Old 12-10-2007, 01:02 PM   #1
thummel26
Member#: 153511
2004 STi
WR Blue
Default Running with test mode on??
Hey, ive got my car tuned using enginuity/OpenECU, and to make flashes easier ive got a switch under the passenger side dash that turns the test mode on and off. Driving in the country yesterday with my girlfriend, i do a quick accel from a stop sign and notice im seriously down on power. boost is only going to 13 psi (tuned for 18) and spool is horrible.
So im thinking i hit a spot of bad gas, got some knock, computer dropped the IAM below 0.35 and turned off the boost solenoid (no cel tho whiah i thought was weird).
I get home and plug in my comp to see if thats the case, but when i turn my car off and turn it back on again check engine light is flashing and i notice my test mode switch is turned on.
Basically, is it possible that my girlfreind might have tripped the switch with her legs or something? is it even possible for the car to run with the testmode turned on, while driving? Thanks.
thummel26 is offline   Reply With Quote
Old 12-10-2007, 01:18 PM   #2
TheShad0w
Member#: 91925
2015 WRX STi
AWDTuning.com
Yes, the car can run in test mode - I'm sure what type of impact it would have though...
TheShad0w is offline   Reply With Quote
Old 12-10-2007, 01:21 PM   #3
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
not that i recommend it or anything but i know a dude who ran his car for 6 months in test mode cuz his dumbass tuner left the test leads plugged in when he was done.
Dirty25RS is offline   Reply With Quote
Old 12-10-2007, 01:24 PM   #4
thummel26
Member#: 153511
2004 STi
WR Blue
haha, alright thanks guys. well i would assume that the car would run like crap with the test mode turned on. i cant see the computer using the normal settings while its in diagnostic mode.
Old 12-11-2007, 12:42 AM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
lol...that reminds me i just tried to read my ecutek 06 STi and left them connected....
im not even drunk either....
that would have been a great thread title though..
Old 12-12-2007, 11:42 AM   #6
ravenhil
Member#: 113774
2002 Impreza WRX
wow that can;t be good. but i tried driving a short distance with the green cnnectors on cuz pluggung and unplugging them is such a b1tch
ravenhil is offline   Reply With Quote
Old 12-14-2007, 02:49 PM   #7
3barboost
Member#: 73609
2002 wrx
running with test connectors connected gives an AM of 8 or .5
this simply means that less timing is added if stock
however you can use this for a simple and crude "dual map facility"
set the fuel map switch parameter at 8 or .5 - the ecu has 2 fuel maps - be smart and tune accordingly then change the disable / enable boost switch poitn as well and presto if you can live with a flashing cel you got the ability to run lo / hi boost and diff maps at the price of some tuning time and logging - the key is to remember that the ignition advance table can take -numbers in certain areas only do this if you understand the ecu and its abilities
I use this for lo boost (literally actuator tension) and poor fuel with lean mixtures and very low loads and aggressive timing - makes for good economy ! with green connectors connected
then for hi boost disconnect connectors - am goes to 16 and boost is enabled and with more boost comes more load and the other fuel map comes into play
your tune for both has to be spot on ! but with experience its possible
3barboost is offline   Reply With Quote
Old 12-16-2007, 11:41 PM   #8
crazymikie
Member#: 56321
2006 Honda El Camino
Green
does avcs work with the connectors connected?
i know my car throws a whole slew of cells if they are connected and you drive.
crazymikie is offline   Reply With Quote
Old 12-22-2008, 03:20 PM   #9
chanders
Member#: 131319
2003 JDM STI
World Rally Blue
Bump for replies!
Anyone knows if the green connectors still work with an EcuTek tune?
chanders is offline   Reply With Quote
OS tuned Running with Air con on Kastley85891 Open Source Reflashes 5 03-30-2008 08:28 AM
How To: Go in to test mode with out connecting the green connectors every time. t4nk AccessPort 3 04-26-2007 03:26 PM
car not going into Test mode with AP Lordhowe Engine Management & Tuning 2 08-27-2005 04:32 PM
Fog lights running with high beams on? bwolf33 Legacy Forum 15 03-17-2003 10:35 PM
