Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 12-11-2007, 10:46 PM   #1
leeswrx
Member#: 118295
05 STI
Default How many MPG and not able to get a full tank
I have an 05 STI(Stock), and I cant get a full tank. I'll fill up at the pump and it will shut off, i get in and it will be just below full. Also the gas light came on and I was only able to get about 9 gallons. Can someone shed some light on this. I know Ive seen a couple of topics on this before but I was not able to find them. Anyhelp would be greatly appreciated.
leeswrx is offline   Reply With Quote
Old 12-12-2007, 12:20 AM   #2
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
is your tank damaged ,,dent underneath the car ??
a6n6d6y is offline   Reply With Quote
Old 12-12-2007, 01:01 AM   #3
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I'm going to assume you got the car used and i'll also assume the previous owner change fuel pumps and somehow bent or messed up the fuel level sender. Then again I could be wrong but has this always been like that or did it just start happening. Check the plat that covers the fuel pump in the trunk and see if it looks like its been tampered.
Old 12-12-2007, 12:55 PM   #4
07SWPSTi
Member#: 158960
07 Impreza STi
I don't mean to "hijack" this thread but it would save us all another one with the same issue. I have had my car for at least three months roughly, I was hoping I this would not be the issue with my STi as it was on my WRX. I also fill up all the way till the pump stops, but never been able to get a full tank of gas, It's always the 3/4 line.
07SWPSTi is offline   Reply With Quote
Old 12-12-2007, 11:46 PM   #5
STIred05
Member#: 115223
2005 Subaru STI
Not likly, but you may have a small restriction in the filler neck. A restriction would cause it takes about 9gal to back fill enough to shut the pump off. I would sit at the pump for about 5 min after it shuts off and then try to pump again. If it still shuts off right away I would take a good long look at your tank.
STIred05 is offline   Reply With Quote
Old 12-13-2007, 10:18 PM   #6
leeswrx
Member#: 118295
05 STI
I believe this has been going on the whole time. And I did buy the car used. Subaru replaced the block, clutch, flywheel, and turbo. I had an 02 wrx and it got great gas milage. I'll check the plate in the trunk and get back with you. thanks
Old 12-15-2007, 11:08 AM   #7
leeswrx
Member#: 118295
05 STI
I looked in the trunk and there was two plates, one on the left and right. Neither of them looked like they were messed with, could be wrong though. By the way I filled up about a week ago and my tank is down to a 1/4 with 135 miles. Im a real easy driver, I think I would get better gas milage, considering it is suppose to get around 280ish to the tank. Should I take this to subaru or is there something else to look for or do? Once again, I appreciate the help.
Old 12-16-2007, 03:42 AM   #8
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
someone posted about this a while back... I think it had something to do with some anti-syphon valve or something in that filler neck or something that was getting stuck.. Can't remember the details..
jigga is offline   Reply With Quote
Old 12-16-2007, 07:53 AM   #9
cbourbs
Member#: 117749
one thing i've noticed with mine (05 sti) is that when it stops, don't fill it up anymore, like not even 10cents more. I've got gas on my feet a few times LOL!!!
cbourbs is offline   Reply With Quote
Old 12-17-2007, 01:04 AM   #10
leeswrx
Member#: 118295
05 STI
how many miles are you guys getting per tank?
Old 12-17-2007, 01:58 AM   #11
C J
Member#: 132587
2006 JrTuned STi
Stock engine 9.77@147mph
I have read somewhere else in this forum that it has todo with how fast the pump at the gas station is filling the tank. Apparently if it fills to fast the gas pump will kick off as if the tank was full b/c of the fuel building up in your cars gas tank's filler neck. So to avoid this problem all you need todo is fill the tank slower. You should beable to set the fuel pump at the station by using the metal deal on the handle (not sure what its called)
I had this problem when I first bought my car and ever since have always set the gas pump at the slower setting and never had a problem again. Might want to give it a try next time and see how it goes.
C J is offline   Reply With Quote
Old 12-17-2007, 04:18 AM   #12
phanofmuzik
Member#: 136068
2005 STi
my 05 sti does a similar thing, where sometimes it shuts the pump off with about 2 gallons to go. I just start pumping again and sometimes it clicks off, but usually itll fill the rest of the 2 gallons or so. Try pumping at like half speed. My dads 930 turbo clicks off pumps unless youre very careful with the speed on the pump. Takes SO LONG to fill that damned car up.
phanofmuzik is offline   Reply With Quote
Old 12-17-2007, 04:34 AM   #13
EJRex
Member#: 119024
2004 Impreza WRX
San Remo Red
^^ this is the right idea.. what's likely happening is that your tank purge vent (for excess fuel vapor) is slow or non-functioning, causing your issue. It happens with some Subies, but I don't know the stats... the vapors build up in the tank during filling, not allowing it to be filled completely and shutting the gas pump off prematurely.. in most cases, if you take it slow thereafter, you can top off the tank, but if the valve is clogged or stuck closed, gas will come out the filler neck.. this may or may not be your problem, but something to consider.
