 12-30-2010, 10:45 AM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Ah... I see what you did there
Old 12-31-2010, 01:52 AM   #9
sorrowfulkiller
Member#: 170439
I <3 Lamp
Is there a "Like" button on Nasioc yet?
sorrowfulkiller is offline   Reply With Quote
Old 12-31-2010, 02:54 AM   #10
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
The factory sensor actually reads more accurately in the post-turbo position than in the stock position, since it no longer gets confused by the high pressure in the up-pipe. I've been running my Legacy this way for a couple years... shortly after Root (above) proved it could work.
Dyno Comparison: Full-Race twin Scroll HTA35r vs Tial .63ar GT35 TopSpeed Proven Power Bragging 234 07-06-2011 10:43 AM
Full Race twin scroll HTA gt3076 1.06a/r 380/364 **1/4 mile info** armyssoldierboy Proven Power Bragging 68 11-06-2010 10:34 AM
Full Race Twin Scroll GT4088R > Cosworth High Compression; prelim. logs are up syoung0298 Proven Power Bragging 217 07-21-2010 08:35 PM
Full Race Twin Scroll Kits APS04silverwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-21-2007 08:04 PM
Full-Race twin scroll 35r updates..? sti.2005.blk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 10-12-2007 02:37 PM
