Old 12-12-2007, 11:36 PM   #101
remowgn
Member#: 41149
09 FXT
SSM
Originally Posted by S14guy View Post
Am I crazy? I thought the stock NON bbs wheels were only 17"????
All USDM cars will come with 18" wheels. The JDM cars have a 17" option, so 17's should still fit without any problems.
remowgn is offline   Reply With Quote
Old 12-13-2007, 12:34 AM   #102
Shabib67
Member#: 61749
So why is the redline 6500rpm? Did they change something in the engine to reduce the redline? And is it possible to up the redline to 7000rpm with a flash and for it to be safe?
Shabib67 is offline   Reply With Quote
Old 12-13-2007, 12:52 AM   #103
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Oh baby! Can't wait for you to unleash this beast!
volkl23 is offline   Reply With Quote
Old 12-13-2007, 01:43 AM   #104
poopy
Member#: 142286
does any1 know the bolt pattern on the wheels?
poopy is offline   Reply With Quote
Old 12-13-2007, 02:19 AM   #105
OA5599
Member#: 47050
2004 STi
aspen white
PCD 5/114.3 and offset +55
OA5599 is offline   Reply With Quote
Old 12-13-2007, 02:29 AM   #106
poopy
Member#: 142286
thanx, oh well was hoping they would fit the lgt
Old 12-13-2007, 02:49 AM   #107
poopy
Member#: 142286
the jdm 08 sti wheels are 5x100. japanparts has them for sale
Old 12-13-2007, 09:26 AM   #108
tshrey
Member#: 29370
2002 WRX Wagon
WR Blue Pearl
Also, all the 17" on the japanparts site says that they will not fit VDC equipped cars - all the USDM ones have VDC, so we might be stuck with 18"...
tshrey is offline   Reply With Quote
Old 12-13-2007, 11:23 AM   #109
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Not with that IDC.
gabedude is offline   Reply With Quote
Old 12-13-2007, 12:32 PM   #110
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Originally Posted by turb04 View Post
I see a rear carbon fiber wing coming soon..lol
We have a great idea in this department, just wait!
Originally Posted by tshrey View Post
What is with those IDC's?!?! I had planned on actually leaving this thing alone for a while with just a downpipe and a tune; hitting 94% duty cycle on the injectors in a stock setup is nuts unless the map is running crazy rich. Everyone is going to need injectors just to add a downpipe and tune...
Nope 18's, and they are much better in person, than in the pics you have seen.
Originally Posted by Frank A View Post
Maybe I'm using the wrong terminology. By variable-geometry, I meant that fins would be more widely spaced where the "sti" used to be, then they would be denser, with more of them maybe 1/2"-1" into the core. This would reduce the pressure drop for outside (cool) air flowing through the core to cool the intake charge. As you said, the TMIC is limited in cooling, and this was an idea to improve the air flow on the cold side to improve the effective cooling. I've heard of people talking about these cores, but have not been able to find the actual product on the net anywhere, or even a good picture of one. I also don't have the math down to prove that this would make a difference, but the cold side of those standard bar+plates looks so restrictive, and I suspect that the cool side air is coming into the engine bay at a relatively low pressure. Just brainstorming a bit...
Frank
Got it! With every core, we vary the geometry. For instance we have a core that is not 3/8" fin and bar on both hot and cold sides. It comes down to the ambient air flow, and how restrictive we make the core. When building these, we use ambient air flow, Charge air flow , and pressure drop to figure in what is the best combination. It just so happens that on our normal TMIC, 3/8" and 3/8" works best.
Originally Posted by gabedude View Post
07 STI IDCs are worse!
Judging by MAF g/s I'd say they are using the same injectors as the 07 STI. This car is just leaned out more with a better cooling system and better pump with upped FPR. A little birdy told me it is the same turbo that is on the legacy, but that is probably wrong, it is proabbly the same VF43 on the 07 STI. 15 Peak PSI (relative to sea level) it seems, so it may be the same 07 STI engine with new heads (exhaust AVCS) and better cooling. My drive magazine mentions stuff about improved cooling ducts, intercooler and a higher flowing fuel pump. They also mention revised gear ratios, but I bet it is identical to the 07 STI gearing. I can't wait to look at the ECU tables.
Yes, this engine uses the same top feed blue injectors that come in the WRX and 2007 STI. Its for sure not VF43, because of the compressor housing being different. But it could be the same size as a VF43. The fuel pump being bigger would be nice. Our 08 WRX used the stock fuel pump and worked just fine up to 380WHP. If the 08 STI has a bigger one, maybe we can say goodbye to the noisy Walbro?
Originally Posted by oh8STi View Post
i ordered mine with the Nav, BBS and fogs, Aspen White, But now i kinda like the front end without the fogs...... also i dont wanna be a pain or anything Jeff, but i also need to know what wheels will fit on there with snow tires. if you could relply that would be much appreciated! again thanks for the updates man!
Mike
Not sure if anyone makes that big of a snow tire. But there are lots of 17" tires out there. So you might have to get new wheels to do that.
I am sure we can go to 7000. As far as making a peak power, that extra 500RPM doesn't do anything. It does add area under the curve, so of course one of the first things the tuners are going to do is raise it to 7000. But it will not change the peak TQ or HP numbers.
