#1 |
Member#: 104120
If I were to use UTEC SD mode and knowing that the turbo will saturate the stock MAF sensor at 5V.
In this case, must I use bigger MAF housing to avoid the MAF sensor saturation ? As in SD mode, it is MAP base, will it affect the SD mode operation once the MAF sensor saturated ?
#2 |
Vendor
Member#: 162594
TXIC
Vehicle:04 WRX STG 4+ |
when in sd mode, it wont matter if the maf sensor is pegged at 5v as it runs off of the map sensor. when the utec crosses into the sd threshold, the maf is only used as a air temp sensor. thats one of the great things about sd.
#3 |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
I find that even with SD it's nice to have MAF voltage to to compare one road pull agaisnt another. A bigMAF run at 4.9v feels a lot different then a bigMAF run at 4.5v
#4 | ||
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
You'd be able to tell between the two just by looking at the boost between those runs, no need to look at a MAF sensor voltage.Here is a UTI log of a FP Green 05 WRX maxing out the MAF sensor in SD mode. As you can tell there is no leaning out caused by MAF saturation because it is running SD ![]() Quote:
#5 |
Member#: 104120
cool..thank you very much..this helps alot ..and I can concentrate on the tune.
#6 |
Member#: 89058
International
Vehicle:2003 WRX 9.63/150mph EJ257+BW S374 735whp |
do I need bigMAF runing SD with FPGreen and 29PSI ?
#7 |
Member#: 89058
International
someone?
#8 |
Member#: 60794
Vehicle:2007 Solstice GXP |
| Thread Tools | |
| Display Modes | |
| Front 02 Sensor,Rear 02 Sensor,MAF Sensor,Blox Shift Knob,SPT Oil Cap, bunch of stuff | TopEndPull | Engine/Power/Exhaust | 11 | 08-14-2009 05:48 PM |
| location of MAF sensor on 02 TS | dlong27 | Normally Aspirated Powertrain | 3 | 05-29-2009 01:20 PM |
| SD question: MAF sensor placement.... | AaronWRX | UTEC | 9 | 05-23-2007 07:04 PM |
| WTB -> MAF Sensor (Charlotte) | tmarcel | South East Region Private Classifieds | 1 | 04-03-2007 01:17 PM |
| AEM cold air intake + MAF sensor for sale | ZapZilla | Private 'For Sale' Classifieds | 6 | 02-12-2004 10:30 PM |