EJRex is offline   Reply With Quote
Old 12-17-2007, 06:04 AM   #14
btung423
Member#: 165934
It could be our MAF sensor or your spark plugs. It happened on my car (MB e320), the MAF sensor was old and faulty. I could be wrong.
btung423 is offline   Reply With Quote
Old 12-17-2007, 08:31 PM   #15
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
He would get a CEL for that, maybe even an O2 sensor code if his MAF was messed up. He'd likely have idling problems and such also. Sounds like it's what people have already diagnosed, but the gas station I fill up at when at school does this to me too. My gas light will be on and it will only take 10.5 or 11 gallons. I fill up at one specific pump and it's the only way I get a full tank.
wrxfactor is offline   Reply With Quote
Old 12-19-2007, 05:00 AM   #16
leeswrx
Member#: 118295
05 STI
The other day, when I came to a couple of red lights, right before stopping clutch in and no throttle, the rpm went up to almost 2 grand. Is this common, or is this a sign of something else?
Old 12-19-2007, 10:33 AM   #17
kellygnsd
Member#: 32669
LINK G4 hybrid STi
That's about right on the money if you ask me. As soon as the gas light comes on you still have quite a few gallons in the tank its just a warning. I usually get 11.5 gallons in if I fill up right when the gas light comes on but I usually drive about 40 miles after I get the light and put 13 gallons in or so. It would make sense for the gas light to come on when you were completely out of gas would it.
Old 12-19-2007, 01:08 PM   #18
beermesf
Member#: 142593
2002 STI Wagon
This was an interesting read. I noticed the same thing on my 05' sti tank. I thought there was something wrong because the most I have been able to get in was 12 gal. But I usually fill up within a few miles of my light going on. Thanks for posting this.
beermesf is offline   Reply With Quote
Old 12-19-2007, 01:55 PM   #19
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Double post.
Old 12-19-2007, 01:58 PM   #20
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
That doesn't make any sense though. With a 15.9 gallon tank, the gas light should go on with about 2.5 or so gallons remaining. Only taking 10.5 or 11 gallons at the light just doesn't seem correct, and I usually get about 12.5-13 in there if I fill up immediately after the light goes on. Additionally, if I "fill" it from one of the other pumps and it stops at 10.5-11 gallons, the needle will not go past the full line all the way up to the F like it normally does. I get around 60 miles from the F to the full line on average, which is where that 2ish gallons extra comes in.
Old 12-19-2007, 02:17 PM   #21
`04AlpineWhite
Member#: 65562
Check both your MAF and front O2 sensors, at least one, if not both, are bad and are causing that issue. That is, if you didn't forget to take your foot off the gas.
`04AlpineWhite is offline   Reply With Quote
Old 12-19-2007, 08:07 PM   #22
SpeedMasterLee
Member#: 78417
2005 WRX/STI Stage 2
I have had my o5 sti for about 3 years and I have never ever been able to fully fill up all the way. Always slightly above the second to the top marking.
SpeedMasterLee is offline   Reply With Quote
Old 12-19-2007, 08:24 PM   #23
az_sti_2
Member#: 163885
04 STI
full in my tank and i get like 200 miles 2 a tank! lol
az_sti_2 is offline   Reply With Quote
Old 12-21-2007, 03:52 PM   #24
jaimejrivera
Member#: 112943
280 on highway
180 on city and hard driving
Sti 05 with FP green
jaimejrivera is offline   Reply With Quote
Old 12-21-2007, 03:53 PM   #25
jaimejrivera
Member#: 112943
280 on highway
Gas tank problem.. not able to get a full tank. Jim.mEh Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 52 03-23-2010 01:21 AM
Need to get a full tank out of my car in a day..... lavid2002 Newbies & FAQs 22 12-18-2009 04:41 AM
anybody else not able to get on flscc.com? wako29 South East Region Forum 7 12-19-2003 01:41 PM
How many of you commit crimes to get money and goods to live? Instead of working. I ROBOT Off-Topic 38 10-01-2002 12:00 AM