That is strange?? I bet its the STI wheels for the WRX. It shows they have both on there. I do like those! But for that much you could get some custom wheels from CCW!
PERRINJeff is offline   Reply With Quote
Old 12-13-2007, 01:13 PM   #111
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Not with that IDC.
Remember these things run really rich. So the ICD's after a tune will be better....hopefully!
Old 12-13-2007, 01:52 PM   #112
AdsWRX
Member#: 16227
2004 Honda S2K
Silverstone
IM pulling a C right now. He is from mexico, i dont really want to post his name...online
AdsWRX is offline   Reply With Quote
Old 12-13-2007, 02:42 PM   #113
SjpWrx
Member#: 22554
2007 Corolla no PW!
WHITE miss my WRX :(
*suscribed*
SjpWrx is offline   Reply With Quote
Old 12-13-2007, 04:11 PM   #114
oh8STi
Member#: 166572
2008 STi
yeah there is no way im goin to put snow tires on the BBS wheels, seeing that if i slid and bent one, id feel like a tool. i just need the official bolt pattern and offset so i know what to order from tirerack, and know that they will fit over the brakes no problem.
Mike
oh8STi is offline   Reply With Quote
Old 12-13-2007, 05:12 PM   #115
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I went there too- the guy I had wore socks with sandals all semester. Quirky fellow...
Frank
Frank A is offline   Reply With Quote
Old 12-13-2007, 06:55 PM   #116
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Agreed. I saw them yesterday on Jeff's car, and they are really really nice. I ended up going with the BBSs since I like the gold wheels on the blue car, but the regular 18s are cool.
Cheers,
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 12-13-2007, 07:26 PM   #117
PERRINJeff
NASIOC Manufacturer
Member#: 74110
So did you pick it up yet?
Old 12-13-2007, 07:50 PM   #118
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Waiting on Subaru of America to release the cars. Could be tomorrow, probably early next week!
Jeff
Old 12-13-2007, 08:45 PM   #119
PERRINJeff
NASIOC Manufacturer
Member#: 74110
We had this great idea what to use one of those side vents for.
Actually we did find a great place for the PWI-1 behind the vent on the washer tank. We are going to be offering water injection tuned maps for the STI stages even starting with stage 0. While this isn't something many customers look at until they get to the higher stages, i think we can show its worth on a bone stock car. Results to follow over the next few weeks!
Old 12-13-2007, 09:44 PM   #120
oh8STi
Member#: 166572
2008 STi
i heard that people are starting to receive cars now....is this true?
Old 12-13-2007, 10:53 PM   #121
BlueF
Member#: 45324
Jeff
I'm so ready for mine to show up. Would love to drive it home for the holidays!!!
BlueF is offline   Reply With Quote
Old 12-14-2007, 03:51 AM   #122
bingpwr
Member#: 105107
2001 Nissan SentraSE
Gawd...the white with no fogs looks so damn goooooood...
bingpwr is offline   Reply With Quote
Old 12-14-2007, 05:08 AM   #123
bluecomet
Member#: 76814
With the 15 runs we did, we tested the I-drive stuff out. Like in the LGT spec-b, it does effect how the car feels, but does it effect power?? Not a single bit! I expected differences in low end power, but nothing! Boost was the same, power, tq, boring!! The only thing I-drive does is change the Throttle position vs. the accelerator position. Which does effect low end power, but only in normal driving conditions. When it comes time to tune these, being able to change maps with the poke and twist of a button will be very cool.
So if I was not interested in changing maps then this feature would be absolutely worthless for track use?
How does it make a difference in normal driving?
bluecomet is offline   Reply With Quote
Old 12-14-2007, 03:09 PM   #124
PERRINJeff
NASIOC Manufacturer
Member#: 74110
For track stuff, yes the I-drive is no good. BUt when we can load different maps into it, then we can do some cool stuff!
But for normal driving its just like having an I-foot. Meaning on sport the throttle works like you expect. The Sport Sharp is more aggressive, instead of 10% TPS giving you 10% throttle, its like 10%TPS give you 20% throttle. This is across the board, and of course 100% is 100%. The I mode is exactly the opposite. 10% throttle, gives you 5% throttle. This i how they say it saves you gas.
The pics and write up are almost done, be on the look out!
Old 12-14-2007, 04:07 PM   #125
oh8STi
Member#: 166572
2008 STi
is there any aftermarket exhaust stuff that your working on, or maybe last years DP will fit... is that a possibilty? just spit ballin'
Mike
Perrin Lightweight Pulley Dyno Results explosivo South West Impreza Club Forum -- SWIC 34 10-24-2009 03:51 PM
PERRIN 2008 STI Stage 2 Results..... PERRINJeff Proven Power Bragging 57 03-12-2008 11:40 AM
ProImage's Surgeline Tuned, PERRIN GT3076R kit Dyno Results PERRINJeff Proven Power Bragging 27 12-03-2007 01:36 PM
Ultimate Racing 2008 WRX Dyno Results Ultimate Racing Proven Power Bragging 14 09-27-2007 12:59 PM
